This shipmodel is an import from other CAD program and I am trying to recreate this vikingship in SketchUp making a low poly model. Tried using Curviloft but cannot make it work.
Can anyone show me how it can be done?
[img] [/img]
Attached find the SketchUp model
Vikingship
• Page 1 of 1
VikingshipLast edited by Epix3D on Fri Jul 17, 2020 11:57 am, edited 1 time in total.
Re: VikingshipYou might get a little more help if you save back your model to an earlier SU version and repost it. Not everyone is using SU2020 for various reasons.
Re: VikingshipHad to fool about with this, couldn't help myself
![]() Got a decent profile at the middle of the hull and copied the upper edge of the hull for a path. Used "follow me" tool and trimmed things up down the center with a cutting plane. Ended up with a reasonably decent 1/4 hull. Did a little reshaping on the keel and there you go ![]()
Re: VikingshipOne more thing.... I tried pulling contours off the model you posted and using Curviloft to skin it .... no love there. After doing my thing with follow me there was a lot of brute force clean up to do. Realized the original model has tons of minute line segments everywhere. I think thats what was keeping Curviloft from working on the profiles copied from the original model......
Re: VikingshipCool
![]() For any problem save as V6 will be the better solution! ![]() Of course the Gif recorder don't gives the same render than the original Twinmotion ![]()
Re: VikingshipIs that some comment from medieval Paris, a swamped Viking ship?
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
Re: Vikingship![]() It's beaten by the waves, but it doesn't sink!
Re: VikingshipWow Tuna!
What a great job! You also managed to reduce the model file significantly which was my goal. Thank you. The model was converted from some other CAD program and was pretty much messed up. Thank you again. ![]() Here is a photo from my hometown Tønsberg where the original vikingships where found. While the originals stays in the museums in Oslo they build replicas at the site the old way using same tools as the vikings. This is from the launch of the Oseberg replica at the harbor in the middle of Tønsberg. The ships are really beautyful work of art.
Re: VikingshipEpix3D , Glad it helped you out. Realized it was not your model to start with. Was crazy how chunks of random mesh was scattered into different components and identical bunches of mesh were unique components overlapping one another. Made me wonder if it was originally modeled that way or if SU went crazy importing it. Getting rid of all the overlapping repetitive components and multitudes of short line segments down to a clean SU mesh really did make a difference in file size. Kept it simple and figured the final result was clean enough for you to add detail if needed.
Re: VikingshipGreat job! Thanks for all the details too!
• Page 1 of 1
