[Plugin] Curvizard - v2.4b - 10 Feb 20
Re: [Plugin] Curvizard - v2.4a - 24 Feb 19
Postby Box » Mon Feb 03, 2020 5:35 pm
Thanks Fredo, a very timely fix as always.
User avatar
Postby fredo6 » Mon Feb 03, 2020 7:25 pm
Box wrote:Thanks Fredo, a very timely fix as always.
Thanks for signaling the problem. Strange that nobody complained before, as this comes from a bug in LibFredo6 v9.5c, released on 10 January.
User avatar
PluginStore Author
PluginStore Author
Postby AISmebel » Fri Feb 07, 2020 2:39 pm
Good afternoon. I had a problem while working with smooth_curve. What can I do to treat him?
https://youtu.be/FqebBna_dmE
AISmebel
Postby fredo6 » Fri Feb 07, 2020 11:47 pm
AISmebel wrote:Good afternoon. I had a problem while working with smooth_curve. What can I do to treat him?
There seems to be a bug there, but I cannot reproduce it.
Could you open the Ruby console to check if there are errors.
User avatar
PluginStore Author
PluginStore Author
Postby AISmebel » Mon Feb 10, 2020 8:53 am
Good afternoon. I hope that I did everything right.
In SketchUp 2018, I had no such problem.
I think that the problem arose due to the transfer of plugins to SketchUp 2020.
Removing Curvizard, LibFredo and installing it again did not solve the problem.
https://youtu.be/3-dOZ7bfvwY
AISmebel
Postby fredo6 » Mon Feb 10, 2020 10:20 am
@AISmebel
Could you make the test with the same model and configuration with this updated version of Curvizard.
EDIT: release as v2.4b on Sketchucation Extension Store.
Please leave the Ruby console open for potential error messages.
Many thanks
User avatar
PluginStore Author
PluginStore Author
Postby TIG » Mon Feb 10, 2020 12:58 pm
@AISmebel
How is your Plugins folder within the ProgramData folder-path ?
The user's Plugins folder in within that user's AppData/Roaming path...
I hope you haven't made it manually ??
Can you try this in the Ruby Console [copy+paste+enter]:
Sketchup.find_support_file('Plugins')
It should return something like:
C:/Users/YOURUSERNAME/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins
If you have not installed SketchUp properly sometimes folder permissions gets messed up...
Close SketchUp/Layout, find the SketchUp installer exe file's icon [probably in Downloads]
Select it, right-click > context-menu > "Run as administrator"
When prompted choose 'Repair'
This should sort out permissions and paths etc...
Any other way of installing - e.g. double-clicking the exe file to simply 'Run' it is NOT the same thing and can result in weird errors...
User avatar
Global Moderator
Postby AISmebel » Mon Feb 10, 2020 1:39 pm
Fredo, thank you very much for your help, everything worked for me. I was very pleased that you were able to help me so quickly.
Thank you for your plugins, they are very strong and very useful for many people.
 Take this opportunity to answer me another question =>
viewtopic.php?f=323&t=17948&p=657086#p657086
Thanks.
AISmebel
Re: [Plugin] Curvizard - v2.4b - 10 Feb 20
Postby fredo6 » Mon Feb 10, 2020 1:52 pm
NEW RELEASE: Curvizard v2.4b - 10 Feb 20
Curvizard 2.4b is for some bug fixing.
Requirement: LibFredo6 9.5 or above
See Home Page of Curvizard for information and Download.
See Main post of this Curvizard thread for discussion, bug reports and suggestions.
User avatar
PluginStore Author
PluginStore Author
Postby AISmebel » Mon Feb 10, 2020 3:08 pm
TIG wrote:@AISmebel
Hey.
I use the SketchUcationTool plugin. It helps me quickly and easily expose my plugins. But I noticed that it works correctly when the plugins are located at the address:
C: \ ProgramData \ SketchUp \ SketchUp 2018 \ SketchUp \ Plugins
Fredo fixed the bug. Perhaps it was not the location of the plugin.
AISmebel
Postby AISmebel » Wed Apr 29, 2020 3:32 pm
Good afternoon. I have a problem with Curviloft and Curvizard plugins.
Perhaps the problem arose after updating LibFredo6.
Reinstalling the plugins did not help.
Delivered an earlier version of LibFredo6, the problem is not fixed.
Here is the link to the video: https://youtu.be/H06P-Fcx0Go
AISmebel
Postby fredo6 » Wed Apr 29, 2020 4:15 pm
This is clearly a bug, and present since v10.0. Thanks for catching.
Could you try on the same model with LibFredo6 v10.3a, just published.
Many thanks
User avatar
PluginStore Author
PluginStore Author
Postby AISmebel » Wed Apr 29, 2020 4:46 pm
Fredo you are a magician !!! :)))
It was not me who caught the error, but rather she me;))
I work in SketchUp and the slightest mistake in plugins makes my work uncomfortable. So thank you very much again!
The second time I turned to you with a problem, and the second time we pleased me with its speed of solving it.
P.S. The new version of LibFredo6_v10.3a fixed everything. So far, I do not see any errors.
AISmebel
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: cbjb, dam doan nhat duy, Google Bot, uzan13 and 13 guests
Visit our sponsors:
