Component Axes
Component Axes
Postby honkinberry » Tue Sep 10, 2019 10:59 pm
When I create a component via .add_group and then .to_component, the component axes are set to the lower left extremities. Meanwhile, making a component via the Edit menu, I can specify the Component Axes in the dialog.
How can I set or move the component axes when I create the definition via Ruby?
Many thanks for any assistance!
--J
honkinberry
Re: Component Axes
Postby Dan Rathbun » Fri Sep 13, 2019 7:42 am
FYI, You can change the insertion point insertion_point=.
You can also apply a transform to the entire entities of the definition ...
Code: Select all
ctr = cdef.bounds.center # Center of untransformed bounds
# Arrays are compatible with translational transformations:
xform = [ctr.x, ctr.y, 0].vector_to(ORIGIN)
cdef_ents = cdef.entities
# Move all the entities so that the axis is in the bottom center:
cdef_ents.transfrom_entities(xform, cdef_ents.to_a)
    I'm not here much anymore. But a PM will fire email notifications.
    User avatar
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Re: Component Axes
    Postby honkinberry » Tue Sep 17, 2019 5:32 pm
    Boom! That worked!
    Thank you sir!
    --J
    honkinberry
    by Ad Machine » 5 minutes ago
    Ad Machine
    Robot
    Return to Developers' Forum
    Who is online
    Users browsing this forum: annguyen15c, Google Bot and 12 guests
    Visit our sponsors:
