[Plugin] Tools On Surface - v2.4a - 01 Nov 18
Re: [Plugin] Tools On Surface - v2.4a - 01 Nov 18
Postby reza1813 » Tue Feb 12, 2019 12:13 pm
Dear Fredo,
Thank you for your prompt reply to my question. Wow, I thought that adding curve line(Bezier) on Tool on surface plugin will be possible in SketchUp as MESH interface because this is just an example in order to show you what I mean and you obviously know that we usually need to add curve line on the curved surface(Like other Software: Rhino and...). Indeed, I ever use Drap(Feature in the SketchUp) or Flowify plugin(Anders L.) in order to put a pattern on my curved surface but most of the time it doesn't work properly or It does not look like what I am looking for.
All in all, I hope so in the near future, we have this feature on SketchUp. Thanks in advance.
Yours sincerely,
Hamidreza
reza1813
Postby Chumley » Sun Feb 17, 2019 2:16 pm
Hi there.
Do you have a link to download the Tools on Surface plugin? I tried on the main page but link doesn't work.
Thanks.
User avatar
Chumley
Postby TIG » Sun Feb 17, 2019 2:43 pm
You should always look in the Plugin Store for the latest versions of almost all toolsets...
See here...
https://sketchucation.com/pluginstore?p ... sOnSurface
Also remember to download and install the latest LibFredo...
https://sketchucation.com/pluginstore?pln=LibFredo6
After the installations, restart SketchUp to ensure everything gets synced...
User avatar
Global Moderator
Postby Caleb_Stanley » Fri Jun 28, 2019 3:48 pm
I am having issues upon the startup of SketchUp with ToolsOnSurface, I believe it may have something to do with the latest update but I am not sure. Below is the text of the error code upon starting.
ToolsOn Surface 2.4a: Error starting up plugin (creating menus and icons) invalid byte sequence in UTF-8 [in lib6config.rbe - #'===0: line 319]
c:/...'sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1058:in'rescue in block in effective_load_part2'
Please Help. Thank you.
Caleb_Stanley
Postby TIG » Sun Jun 30, 2019 6:52 pm
I'm sure that Fredo will respond with more details...
However, the error message you posted is incomplete - in fact it omits the vital parts.
Can you re-post the FULL message [including your ../users/user_name/ etc]...
Also please confirm that you have the latest LibFredo RBZ installed...
User avatar
Global Moderator
Postby fredo6 » Sun Jun 30, 2019 9:02 pm
Thanks, TIG, for your invaluable help.
I already answer in the other thread where the problem was also posted.
User avatar
PluginStore Author
PluginStore Author
Postby rv1974 » Tue Jul 02, 2019 11:35 am
Fredo could erroneous Arc behavior be fixed please?
rv1974
Postby jgb » Tue Jul 02, 2019 5:56 pm
I get that a lot too. Mentioned it numerous times in the past 8+ years and no improvement. Sometimes it works correctly, but I cannot define what works and what doesn't.
__________________
jgb
User avatar
jgb
Postby rv1974 » Tue Jul 02, 2019 8:34 pm
Yep it's present from day 1. The 'workaround' is not to start/end from the outer edges. Just a microscopic offset, then manually extend the arc Kinda helps in many (but not 100%) cases
rv1974
Postby fredo6 » Wed Jul 03, 2019 5:45 am
This is a fundamental flaw in the algorithm when you start from sharp borders.
So, not something simple to correct, versus revisiting seriously the algorithm itself.
User avatar
PluginStore Author
PluginStore Author
Postby jgb » Wed Jul 03, 2019 10:17 pm
What do you mean "sharp borders"?
__________________
jgb
User avatar
jgb
Postby fredo6 » Thu Jul 04, 2019 5:20 am
jgb wrote:What do you mean "sharp borders"?
Usual cases where you TOS algorithm has problem are those where the surface is a close shape and when you start from an edge which has a sharp angle.
User avatar
PluginStore Author
PluginStore Author
Postby mrswissmaster » Thu Mar 05, 2020 8:05 am
Is it possible to place image on curved surface?
mrswissmaster
Postby Dave R » Thu Mar 05, 2020 1:50 pm
Native tools can do that or you could look at Fredo's Thru Paint.
User avatar
Global Moderator
Postby keitheseymour » Mon Mar 09, 2020 9:52 am
I'm running Sketchup 2015, and have installed Fredo6: Tools On Surface v2.4a. I can see it installed in my extensions list, but it doesn't show up in the menus to use. Any ideas? Thanks in advance.
keitheseymour
Postby Box » Mon Mar 09, 2020 10:23 am
Did you install the Fredo Library that is required.
User avatar
Postby TIG » Mon Mar 09, 2020 12:27 pm
Fredo's tools appear under the Tools menu, did you look there ?
User avatar
Global Moderator
Postby stebbins » Mon Apr 27, 2020 9:09 pm
Hello, how may I avoid these diagonal lines that are produced when offsetting rectangles?
Thanks in advance,
stebbins
Postby fredo6 » Tue Apr 28, 2020 9:48 am
stebbins wrote:Hello, how may I avoid these diagonal lines that are produced when offsetting rectangles?
I would need to have the model, and also to understand how you used the OffsetOnSurface tool.
User avatar
PluginStore Author
PluginStore Author
Postby jgb » Wed Apr 29, 2020 7:00 pm
I take it that those roofs have the center raised a bit. The diagonal lines are the "hip" bends. Quite normal. You need to make then "soft" or hidden.
Three ways, either select the line and change its attribute in Entity Attributes; or
with the erase tool, press and hold "CTRL" and sweep over the line.
The third way is to create a layer and move those lines into it. Make that layer visible or invisible as needed.
__________________
jgb
User avatar
jgb
Postby j40 » Sun May 03, 2020 7:45 pm
Hi, great plugin! :thumb: I have an issue on SketchUp 2020 version (Mac), it's not appearing in none of menus.
on SU 2018 it's working perfectly though.
Any idea why it happens?
best regards
j40
Postby Dave R » Sun May 03, 2020 7:53 pm
It will show in Tools>Fredo6 Collection in SketchUp 2020. Have you restarted SketchUp after installing it?
User avatar
Global Moderator
Postby j40 » Sun May 03, 2020 8:25 pm
Dave R wrote:It will show in Tools>Fredo6 Collection in SketchUp 2020. Have you restarted SketchUp after installing it?
Yes, I have. No luck. As if nothing was added/installed. Very odd.
j40
Postby Dave R » Sun May 03, 2020 8:33 pm
How did you install it?
User avatar
Global Moderator
Postby j40 » Sun May 03, 2020 9:09 pm
Dave R wrote:How did you install it?
Via: Extension Manager>Install Extension>ToolsOnSurface_v2.4a.rbz
j40
Postby Dave R » Sun May 03, 2020 9:13 pm
Do you have the most current version of LibFredo6 installed, too?
User avatar
Global Moderator
Postby j40 » Sun May 03, 2020 9:41 pm
Dave R wrote:Do you have the most current version of LibFredo6 installed, too?
Indeed.
The same .rbz was successfully installed on SU 2018 though :?
j40
Postby TIG » Mon May 04, 2020 2:56 pm
Have you closed SketchUp, then restarted it to ensure everything is synced after the files/lib installation ?
User avatar
Global Moderator
Postby j40 » Tue May 05, 2020 2:45 pm
TIG wrote:Have you closed SketchUp, then restarted it to ensure everything is synced after the files/lib installation ?
Yes, I have. Also updated to the most recent SU update (20.1.228 OS X).
j40
Postby designerbursa » Wed Jul 01, 2020 9:46 am
When will your update arrive?
User avatar
designerbursa
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: aebgalmeida, arqcopt, DavidGil, gammatheta, Kravchuk Veronika, ValentinDuncombe, vanvu2903 and 14 guests
Visit our sponsors:
