by rv1974 » Wed May 06, 2020 7:58 pm
something like this
rv1974
- Name: rv1974
- Operating system: Windows
- SketchUp version: 2017
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by rv1974 » Wed May 06, 2020 8:28 pm
>>Many things can be done, but it would make the UI more complex... Ok, I'm just suggesting to tweak the plugin's behavior without UI changing: If face selection = surface, molding not equal 0, borders = grid, Then 'moldings' to be created between surfaces (and not along contour only)?
rv1974
- Name: rv1974
- License type: Pro
by a_pusen » Sat Jun 27, 2020 1:07 pm
This does not work in Sketchup 2020 after installing the latest Fredotools. When will this be fixed?
a_pusen
- Name: Apurba Sen
- SketchUp version: 8
- License type: Pro
- Level of SketchUp: Intermediate
by TIG » Mon Jun 29, 2020 10:22 am
It should work OK. You need the latest RBZs installing for the Fredo Extensions and his LibFredo. Note that the JPP Extension is separate from FredoTools Extension ???
After installing them you'll also need to restart SketchUp to sync everything.
When you say, "it doesn't work", what is the problem ? what are the error messages ? etc - providing those [if any] would help us to help you...
- Global Moderator
- Name: TIG
- SketchUp version: 2021
- License type: Pro
by Tymnastik » Tue Jul 21, 2020 6:47 am
Please I have installed fredo jpits shows on the tool bar but it won't work
Tymnastik
- Name: TIMILEHIN ONILEIMO
- SketchUp version: 2018
- License type: Free/Make
- SketchUp use: woodworking
- Level of SketchUp: Beginner
by Dave R » Wed Jul 22, 2020 12:57 am
Tymnastik wrote:its shows on the tool bar but it won't work
Did you also install LibFredo6? What version of SketchUp are you actually using? Your profile says 2018 Free/Make but there is no such version. Knowing the right version could help us help you.
- Global Moderator
- Name: Dave R
- License type: Pro
by AISmebel » Thu Sep 03, 2020 10:33 am
hi Fredo. I ran into such a problem, I cannot make a uniform indentation around the entire perimeter on a model with an irregular shape. I couldn't find any plugin that could do this. I have a big request to you to consider this improvement in the next versions of your excellent plugin. Thank you so much for your work! https://youtu.be/wCsli3Ps7xc
AISmebel
- Name: Иван
- License type: Pro
by slb_jwm » Thu Nov 12, 2020 5:00 pm
Joint push pull Joint and Thickener both fail with errors when I try to make this skin (part of a geodesic dome of frequency 3) thicker (by 3/4"). But they only do it when the component is part of a larger model. In a separate model, both those forms work, but only extrude normal to the faces (as designed). Extrude works, but takes only an average direction, presumably along the radius to the centre of the hexagon. Feature request: could there be an option in the existing plugin to enlarge radially from a given centre? Either the origin of a component opened for editing, or perhaps picked by the user? Icosahedral skin.skp I've managed to do it approximately with the Scale tool, but can't get it to scale to an exact thickness of 3/4"
slb_jwm
- PluginStore Author
- Name: Steve John
- Operating system: Mac
- SketchUp version: 2016
- License type: Pro
by Dave R » Thu Nov 12, 2020 5:32 pm
- Global Moderator
- Name: Dave R
- License type: Pro
by fredo6 » Fri Nov 13, 2020 8:41 pm
JPP Thickening is done along the normal of faces. If it happens that all faces are perpendicular to the the radial dierction, then it is OK.
- Name: Fredo6
- License type: Pro
- SketchUp use: interior design
by Raimondo_Vincenti » Mon Dec 14, 2020 4:02 pm
Installed libfredo6 11.4f -> JointPushPull is not awailable and cannot be installed anymore. Message(german): "JointPushPull_v4.4e.rbz konnte nicht installiert werden."
Raimondo_Vincenti
- Name: Vincenti
- SketchUp version: 2020
- License type: Pro
- SketchUp use: hobby
by Dave R » Mon Dec 14, 2020 5:21 pm
"JointPushPull_v4.4e.rbz konnte nicht installiert werden." Where are you looking for it? Screenshot - 12_14_2020 , 10_19_17 AM.png https://sketchucation.com/pluginstore?pln=JointPushPull
- Global Moderator
- Name: Dave R
- License type: Pro
by TIG » Mon Dec 14, 2020 8:12 pm
If you have successfully downloaded Fredo's extension as an RBZ file, then you still need to 'Install' it... using the appropriate button on SketchUp's 'Extension Manager' dialog... But note that, as explained in the extension's notes, it also requires you to download and install a suitable version of the Libfredo... RBZ... [>=8.7] After that you will need to restart SketchUp to 'sync' the loading files...
- Global Moderator
- Name: TIG
- License type: Pro
by Raimondo_Vincenti » Tue Dec 22, 2020 5:52 pm
Fredo6 Libfredo6 is installed (Version11.4f) is installed Still cannot install JointPushPull - a Sketchup 2021 problem?
I could use JountPushPull in Sketchup 2020.
Raimondo_Vincenti
- Name: Vincenti
- License type: Pro
by Einstein » Sun Jan 10, 2021 4:06 pm
Hello, I got an error with joint push pull extrusion in SketchUp 2020.
Date: 10-Jan-21 15:59:27 An error occurred in Joint Push Pull Error in generation of the geometry
undefined method `target' for nil:NilClass jointpushpullgeometry.rbe: 447 -- block in geometry_create_top_face jointpushpullgeometry.rbe: 445 -- collect jointpushpullgeometry.rbe: 445 -- geometry_create_top_face jointpushpullgeometry.rbe: 258 -- block in geometry_robot_prepare_mesh jointpushpullgeometry.rbe: 257 -- each jointpushpullgeometry.rbe: 257 -- each_with_index jointpushpullgeometry.rbe: 257 -- geometry_robot_prepare_mesh jointpushpullgeometry.rbe: 212 -- robot_call_action jointpushpullgeometry.rbe: 183 -- geometry_robot_exec jointpushpullgeometry.rbe: 166 -- geometry_robot jointpushpullgeometry.rbe: 81 -- block in geometry_execute lib6operation.rbe: 369 -- step_geometry lib6operation.rbe: 304 -- block in yield?
Einstein
- Name: Michal P
- License type: Pro
by fredo6 » Sun Jan 10, 2021 4:55 pm
I guess you wish to push-pull all faces. Then, you have a number of them which are ill-formed and there is nothing JPP can do about it. For instance, these group of buildings: Einstein - JPP - faces 1.png Einstein - JPP - faces 2.png Einstein - JPP - faces 3.png
- Name: Fredo6
- License type: Pro
by Einstein » Sun Jan 10, 2021 5:32 pm
Then would it be possible for the plugin to skip the ill-formed faces, leave them unextruded and proceed? Ok, some of the faces are broken but most of them are OK. Why break entire operation due to a few wicked faces?
Einstein
- Name: Michal P
- License type: Pro
by Dave R » Sun Jan 10, 2021 5:55 pm
Why not clean up the model before you add more geometry and potentially make more problems for yourself?
- Global Moderator
- Name: Dave R
- License type: Pro
by fredo6 » Sun Jan 10, 2021 6:38 pm
Einstein wrote:Then would it be possible for the plugin to skip the ill-formed faces, leave them unextruded and proceed? Ok, some of the faces are broken but most of them are OK. Why break entire operation due to a few wicked faces?
I concur with Dave. Better clean up the model if you wish to do something with it. Detecting and cleaning the problem is a whole big task in itself. It could deserve a plugin. This is not like Sketchup tells you the face is ill-formed or not. Actually, these faces are toplogically valid for Sketchup but they won't work with many transformations and operations. So, using a detection and fixing before operating JPP would be counterproductive and a big hit to performance in 99.9% of cases where the geometry is OK.
- Name: Fredo6
- License type: Pro
by Dave R » Sun Jan 10, 2021 7:09 pm
Thom Thom's CleanUp3 could remove coplanar edges to merge faces although it may not remove the correct edges. In this particular model it would be difficult for an extension to identify which edges should be removed.
- Global Moderator
- Name: Dave R
- License type: Pro
by Einstein » Sun Jan 10, 2021 10:22 pm
That's weird. I actually did a cleanup using ThomThom's plugin and JPP first threw an error. Then did a cleanup again and JPP worked fine. I don't know why it happened but sorry for bothering you.
Einstein
- Name: Michal P
- License type: Pro
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Plugins
