Animating retractable lightsaber
General discussion related to SketchUp Pro and Make
Postby matsuo_lano » Sat Oct 17, 2020 10:30 am
Like the topic said, I want to try and achieve this (I hope rather simple) animation. The idea is to render it with SUPodium when finished. Since this uses scenes for rendering, I found out that Fredo6's animation plugin wouldn't be the right one. Any other plugins I can use?
You try to rearrange me 'till I'm sane
matsuo_lano
Re: Animating retractable lightsaber
Postby Mike Amos » Sat Oct 17, 2020 12:01 pm
How about sketchup scenes? Different lengths of 'blade' on different layers, switch off all but the one you want for each 'frame'.
Premium Member
Premium Member
Postby pbacot » Sun Oct 18, 2020 1:30 am
Could one use the section animation for this. Two scenes with different section cuts. Wouldn't SU animate the transition?
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
User avatar
Top SketchUcator
Postby solo » Sun Oct 18, 2020 1:51 am
Technically, a lightsaber beam is about 3ft so from off to fully extended it would take 3.0501e-9 or 10 to the 9 nanoseconds. An animation is what 30 frames per second? so it would take way less than a single frame to extend, no need for animation, render it off then on, there is no visible transition. :puke: :mrgreen:
User avatar
Global Moderator
Postby matsuo_lano » Tue Oct 27, 2020 7:09 pm
Well, I've decided to ditch animating it all together and just make a simple render. Will post it in a few!
matsuo_lano
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: Google Bot and 4 guests
Visit our sponsors:
