[Plugin] RotaScale
• Page 2 of 2 • 1, 2
Re: [Plugin] RotaScale (0.3.3b) — 11 June 2009hey thom thom, looking at this script i see uve put standard rotate, as a extra when holding control u get standard rotate, any way we could get linear scaling when holding alt?
Re: [Plugin] RotaScale (0.3.3b) — 11 June 2009I'd think so. Just need to find a spare moment.
Re: [Plugin] RotaScale (0.3.3b) — 11 June 2009Can I suggest an update to this plugin? Wouldn't be more useful to have the "Move" function too added to Scale and Rotate? This can be done with 4 clicks instead of 3. First two to pick the "source" vector, and two more to say where to put the "target".
One can always reproduce the current behaviour, by clicking on the same point for the first and third click. And, as a final enhancement, it would make a Copy, if the Ctrl key is pressed. Re: [Plugin] RotaScale (0.3.3b) — 11 June 2009
I've had the same thoughts - will add it to my To-Do list. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] RotaScale (0.3.3b) — 11 June 2009And a random function of a selection? Rotate + Scale
Edit In fact exist in a certain way by Chris Fullmer Scale Rotate Multiple ![]()
Re: [Plugin] RotaScaleThanks for it!
I'd add "clone" (copy) feature to TODO list ![]() Re: [Plugin] RotaScaleHi!
It would be very useful to have ESC button to undo reference point selection. For example: I picked first refpoint but I want to change it without leaving the tool, then I press ESC and I can pick it again. The same with second and third refpoint. Re: [Plugin] RotaScaleI just discovered this gem.. It would be also nicer with a toolbar button!
Edit: nevermind, I managed to do it myself, using the toolbar editor plugin. ![]()
Who is online
Users browsing this forum: Asamaleo, Dung112, gardaady, Google Bot, hapipo1103, Maninb and 13 guests
