[Plugin] Random Entity Generator - v1.1.8 - 02 Jan. 2020
Re: [Plugin] Random Entity Generator - v1.1.8 - 02 Jan. 2020
Postby samuel_t » Thu Jan 02, 2020 8:32 pm
1.1.8 version memorizes user settings.
Download latest Random Entity Generator plugin from the SketchUcation PluginStore.
User avatar
samuel_t
Postby Oxer » Mon Jan 13, 2020 8:33 pm
Spanish Language FIle
es.zip
User avatar
Oxer
Postby samuel_t » Mon Jan 13, 2020 8:47 pm
Oxer wrote:Spanish Language FIle
es.zip
Thank you!
User avatar
samuel_t
Postby Kruegen » Thu Mar 19, 2020 5:47 pm
This extension is amazing! I use this all the time in our workflow we have for quickly dispersing trees along terrain. I am having a lot of trouble getting the "Set Random Zone from Image..." function to work. I can select the image, and type in the parameters for centimeters per pixel, etc. but once i select OK the following error message pops up:
Error: undefined method 'unpack' for nil:NilClass
Is there any way you could help me with this? This extension is amazing, and the function of Set Random Zone from Image would be a giant help to our team. Thanks Samuel!
Kruegen
Postby samuel_t » Sat Mar 21, 2020 10:24 am
Kruegen wrote:This extension is amazing! I use this all the time in our workflow we have for quickly dispersing trees along terrain. I am having a lot of trouble getting the "Set Random Zone from Image..." function to work. I can select the image, and type in the parameters for centimeters per pixel, etc. but once i select OK the following error message pops up:
This extension is only compatible with 24-bit BMP images. So be sure to select a 24-bit BMP image...
User avatar
samuel_t
Postby Kruegen » Mon Mar 23, 2020 8:02 pm
Thanks! that solved my issue
Kruegen
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: Alusya98, Archunet, Ericson2020, GabrielLang, lucianinski and 15 guests
Visit our sponsors:
