[Plugin] Projecting Floor Paintings
Postby plot-paris » Tue Apr 05, 2011 11:56 am
Hello everyone,
have been absent for quite some time now. just too much to do. but now I've got a problem, that might be solved by a nice little ruby script:
Do you know these painters, drawing a painting on the floor in a pedestrian area? Some of these paintings use a fantastic trick, so that if you stand at one specific point you will see a hole in the ground or similar. They do it via perspective distortion.
To create such a painting in SketchUp all I have to do is create the scene, then define one camera point in space. Then I have to draw lines from this camera point to all the visible vertexes and continue these line until they hit the ground floor. And finally all I have to do is connect these new intersection points on the ground.
If I look thorugh the camera now, I will see a 3D object, that is actually painted on a flat floor.
(by the way: there is a new "Film and Stage" plugin for SketchUp 8 )
Unfortunately I need to do that for quite a few scenes. And I figured this might be something that can be done via Ruby (I know there is the Projection ruby. But it doesn't do projections from one single point, only parallel...)
I need to do the project over the weekend. So time is short :?
Any help would be highly appreciated!
User avatar
plot-paris
Re: [Request] Projecting floor Paintings
Postby mitcorb » Tue Apr 05, 2011 2:01 pm
Hi, plot-paris:
Nice to see you back.
I thought perhaps you could do a Forum wide search on "camera", but then I saw that there were only 307 pages on this search topic. However, what you describe does bring up thoughts of discussions within the last 6 months, it seems, on related topics.
User avatar
mitcorb
Top SketchUcator
Re: [Plugin] Projecting floor Paintings
Postby TIG » Tue Apr 05, 2011 5:11 pm
Try this
projecteye2ground.rb
Select raw geometry [i.e. including the edges to project] and type projecteye2ground into the Ruby Console, and the vertices are projected onto the ground plane from the eye, with cpoints and clines reproducing the distorted form...
User avatar
Global Moderator
Postby mitcorb » Tue Apr 05, 2011 7:33 pm
In lieu of all that exhaustive searching, we have the resident problem solver to present the solution. Well done, TIG. :thumb: :thumb:
User avatar
mitcorb
Top SketchUcator
Postby plot-paris » Tue Apr 05, 2011 10:28 pm
wow, TIG! Did you just write that? thats almost perfect! wonderful! you just made my day!!! :sketchstatic:
User avatar
plot-paris
Postby Dave R » Wed Apr 06, 2011 3:17 am
TIG, that's pretty slick.
User avatar
Global Moderator
Re: [Plugin] Projecting Floor Paintings
Postby elthanos » Mon Jan 21, 2013 5:14 pm
Very good TIG!!! Could it project on other objects too or only on ground floor?
elthanos
Postby RPNZ » Tue Nov 05, 2013 9:34 pm
Hey TIG, this is all great information,
is there a way of projecting on the ground and onto a vertical surface ? ie onto a street and onto a building across the street? So the "object is projected on the flat and vertical surfaces in the same drawing?
thanks..
RPNZ
Postby mikedd » Sun Nov 10, 2013 3:06 am
Julian Beever is probably the most famous. http://www.julianbeever.net/index.php?o ... 1&Itemid=1
Here is a basic tutorial http://www.instructables.com/id/3D-Anam ... treet-Art/
With Photoshop http://www.instructables.com/id/Anamorp ... Photoshop/
mikedd
Postby mikedd » Mon Nov 11, 2013 2:01 am
Heres mine: Nancy with a basketball, in scene 1 the ball looks normal. In scene 2 you can clearly see how the ball is flat and distorted by using the scale tool and how long the anamorphic images have to be to get the desired effect.
mikedd
Postby pilou » Mon Nov 11, 2013 2:33 am
Speedy Galerie
User avatar
Top SketchUcator
Postby robertWan » Sun Jan 12, 2020 2:03 am
How to place the camera in the designated place (x, y, z)?
Google Translator
Robert
User avatar
robertWan
Postby TIG » Sun Jan 12, 2020 2:45 pm
robertWan wrote:How to place the camera in the designated place (x, y, z)?
Code: Select all
eye = [1000,1000,1000]
target = [0,0,0]
up = [0,0,1]
my_camera = Sketchup::Camera.new(eye, target, up)
Sketchup.active_model.active_view.camera = my_camera
Vary the eye and target as desired...
User avatar
Global Moderator
Postby Didier Bur » Sun Jan 12, 2020 6:59 pm
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
User avatar
Didier Bur
Postby robertWan » Sun Jan 12, 2020 7:08 pm
Didier Bur wrote:@RPNZ:
Try my Projections extension
I have SU8 and I see that I need 2016.
TIG wrote:Vary the eye and target as desired...
It works! Thank you.
The shadows can be easily redrawn by hand.
Robert
User avatar
robertWan
Postby Didier Bur » Tue Jan 21, 2020 8:51 pm
Didier Bur
User avatar
Didier Bur
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: No registered users and 15 guests
Visit our sponsors:
