set_attribute problem
Postby Pixero » Thu Jan 16, 2020 11:56 am
I'm getting an attribute from a component this way:
Code: Select all
@myid = e.definition.get_attribute("A", "Id")
If I do a:
Code: Select all
puts @myid
I get the correct value.
Something like this: 0481e69d-cbc0-4e4c-2c32-e2d2f7932bdf
And setting it this way:
Code: Select all
e.definition.set_attribute("A", "Id", @myid)
or
Code: Select all
e.definition.set_attribute("A", "Id", @myid.to_s)
But all I get is nil.
What am I doing wrong?
User avatar
Pixero
Re: set_attribute problem
Postby TIG » Thu Jan 16, 2020 1:28 pm
If you use this code in your script, then what do you see in the Ruby Console when it runs ?
Code: Select all
puts"{@myid}"; e.definition.set_attribute("A", "Id", @myid)
Remember that @myid will probably not be accessible in the Console, as I suspect that it's being set within your own method ??
User avatar
Global Moderator
Postby Pixero » Thu Jan 16, 2020 1:32 pm
Then I get:
Code: Select all
{@myid}
I'm doing it inside a:
Code: Select all
sel.each {|e|
  puts"{@myid}";
Edit:
Doh! :oops: It was all a small typo with a D instead of a d.
Works as it should now.
User avatar
Pixero
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Developers' Forum
Who is online
Users browsing this forum: moiari53 and 6 guests
Visit our sponsors:
