CompoSpray is back [version 2.0.0]
Postby Didier Bur » Tue Jul 23, 2019 4:08 pm
Hi all,
I've updated my old plugin CompoSpray which is now live at the EW here:
https://extensions.sketchup.com/en/content/compospray
Faster, better, more reliable than before, compatible with SU2016 and higher, 14 different ways of spraying components.
Enjoy ;)
11
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
User avatar
Didier Bur
Re: CompoSpray is back [version 2.0.0]
Postby juju » Tue Jul 23, 2019 8:33 pm
Great work Didier, thank you!
User avatar
juju
Premium Member
Premium Member
Postby jenujacob » Thu Jul 25, 2019 1:01 pm
Thank you very much Sir Didier Bur!
User avatar
jenujacob
Postby srx » Thu Jul 25, 2019 2:47 pm
Thank you Mr. Bur. :thumb: I am glad you on the road again.
I noticed there is still an old bug with populating selected face - part of it is not populated, as it was masked, or something...
Also when try to populate grass, I need to do it 5-6 times to reach the desired density. Would be nice to have pressure up to 1000%. Why not?
www.saurus.rs
User avatar
srx
Postby db11 » Thu Jul 25, 2019 4:23 pm
With all of the discussion lately about sages and pros dropping off the SU map, it's great to see you back in the saddle and producing/updating plugins.
Your (renewed) contributions are much appreciated!
db11
Postby pbacot » Thu Jul 25, 2019 5:19 pm
Thank you very much!
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
User avatar
Top SketchUcator
Postby HornOxx » Thu Jul 25, 2019 8:19 pm
Prima & 1000x Danke !! :)
never trust a skinny cook
User avatar
HornOxx
Postby pilou » Fri Jul 26, 2019 12:05 am
Always innovative! :fro:
Speedy Galerie
User avatar
Top SketchUcator
Postby chon » Fri Sep 13, 2019 8:42 am
Hello all,
Thanks Didier for this update.
I've got an issue :
The plugin works fine when i install it in the C:\Users\XX\AppData\Roaming\SketchUp\SketchUp 2019\SketchUp\Plugins folder, but it doesn't work when i install it in my Fredo6's AdditionalPluginFolder.
If someone has an idea...
Many thanks for response.
User avatar
chon
Postby Didier Bur » Fri Sep 13, 2019 10:38 am
Hi all,
The path to the plugin is hard-coded in the script. So if you locate the plugin elsewhere than C:\Users\XX\AppData\Roaming\SketchUp\SketchUp 2019\SketchUp\Plugins\DBUR_Compo_Spray, it will not work.
Sorry for the inconvenience, but what's the reason you want to install it with Fredo Tools ?
Didier Bur
User avatar
Didier Bur
Postby chon » Mon Sep 16, 2019 8:20 am
Tanks for response
Didier Bur wrote:Sorry for the inconvenience, but what's the reason you want to install it with Fredo Tools ?
The Fredo6's AdditionalPluginFolder is a small standalone script providing the capability to define one or several additional user-defined directories to load plugins in Sketchup.
We use 4 licences of SU and it is really interesting to centralize all plugins in 1 place for updates or installations on the 4 machines at the same time.
Edit : Compospray 1.4.2 was working fine with AdditionalPluginFolder after some corrections by TIG.
User avatar
chon
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: Bing [Bot], ffffffaisal, maria adorno, pablopcb, silfax and 23 guests
Visit our sponsors:
