How I make the shapes with curviloft
• Page 1 of 1
How I make the shapes with curviloftCurviloft can be downloaded from here.
https://sketchucation.com/pluginstore?l ... category=0 First make a box. Last edited by Bryan K on Sun Jun 28, 2020 1:20 am, edited 1 time in total.
Re: How I make the shapes with curviloftNext, delete 3 sides.
Re: How I make the shapes with curviloftNext draw straight lines to use as guides and part of the final solid model.
Re: How I make the shapes with curviloftNow use the basic arc tool and draw arcs.
Re: How I make the shapes with curviloftFurther refine the arcs so the corners are not pointy.
Re: How I make the shapes with curviloftDraw new guideline on the bottom and repeat the process with arcs and then smaller arcs on the corners.
In this case, I just drew one arc to make a perfect corner arc. See my portfolio at https://delphiscousin.blogspot.com/
Re: How I make the shapes with curviloftNow erase all the guidelines and just leave the 3 sided arc faces.
Re: How I make the shapes with curviloftSelect all the outer edges with Curviloft.
This is a different image but essentially the same process. Somehow the original image export became corrupted and then deleted itself. The click the small green checkmark and the big checkmate which will appear. Last edited by Bryan K on Sat Jun 27, 2020 8:40 pm, edited 1 time in total.
Re: How I make the shapes with curviloftYou now have a quarter of your final shape.
IMPORTANT! Make sure you EXPLODE the Curviloft shape or it will only be a shell and not a solid model. Exploding it welds it back to the lines you used to create it, giving it the flat inner sides and bottom and a fully enclosed model. This makes it easier to modify later. Last edited by Bryan K on Sun Jun 28, 2020 12:09 pm, edited 2 times in total.
Re: How I make the shapes with curviloftMake the model a component or group. I make components based on Front, Rear, Top and Bottom. So four final components for each quarter.
Duplicate and flip each one to make final shape. Then scale top or bottom as you see fit. I usually scale the bottom to be shorter than the top. Last edited by Bryan K on Sat Jun 27, 2020 8:39 pm, edited 1 time in total.
Re: How I make the shapes with curviloftAnd that's it! Add detail as needed by making and using separate components.
Re: How I make the shapes with curviloftCool tuto
![]() Seems you can have same result with Extrude Tools by Tig from this step ![]() (sure with less options after the mesh creation) or here Ferrari ![]()
Re: How I make the shapes with curviloftVery interesting process Bryan. I did some of it (enough to understand the process). I had to try several times to get the lines and arcs all connected properly to that CurviLoft would work correctly.
Want to experiment a little with the types of CurviLoft so I understand the differences better. Thanks for sharing..............Now I will have to go off and try to be "inventive". ![]() ![]() Re: How I make the shapes with curviloft
That IS the trick. It does take some fiddling. If the arcs aren't connected just perfect, it will not work. Be sure to connect arcs on "points" (green dots) and not "midways" (blue dots). You're welcome. My pleasure. Many people here have helped me over the years and I am happy I can do anything to pay back or pay forward any way I can. See my portfolio at https://delphiscousin.blogspot.com/
Oh that is cool. Nice! Extrude tools are what I've been looking for some time but forgot what it was called. Thanks! And just installed and yes, this is what I've been looking for quite some time. ![]() Ah, but it does not work on straight edges nor too many compound curves. Still, very handy tool. Last edited by Bryan K on Sun Jun 28, 2020 1:28 am, edited 1 time in total.
Re: How I make the shapes with curviloftCurviloft can be downloaded from here.
https://sketchucation.com/pluginstore?l ... category=0 See my portfolio at https://delphiscousin.blogspot.com/
Extrude Tools Yes you must first divided straight lines and recurve (weld (by Diggsey) & also Curves ![]()
Ah! Thanks! ![]() See my portfolio at https://delphiscousin.blogspot.com/
• Page 1 of 1
