[Plugin] Skelion (solar, shadows)
Re: [Plugin] Skelion (solar, shadows)
Postby tald311 » Wed Nov 16, 2016 4:33 pm
Greetings,
I am having issues getting the Relief terrain to import. I have tried it on both SU 2016 and 2017. I use the location tool to geo-locate and then Relief but the window hangs and just continues to process without importing any data.
I have tried this both at home (no firewall) and work (we have a firewall - but we checked it to make sure it was not being blocked).
Any suggestions?
Daniel
tald311
Premium Member
Premium Member
Postby phunter10 » Fri Mar 03, 2017 1:45 pm
Hi Juantxo,
We are also having the same problem as tald311 in regards to the relief feature. Is this no longer supported in the latest sketch version of 2016 onwards?
best,
PH
phunter10
Postby phunter10 » Fri Mar 03, 2017 3:30 pm
hi Juantxo,
Is relief feature not supported in the latest version of sketch up 2016-2017? We are trying to capture part of the terrain over cave creek Arizona.
Regards,
PH
phunter10
Postby Juantxo » Sun Mar 05, 2017 6:18 pm
Just update to skelion 521. Some address changed and relief tool stop working. It is fixed in 521.
User avatar
Juantxo
Postby Smexystef » Fri Feb 23, 2018 2:26 pm
When I place panels their borders (edges) look white in a certain perspective. We've gotten clients who've asked why the panels had a white border while we offered them full black panels. How can we avoid this?
Also, is Skelion still being worked on? Last update seems to be almost a year ago.
Smexystef
Meteorological Data Setting Error
Postby girish0105 » Tue Oct 30, 2018 3:36 pm
Whenever i try to set the meteoroogical data in skelion i get this error "Waiting for Web Service Response"
girish0105
Postby Juantxo » Tue Oct 30, 2018 3:43 pm
Update to last version ( 523 October 2018).
You need Internet Explorer 11 (You must update if you not have)
Set Internet Explorer 11- Internet Options - Security to the minimum possible.
Best
User avatar
Juantxo
Postby danniejackson » Sat Jan 25, 2020 12:17 am
I should have found this plugin earlier. I just started using it this week on passive and active solar design models for green built homes. I have made some models for solar space heating panels and used them in my SketchUp designs, and looked at solar radiation on windows and solar gain using a little math to devise Representative solar gain figures for windows.
What I want to say the most about this plugin is that it is way easier to use than some of those plugins for use with coupling DOE and NREL software with SketchUp. You can get started right away and get that data you really want for designing solar homes.
I am writing about my experience with this plugin in my models and some of the devices I have design with it such as solar space heating panels. https://solarparadigmdesign.wordpress.com
danniejackson
I want to get results like training videos in surface report
Postby Kawasakippp » Wed Oct 21, 2020 1:55 am
(I'm using google translate so I'm sorry if there is a mistake in English)
I'm having trouble getting results like training videos on the surface report.
Is the procedure missing?
Software used
・ Sketchup2020Pro
・ Skelionpro
Steps I'm taking
① Acquisition of terrain data by geolocation (Digital Globe)
② Component creation (skelion component, mark collecting surface setting)
③ Component placement in geolocation terrain data
④ Add construction point to the component
⑤ Select an edge and surface report
Surface repport does not work with construction point
If there is no construction point
Only Edge Azimuth and Edge Tilt can be obtained
Am I missing something?
Kawasakippp
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: No registered users and 5 guests
Visit our sponsors:
