[Request] Edge loop Selection
• Page 1 of 1
[Request] Edge loop SelectionHi there,
Does anyone know if there is a plugin that will allow me to select edges that loop around the model? Thanks! _KN 1 - select one edge 2-apply plugin and the edge loop is selected Last edited by ken28875 on Mon Mar 15, 2010 11:43 pm, edited 1 time in total.
Follow Your Dreams.
Re: [Request] Edge loop delectionI think thomthom's select toy script has something like this...
Re: [Request] Edge loop delectionMan, I've been wanting this like forever. And, based on your examples, it would not seem to be hard to do. But, in the case of your illustrations, which are very regular and isolated in the model space, what I do is navigate to a position where I can do a selection box around one of the loops as you show.
I suggested this in a post about a year ago, and I believe it was deemed too complicated, or required hacking the core program, or whatever. As you may know, other programs such as Blender, Maya have this capability. But these programs are based on a different modeling philosophy. Whereas, SU is a surface modeler, these others are solid, or box modelers and they treat vertexes as operable entities, meaning you can copy, move, highlight, extrude them as you would edges and faces. I don't know if the vertex thing has anything to do the limitation. I just thought I would throw that in. I take the slow, deliberate approach in my aimless wandering.
Re: [Request] Edge loop delectionTIG:
Last time I looked, ThomThom's Selection Toys only selected face loops, that is loops composed of faces, not loops composed of edges. I do think his tools will select edge loops totally contained within a face. Anyway, a girding edge loop would allow quick selection and you could scale it, move it copy it and so forth. Soon as somebody figures it out, the next step would be loop subdivide like Blender has. By the way, would the topic title need to be edited? From "delection" to "selection"? I take the slow, deliberate approach in my aimless wandering.
Re: [Request] Edge loop delectionI've seen this request a number of time - but I wonder do people have such clean geometry that it actually works. These other 3D apps to which people refer to usually allow for non-coplanar quads. While SU doesn't do this - significantly decreasing the usability for such a selection feature. The geometry need to be regular in its construction in order to determine the direction of the next edge to select.
Re: [Request] Edge loop SelectionProbably a gross over-simplification, but can't you grab the next connected edge whose angle between the current edge is less than a specified angle?
As you say, regular geometry is required. It would not work so well on sub-divided mesh. Hi
Re: [Request] Edge loop SelectionHi TIG,
You're correct, "ThomThom's Selection Toys only selected face loops, that is loops composed of faces". Hopefully someone will manage to figure out a script for that plugin. Thanks, _KN Follow Your Dreams.
Oops, I meant to reply to mitcorb, not TIG. ![]() Follow Your Dreams.
Re: [Request] Edge loop SelectionIt's pretty easy to switch to wire-frame or Xray mode and position your camera to view 'side on' and then use select by fence with left-right drag so only things that are wholly inside the fence get picked [as opposed to right-left drag fence making which selects everything that has just a part of itself inside the fence]
Voila! you have the loops edges selected in 'one foul swoop'. If you do select something that's not wanted then remove it from the selection-set by holding down shift+ctrl and re-picking it... ![]() ![]() TIG
Re: [Request] Edge loop SelectionFredo's Hover Select has an option to "Extend selection to cofacial and aligned edges". It works to do a loop select on clean quads. Another option would be a script that I think Jim or TIG helped me with a while back called Select Edges by Z. You can pick an edge and run the script and it will pick all other edges on that Z coordinate.
Guide Tool at Winning With Sketchup Content Creator at Skapeup
Hi TIG, Yes, that's a method I use sometimes, but it works on simple shape like the example I showed or on model with a few details. I was hoping for a plugin that will quickly help select edge loops on complex models. Thanks though. Have a great day! ![]() _KN Follow Your Dreams.
Hey Adam, Thanks for the tips. I tried it but did not work so well as my model is quite complex and has lots of details. Take care, _KN Follow Your Dreams.
Re: [Request] Edge loop SelectionI know this is an old post to bump, but in case someone finds it my new plugin was written to do this exactly:
viewtopic.php?f=323&t=61884
Thanks for the extension that you have included. would it be possible to tweak it to just include "connected edges"? Re: [Request] Edge loop SelectionAny one know what plugin is it from this video https://www.youtube.com/watch?v=bA4tGgOFQJQ&t=553s It's great for selecting edges in a loop.
Re: [Request] Edge loop SelectionSketchUV and Profile Builder have this tool
There's a frontroom and a backroom....reverse faces
Brilliant!, I have quad tools 'select' set on a shortcut. Just right click on the line and select 'selection'-> 'select loop'. Many thanks, cengizileten Many thanks
Bruce SKUP PRO 2020 Windows 10 Pro Dell Alienware Aurora R10 AMD AMD Ryzen™ 9 3900X NVIDIA® GeForce RTX™ 2080 Ti 11GB GDDR6
Re: [Request] Edge loop SelectionI´m a bit late to the party, but... While Twilight render has other main purpose, looks like in the Pro version it has tools that allows to select edge loops: https://www.twilightrender.com/index.ph ... ials-tools
Hope that helps.
• Page 1 of 1
