How do I Construct this shape?
General discussion related to SketchUp Pro and Make
Postby davewong » Tue Jan 21, 2020 10:09 pm
HI All,
May I know if anyone knows how to construct this shape and maybe give me a guide on how to construct it?
It seems easy but I really can't figure out how to achieve this shape. Since the bottom isn't round, it's hard to just draw half and follow me it.
Anyone?
davewong
Re: How do I Construct this shape?
Postby Dave R » Tue Jan 21, 2020 10:35 pm
Something like this:
Edges for profiles shown selected. I copied the profiles to give me a better idea of the overall shape. Curviloft to create the skin on the left. Copy and flip the skin to make the other three sections. Explode the resulting groups and soften the edges.
User avatar
Global Moderator
Postby pilou » Tue Jan 21, 2020 11:58 pm
Or the same with extrude Tool by Tig...
Speedy Galerie
User avatar
Top SketchUcator
Postby davewong » Wed Jan 22, 2020 9:38 am
Dave R wrote:Something like this:
I will try now. But will it be possible to be made into a Solid? As I want to 3d-print it later...
davewong
Postby davewong » Wed Jan 22, 2020 9:39 am
pilou wrote:Or the same with extrude Tool by Tig...
BUt how do I draw the lines? :(
davewong
Postby davewong » Wed Jan 22, 2020 9:52 am
Hi Sorry, may I have a step by step on how to achieve it? I downloaded Curviloft but I am so lost as to how to create the lines to even start using Curviloft to do anything :(
davewong
Postby pilou » Wed Jan 22, 2020 9:53 am
Solid...As I want to 3d-print it later...
Just select the Surface and Use Joint PushPull by Fredo!
look all the tutorial (but your case is 8.42... minutes )
Speedy Galerie
User avatar
Top SketchUcator
Postby davewong » Wed Jan 22, 2020 10:10 am
I am still very very stuck...
How do I create the lines to even do an extrude? :(
davewong
Postby pilou » Wed Jan 22, 2020 10:49 am
With the method of the Extrude Tools By Tig
Bezier Splines
Trick is drawing curves on a rectangular surface (here the image) or a simple rectangle then erase the unwanted...or like follow a Copy / Move! ;)
you can use only 3 curves (so make 2 clicks on the second curve - here it's 4 curves)
Extrude Tools
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Wed Jan 22, 2020 11:38 am
So after the JPP for thickness etc...
Maybe base must be trimed depending of what do you want...
Speedy Galerie
User avatar
Top SketchUcator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: No registered users and 6 guests
Visit our sponsors:
