[Plugin] Universal Importer - v1.1.9 - 17 Aug. 2022
@ahmed0007 said:
@samuel_t said:
@ahmed0007 said:
i import this model with v1.0.1 without any problem but v1.0.6 give me this error why?
please help.In recent versions of plugin there's a mechanism that prevents copy of a too big folder. To fix this issue: Create a sub folder in your Documents then place model and textures inside that sub folder. Re-import.
Still Same error ?
What's size of model in MB?
@samuel_t said:
@ahmed0007 said:
Still Same error ?
8 mb
@ahmed0007 said:
@samuel_t said:
@ahmed0007 said:
Still Same error ?
8 mb
OK. Could you please post a screen capture of folder containing model (aka a Windows Explorer view)?
Now i'm also unable to import this model again
Youtube Videofile type .obj
size 110 mb
located in Documents folder \Documents\obj 2 -
@samuel_t said:
@ahmed0007 said:
@samuel_t said:
@ahmed0007 said:
Still Same error ?
8 mb
C:\Users\Ahmed\Documents\New folder (2)
@ahmed0007 said:
@samuel_t said:
@ahmed0007 said:
@samuel_t said:
@ahmed0007 said:
Still Same error ?
8 mb
Everything seems OK. I don't understand why you can't import... There are no hidden files, isn't?
Everything seems OK. I don't understand why you can't import... There are no hidden files, isn't?[/quote]
did you try this on your own pc
No! There are no hidden files
i think i should stick with older version. -
i think i should stick with older version.Yes. I tried to import a model with this path: "C:\Users\Samuel\Documents\New folder (2)" and it's OK.
Could you please upload your model to a file hoster? This way I can verify if the model is the problem.
i uplode the model in my first comment
size 110 mb
located in Documents folder \Documents\obj 2OK. I'm gonna release a hotfixed version.
i tried on another pc and get this error
and on one another file get "model is too big error" model size was 11mb
1.0.7 version fixes "anti big copy" bug.
Download latest Universal Importer plugin from SketchUcation PluginStore.
and on one another file get "model is too big error" model size was 11mbReinstall Microsoft Visual C++ library on this another computer then upgrade to v1.0.7 of plugin.
WoW
Everything is working fine again
Thank you Sooo Much!!! -
@samuel_t said:
@einstein said:
Hi!
I downloaded the latest update but I'm still getting the same bug with every file format. I cannot import any file to SketchUp
Hi!
Could you please upload your model (textures included) to a file hoster or here? So I could debug it.
I'm attaching one of the models I was trying to import (it's a free model from TurboSquid). But I also tried to import a model that was posted earlier in this thread. None of them worked, even with v1.0.7 - the same bug report.
If I don't want textures when it asks me about them, shall I just press "Cancel"?
I believe if your model has yet Textures even you cancel, you will have original textures !
If it's just "colored" it will keep its colors... -
@einstein said:
@samuel_t said:
@einstein said:
Hi!
Hi!
I can import model you attached in my computer. (There's still issue with leaves. SketchUp import bugs sometimes. If you don't want textures: it's OK.) So, problem comes most problably from your computer.
Reinstall Microsoft Visual C++ library then reimport model. Please let me know if problem persists.
I you don't want textures: you can remove textures after import by using Materials Tray in SketchUp.
Your file works fine for me too!
Import without Texture and reduce to 500 faces!
as I did'nt ask statistics maybe your file had less 500 faces!
Edit asked : so...original was 81 000 faces!
hum hum 50 000 faces after the decimate reduction to 500 faces asked ?
there is not something curious ?
