[Plugin] FredoSpline - v1.7a - 06 Jan 21
Re: [Plugin] FredoSpline - v1.4a - 01 Jun 20
Postby fredo6 » Sat Jun 20, 2020 7:38 am
Gray Gardner wrote:File won't seem to install in my sketchup. "failed to install FredoSpline_v1.4a.rbz"
Difficult to help without more information....
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] FredoSpline - v1.5a - 19 Aug 20
Postby fredo6 » Wed Aug 19, 2020 9:16 pm
NEW RELEASE: FredoSpline v1.5a - 19 Aug 20
Requirements
  • LibFredo6: v11.0a
FredoSpline 1.5a is a maintenance release for cosmetic adjustments and extension of validity
Home Page of FredoSpline for information and Download.
Main post of this FredoSpline thread.
User avatar
PluginStore Author
PluginStore Author
Postby rv1974 » Tue Oct 06, 2020 11:16 am
Fredo, is Covert curves command able to alter radius of already existing fillets (in polycorner arc curve)? Or at least remove all fillets (= radius 0)?
rv1974
Postby fredo6 » Tue Oct 06, 2020 3:36 pm
rv1974 wrote:Fredo, is Covert curves command able to alter radius of already existing fillets (in polycorner arc curve)? Or at least remove all fillets (= radius 0)?
If you wish to remove all fillets, then SWAP it to Polyline.
Remember the difference between Edit, Swap and Convert:
  • EDIT allows to change the parameters (as well as control points) of a single existing FredoSpline curve. Actually, you can also change the type.
  • SWAP changes the type of an existing FredoSpline curve. The benefit of Swap is that you can preselect several curves
  • CONVERT is used to make a FredoSpline curve of a given type from one or several non-FredoSpline sequences of segments. Indeed, it also works with a FredoSpline curves; in which case, it would be equivalent to Swap.
User avatar
PluginStore Author
PluginStore Author
Postby rv1974 » Tue Oct 06, 2020 8:56 pm
thank you for clarification, Swap function is divine as well as all toolset :enlight:
rv1974
Postby Michelfad » Sun Oct 11, 2020 11:23 am
HOW TO UPDATE FOR THE LATEST VERSION
Michelfad
Postby rv1974 » Wed Oct 21, 2020 10:09 am
Fredo, here is a small but important suggestion:
When editing* polycorner's fillets with mouse scrolling (or slider) it'd be great to have ability to snap to user defined rounding values (like 10\50\100 cm)
It could be implemented by continuously pressing one of modifier keys while scrolling
*- Usually people work with 2+ digits after point precision, and using mouse scroll\slider now delivers bad radius values.
Thank you for attention
rv1974
Postby fredo6 » Wed Oct 21, 2020 1:20 pm
rv1974 wrote:Fredo, here is a small but important suggestion:
Maybe I'll add an explicit configuration parameter, because there are issues with guessing the right increment:
  1. imperial and other exotic units could be used
  2. the order of magnitude is difficult to infer, as curves are drawn outside of context. You wish 10/50/100 cm, but another user may want 10/50/100 m)
User avatar
PluginStore Author
PluginStore Author
Postby rv1974 » Wed Oct 21, 2020 7:55 pm
BTW For some reason Profile Builders assemblies don't like closed polyacrc curves- they need to be converted to regular polylines (or exploded) in order to be treated as paths
rv1974
Postby fredo6 » Thu Oct 22, 2020 7:43 pm
rv1974 wrote:BTW For some reason Profile Builders assemblies don't like closed polyacrc curves- they need to be converted to regular polylines (or exploded) in order to be treated as paths
I don't have Profile Builder installed. This is strange, because FredoSpline generate geometry as true Sketchup curves, with some extra attributes. So, it should be transparent to Profile Builder.
The problem with closed curves is the start point of the curve, which may not be what you would visually expect.
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] FredoSpline - v1.6a - 19 Nov 20
Postby fredo6 » Fri Nov 20, 2020 8:59 am
NEW RELEASE: FredoSpline v1.6a - 19 Nov 20
Requirements
  • LibFredo6: v11.3a
FredoSpline 1.6a is a maintenance release for
  • Help can be accessed in a separate window, not just the Instructor
  • Extension of validity
User avatar
PluginStore Author
PluginStore Author
Postby DidiTheOne » Tue Dec 29, 2020 8:18 pm
Hi Fredo,
I want to report to you what seems to be bugs with the plugin in SU2021:
1) Trying to click and drag a control point often results in no action at all. That's especially true when zoomed in for precison movements, regardless of the number of segments, and even deactivating sticking to inference points. After many attempts, sometimes the control point moves. But it's very hit-and-miss, making the plugin unusable for complex works. Many other times, the control point stops moving before you are done editing it.
2) I can't seem to find a way to control the weight/angle at each side of the control point. Maybe I'm missing something here, or maybe it is not an implemented feature yet.
3) When you add a control point in edit mode, the plugin immediately exits the edit mode. So the edit mode has to be reselected each time you want to modify the control point that has just been added. And in doing so, everytime the plane you selected (for example XY or XZ) gets reset. So it's quite likely that you forget about reselecting the correct plane each time, which ends up in wrong edits.
Hope this help in hunting bugs. Let me know if I can help with experimenting, or just uploading a vid of the problems.
DidiTheOne
Postby fredo6 » Tue Dec 29, 2020 9:44 pm
@DidiTheOne
This must be very specific to your configuration or to your model, as nobody reported such problems in SU2021 (or other versions of SketchUp).
It might be that your mouse is slightly desynchronized from the visual feedback you see on the screen. In general, clicking outside the curve will exit the tool.
1) To move a control point, hover over the point until you see an orange disk. Click-Drag on it, or Click-Release-Drag.
2) For weight / angle, which curve are you referring to? A mousewheel on the small pin should change the parameters
It would help to have a video of the problem, because I have no hint on what the problem could be with the information you give.
User avatar
PluginStore Author
PluginStore Author
Postby rv1974 » Wed Dec 30, 2020 11:24 am
This is enigma for me as well. The brown tension slider (in edit mode for local fit spline for example) controls only one side, no effect on other.
P.S. In attached file, I can't make smooth areas, why is that?
rv1974
Re: [Plugin] FredoSpline - v1.7a - 06 Jan 21
Postby fredo6 » Wed Jan 06, 2021 8:42 am
NEW RELEASE: FredoSpline v1.7a - 06 Jan 21
Requirements
  • LibFredo6: v11.3a
FredoSpline 1.7a is a maintenance release for Extension of validity.
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: arcnguyenmanhhung, MissLong, qifu123, samuel_t, SHANUAGARWAL , shim jain cho and 12 guests
Visit our sponsors:
