SketchUcation Premium Membership
[Plugin] Roof.rb v1
[Plugin] Roof.rb v1
Postby TIG » Tue Nov 20, 2007 3:26 am
This is v1 of Roof.rb. It's new script I have created to make several types of roof from a selected face or face+edge.
In the zip file there are two files Roof.rb and RoofHelp.mht, put both of these into your SketchUp Plugins folder.
Read the help file for an overview...
Please try and feedback...
User avatar
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: Roof.rb v1
Postby TIG » Tue Nov 20, 2007 3:28 am
Some problems reported with the Help combined image and text file (mht) so here's a pdf if it, that you can open manually till I get a better handle on the problem...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Re: Roof.rb v1
Postby Edson » Tue Nov 20, 2007 4:05 am
hi, tig.
i have not tried your latest release yet but had a good look at the pdf. just felt like saying thanks to you for the invaluable contribution you have been doing to all of us. i use several of you other scripts and i am sure will soon use this.
best wishes.
edson mahfuz, architect
http://www.mahfuz.arq.br
Anyone can get you more for more, but it takes genius to get you more for less.
User avatar
Edson
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
Re: Roof.rb v1
Postby ilay7k » Tue Nov 20, 2007 4:06 am
TIG thanks for this tool!
Ilay
ilay7k
Re: Roof.rb v1
Postby TIG » Tue Nov 20, 2007 4:08 am
Here's v1.1, it's adjusted to resolve ratio (A:B) issues if a certain other script was not loaded (RickW's array_to.rb) - now the required array method is built into Roof.rb too...
Please replace the current version with this one.
At least that error report is fixed. Now for some other errors...
Edit: For new users: get the zip file - it also contains the help file that goes in the folder with the script. However, the help file in v1.1 is the same as v1.0 so you only need to get Roof.rb if you've downloaded it before...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Re: Roof.rb v1
Postby Jim Smith » Tue Nov 20, 2007 4:08 am
TIG, thsnk you for the roof tool. I can see where it will save quite a bit of time.
Jim
"Out of clutter find simplicity,
from discord find harmony,
In the middle of difficulty lies opportunity"
Albert Einstein
User avatar
Jim Smith
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Re: Roof.rb v1
Postby TIG » Tue Nov 20, 2007 4:10 am
Location: UK Here's v1.2. There's now a slight tolerance in checking if the face to make a gable or pyramid roof is rectangular. If the sides are out by less than ~0.2mm in 1000mm it'll still work. However, in that case you might get gables not lining perfectly with the block below.
The Roof.rb script attached is v1.2, The .zip file contains both this version of the script and the .mht help file that goes into the Plugins folder with it. You only need the help file reloading if you haven't had an earlier version of the script, since the help file is the same as in v1.0 and v1.1...
I hope this now addresses a few problems. Keep the feedback coming...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Re: Roof.rb v1
Postby digby dart » Tue Nov 20, 2007 4:11 am
I have only just downloaded this script and given it a quick test. It is a perfect addition to sketchup. :D
Thank you for your time, effort and generosity in making this roof script available.
[digby dart]
digby dart
Re: Roof.rb v1
Postby Iglesias » Tue Nov 20, 2007 4:12 am
Hello TIG,
This new script runs very well, congratulations. In my PC didn't run the older one.
Iglesias
Re: Roof.rb v1
Postby TIG » Tue Nov 20, 2007 4:15 am
Here's v1.3. It fixes some more problems: gable material glitches, spurious non-rectangular face error messages and second-gable overhang weirdness.
The Roof.rb script attached is v1.3, The .zip file contains both this version of the script and the .mht help file that goes into the Plugins folder with it. You only need the help file reloading if you haven't had an earlier version of the script, since the help file is the same as in v1.0 to v1.2...
I hope this now addresses many of your problems. But keep the feedback coming...
User avatar
Global Moderator
SketchUp version: 8
License type: Pro
Re: Roof.rb v1
Postby smitty97 » Wed Dec 12, 2007 10:44 pm
Awesome, I've only jsut discovered Sketchup and your script makes rofos a much simpler process.
Many thanks.
smitty97
Re: Roof.rb v1
Postby boofredlay » Wed Dec 12, 2007 11:15 pm
Smitty, here is V2.
User avatar
boofredlay
Global Moderator
SketchUp version: 8
License type: Pro
by Ad Machine » 5 minutes ago
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: nhocarc, simeonsphinx, TinyBabyGirl, unearthed and 7 guests
