[Plugin] CleanUpRe: [Plugin] CleanUpToo bad. This used to be a good plugin. Any options out there?
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
Re: [Plugin] CleanUpI haven't seen any problems with CleanUp3. It works as expected in SU2020.
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: [Plugin] CleanUpI am seeing the CleanUp stats unchanged when running it more than once on the same thing as well. Make 2017 on Win 10. I uninstalled the Lib and the CleanUp extension. Being Windows I rebooted and did a fresh install. CleanUp now reports hours to completion on tasks that took seconds before.
I did another purge and reinstall with fresh downloads, results are the same so there may be a problem with older versions although the notes state compatibility. I will back-rev and report back. Re: [Plugin] CleanUpCleanUp or CleanUp3
When you did the reinstall was that for SketchUp? If so, did you right click on the installer and choose Run as administrator? Etaoin Shrdlu
Re: [Plugin] CleanUpCleanUp3. I used the Extension Manager to install it. I did not re-install SU.
I tried back-reving by zipping cleanup1, renaming it .rbz and using the Extension Manager to install it, no go; errors. I used Extension Manager to install CLeanUp3 again. It uses a pop-up to ask you to upgrade it which I do via the Extension Manager. I am still seeing the same 'edges reduced' figure despite repeated cleanings and saving of the file, closing re-opening the app, etc. The native 'statistics' do show a reduction the first time CleanUp3 is run so it is working. The repeated display of the original figures may just be a bug. I did find a bandsaw model that I have in a shop layout that reports a couple of hours to clean. Other similar models work fine. this bandsaw could be why my open and save functions on this particular file are slow, eh? ![]() I will let it run to completion and check the native stats and report back. Last edited by glenn bradley on Wed Oct 07, 2020 5:30 pm, edited 1 time in total.
Re: [Plugin] CleanUpNot quite 2 hours to complete. The native stats show a small decrease in edges and faces for the bandsaw model. When I run CleanUp3 again the same figures appear and the nearly 2 hour estimate re-starts.
I'm not sure where to go from here as I stubbornly stick with Make 2017. I will try the built in purge and fix functions and see how I get on. I cannot say that this behavior is universal as I only have my current Win 10 and Make 2017 environment. Re: [Plugin] CleanUpWhat bandsaw component are you using?
Re: [Plugin] CleanUpRepairing edges isn't working for me. It claims to remove edges, but it doesn't.
For example, I'll select 12 connected edges. Run CleanUp3. The dialogue will say "Edges Reduced: 3". But all 12 original edges remain. So it's like CleanUp3 sees the correct edges that it should be deleting, but then it doesn't actually delete them. I'm running SketchUp 2020 on Windows, with CleanUp3 v3.4.3. I'd appreciate any suggestions. Thanks for all the great plugins, thomthom. Re: [Plugin] Cleanup (1.0.0) — 21 October 2009
Hei hva med en shortcut icon in toolbar ? Thanks Dan Stavanger Re: [Plugin] CleanUpCan you add a stop clean button ? , coz when removing dublicated faces takes hours on large components
Thanks Dan Re: [Plugin] CleanUpOpps my bad , there is a cancel button when u dont use last settings sorry
great cleaner Dan |
Who is online
Users browsing this forum: Inka22 and 9 guests
