[Plugin] JointPushPull Interactive - v4.4e - 02 Jun 19
Re: [Plugin] JointPushPull Interactive - v4.4e - 02 Jun 19
Postby rv1974 » Wed May 06, 2020 7:58 pm
something like this
rv1974
Postby rv1974 » Wed May 06, 2020 8:28 pm
>>Many things can be done, but it would make the UI more complex...
Ok, I'm just suggesting to tweak the plugin's behavior without UI changing:
If face selection = surface,
molding not equal 0,
borders = grid,
Then
'moldings' to be created between surfaces (and not along contour only)?
rv1974
Postby a_pusen » Sat Jun 27, 2020 1:07 pm
This does not work in Sketchup 2020 after installing the latest Fredotools. When will this be fixed?
a_pusen
Postby TIG » Mon Jun 29, 2020 10:22 am
It should work OK.
You need the latest RBZs installing for the Fredo Extensions and his LibFredo.
Note that the JPP Extension is separate from FredoTools Extension ???
After installing them you'll also need to restart SketchUp to sync everything.
When you say, "it doesn't work", what is the problem ? what are the error messages ? etc - providing those [if any] would help us to help you...
User avatar
Global Moderator
Postby Tymnastik » Tue Jul 21, 2020 6:47 am
Please I have installed fredo jpits shows on the tool bar but it won't work
Tymnastik
Postby Dave R » Wed Jul 22, 2020 12:57 am
Tymnastik wrote:its shows on the tool bar but it won't work
Did you also install LibFredo6?
What version of SketchUp are you actually using? Your profile says 2018 Free/Make but there is no such version. Knowing the right version could help us help you.
User avatar
Global Moderator
Postby AISmebel » Thu Sep 03, 2020 10:33 am
hi Fredo.
I ran into such a problem, I cannot make a uniform indentation around the entire perimeter on a model with an irregular shape. I couldn't find any plugin that could do this.
I have a big request to you to consider this improvement in the next versions of your excellent plugin. Thank you so much for your work!
https://youtu.be/wCsli3Ps7xc
AISmebel
Postby slb_jwm » Thu Nov 12, 2020 5:00 pm
Joint push pull Joint and Thickener both fail with errors when I try to make this skin (part of a geodesic dome of frequency 3) thicker (by 3/4"). But they only do it when the component is part of a larger model.
In a separate model, both those forms work, but only extrude normal to the faces (as designed).
Extrude works, but takes only an average direction, presumably along the radius to the centre of the hexagon.
Feature request: could there be an option in the existing plugin to enlarge radially from a given centre? Either the origin of a component opened for editing, or perhaps picked by the user?
Icosahedral skin.skp
I've managed to do it approximately with the Scale tool, but can't get it to scale to an exact thickness of 3/4"
slb_jwm
PluginStore Author
PluginStore Author
Postby Dave R » Thu Nov 12, 2020 5:32 pm
Is this what you're trying to do?
User avatar
Global Moderator
Postby fredo6 » Fri Nov 13, 2020 8:41 pm
JPP Thickening is done along the normal of faces. If it happens that all faces are perpendicular to the the radial dierction, then it is OK.
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: 128482A, qwasdqweasd, sumant11 and 9 guests
Visit our sponsors:
