MSPhysics 1.0.3 (16 October 2017)
Re: MSPhysics 1.0.3 (16 October 2017)
Postby pilou » Tue Jul 21, 2020 1:35 pm
For your tests :)
Put your links as you want...
Wanted 2 curves...
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Sat Jul 25, 2020 11:06 pm
Sorry bad hypothesis ! :oops:
That can't work with these prisms!
There are overlapings!
Works for 2 perpendicular "lines" but not for a checkerboard! :-P
Here with a pyramid with 5° basis
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Fri Jul 31, 2020 8:09 am
I found my error and won half of joints! ;)
No so evident to find the good angles following sizes! :ugeek:
3
Speedy Galerie
User avatar
Top SketchUcator
Postby azizxpx » Fri Sep 04, 2020 1:38 pm
Hello Anton_S
We thank you very much for this effort
I was hoping the work would Export in mdl format
Is there a way for that?
Thanks ..
azizxpx
Postby mkurmanalinova » Mon Sep 28, 2020 7:22 am
Hello, could you help me?
1. I need a command, a function that allows to find out the position of the pusher at any time by using the keys, for example. At the moment the position of the pusher is bound to the sensor. The box crosses the sensor, the sensor issues a task for the movement of the puher. Also, when we touch the sensor, we display the coordinates of the pusher. The command “puts” didn’t help, it show the text, but we need the changing value.
2. I need a command that is triggered by the condition: "sensor 2" = 1, "sensor 3" = 1, moreover, when the box leaves the sensor's range, "sensor 2" = 0. The pusher moves to a value of -70 when there are 2 boxes on the conveyor in the range of sensors 2 and 3.
The problem is as follows: the pusher is triggered by the condition if laser2 && laser3> 0, fly = -70, written in the script of sensor 3.
But when the box crosses the sensor 3, only one condition is triggered (laser3> 0), the boxes do not accumulate.
Is there a function (onTouch, onUpdate, etc.) where you can write a condition via an if for two sensors?
mkurmanalinova
Postby eosmontana » Tue Nov 17, 2020 11:14 pm
Does anyone know of a work around to install on a mac in SKU2019?
eosmontana
Postby Dave R » Sat Nov 21, 2020 12:15 am
eosmontana wrote:Does anyone know of a work around to install on a mac in SKU2019?
As per earlier posts in this thread, the extension doesn't work in versions later than 2018 so there's no point installing it for SketchUp 2019. The author is working on a new version and it'll be released as soon as it is ready.
User avatar
Global Moderator
Postby ak-sam » Wed Feb 17, 2021 10:32 pm
Hello are there any updates on when this could be compatible with SU2020 & 2021?
ak-sam
Postby Dave R » Wed Feb 17, 2021 10:48 pm
ak-sam wrote:Hello are there any updates on when this could be compatible with SU2020 & 2021?
See: viewtopic.php?f=323&t=56852&start=840#p656107
User avatar
Global Moderator
Re: MSPhysics Preview
Postby pinyol » Wed Feb 24, 2021 4:53 pm
Hi Anton,
Any news on when you'll be able to release an updated version of this wonderful Plugin?
Best,
Juan
pinyol
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: Jamesjj2020, Majestic-12 Bot, ramsun, smjeon and 10 guests
Visit our sponsors:
