Fredo6 BezierSpline_v2.1a Having Trouble
Postby Bluewater77 » Tue Jan 07, 2020 4:47 pm
Hello, I installed this and having some issues. I have SKP 2018 Pro. Maybe I am not using properly as I am not advanced user and Bezier spline novice.
When I choose Polyline with Arc Corners and start to draw. Two things... 1st is that no menu window for offset pops up. 2nd is that when I start to draw, it disappears when trying to set points. So I can't see the polyline that I am trying to draw? Advice appreciated!
Bluewater77
Re: Fredo6 BezierSpline_v2.1a Having Trouble
Postby fredo6 » Tue Jan 07, 2020 5:09 pm
Bluewater77 wrote:Hello, I installed this and having some issues. I have SKP 2018 Pro. Maybe I am not using properly as I am not advanced user and Bezier spline novice.
Could you open the Ruby Console and see if there are errors showing.
User avatar
PluginStore Author
PluginStore Author
Postby Bluewater77 » Tue Jan 07, 2020 5:34 pm
Thanks Fredo6. Nothing shows in Ruby Console. I tried drawing a Polyline with Arc Corners and it dissapears after selecting point #1. I click for point 2 & 3 (eventhough I can't see and choose to end and close tool) Then there is nothing on my screen?? And Ruby Console is blank
Bluewater77
Postby fredo6 » Tue Jan 07, 2020 11:18 pm
Do you get the same problem with other curves, like Bezier, Cubic Spline, Polyline, ....?
User avatar
PluginStore Author
PluginStore Author
Postby Bluewater77 » Sat Jan 11, 2020 1:59 pm
Sorry Fredo6 for late response. Not getting reply notifications... It happens i.e. after 1st click, everything disappears.
on all except for classic bezier, polyline, catmull, courbette, cubic bezier, F-spline.
Bluewater77
Postby fredo6 » Sat Jan 11, 2020 4:08 pm
In a last resort, could you clean up the plugin directory for everything starting with bezierspline_ and BZ_ (file and folders), and then reinstall the latest version from the Sketchucation ExtensionStore...
User avatar
PluginStore Author
PluginStore Author
Postby Bluewater77 » Sun Jan 12, 2020 1:47 pm
I uninstalled the extension then reinstalled it before. I will try what you suggested. Thanks
Bluewater77
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: abdillahnunu, Anono1510, aryadey1978, kaiohon, lichtstudio, sandromcaf and 16 guests
Visit our sponsors:
