[Plugin][$] FredoGhost - v1.8a - 27 Jan 21
Postby fredo6 » Wed Jun 05, 2019 8:23 pm
The information on FredoGhost is maintained on the Plugin Home Page of FredoGhost. This is also where you can download the RBZ file.
REQUIREMENTS:
  • LibFredo6: v11.6a or above
  • Sketchucation ExtensionStore: v4.0.0.e or above
  • Usage: Licensed under Sketchucation SCFLicense
    • Free Trial period (full features): 15 days from activation
    • Perpetual license (3 seats): 17 €
    • Rush license (3 seats, valid 21 days from purchase date): 5 €
If you land on this page and are unfamiliar with how to install Sketchup Extensions such as LibFredo6 or how to register on Sketchucation, please watch this video or refer to the Plugin page of LibFredo6.
Credit: all toolbar icons and button images by JClements
FredoGhost is a Proxy framework for SketchUp. By ‘proxy framework’, I mean the capability to temporarily replace an object by another one, the proxy, and switch back and forth between the original version and the proxy version.
In FredoGhost:
  • A Proxy is called a Ghost, and the original object is called a Real.
  • FredoGhost operates on Components and Groups, called generically Objects.
FredoGhost can be used for 2 main purposes:
  1. Combine different rendering styles in the same view, for instance, some objects in X-Ray, while others staying natural (like in my old plugin XRaySelection). FredoGhost gives you control of the style and of the objects you want to modify.
  2. Make your model lighter to work with, since you can substitute proxies with lighter geometry (including just its bounding box) to replace complex objects. You have some methods to help in that, in particular the 'Proxy' method and the concept of frozen ghosts.
FredoGhost allows to select the objects you want to ghost and to convert them individually to their Ghost and Real versions. The ghost methods provided can be parameterized at will. It can also associate a particular ghosting state to a Scene, which can be useful both for individual rendering and a faster working environment.
Most features can be accessed from the FredGhost Studio dialog box, either in basic features or advanced features
IMPORTANT: For a period, it is advised to make a safe copy of your model, as there might be bugslats or other issues. This will ensure that you keep the main objects of your model in their real form.
Overview of FredoGhost
FredoGhost - User Manual - English - v1.2 - 03 Jun 2019 - Overview.pdf
More details about the Ghost Methods
FredoGhost - User Manual - English - v1.2 - 03 Jun 2019 - Ghost Methods.pdf
Just drop the attached PDF file into the SU Plugins directory to have it accessible from within Sketchup.
0) A quick introduction to FredoGhost main features (no sound)
Tutorial 1: Basic operations in FredoGhost
Tutorial 2: Ghost Method Editor
Tutorial 3: Scene Capture
Tutorial 4: Layout Compatibility mode
Tutorial 5: Advanced Features - Working with Components
Tutorial 6: Advanced Features - Frozen Ghosts
Tutorial 7: Advanced Features - Sensitivity to Distance
Tutorial 8: Advanced Features - Ghost Configurations
Tutorial 9: Under the hood...
6
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] FredoGhost - v1.2a - 07 Jun 19
Postby rv1974 » Wed Jun 05, 2019 9:21 pm
Amazingly helpful improvements, 1000 thanks!
rv1974
Postby juju » Wed Jun 05, 2019 10:02 pm
looks useful, can't wait, thanks!
User avatar
juju
Premium Member
Premium Member
Postby kenancakir » Thu Jun 06, 2019 10:27 am
Thank you, it will be a must have plugin for presentations..
kenancakir
Postby cotty » Thu Jun 06, 2019 7:37 pm
Great addition to the superb Fredo collection!
User avatar
cotty
Top SketchUcator
Postby Ahmed0007 » Sat Jun 08, 2019 5:42 am
Thank you Fredo6 <3
Ahmed0007
Re: [Plugin] FredoGhost - v1.2b - 18 Jul 19
Postby fredo6 » Thu Jul 18, 2019 9:11 am
NEW RELEASE: FredoGhost v1.2b - 18 Jul 19
Requirement: LibFredo6 8.9
FredoGhost 1.2b extends validity.
Home Page of FredoGhost for information and Download.
Main post of this FredoGhost thread.
User avatar
PluginStore Author
PluginStore Author
Postby JQL » Sat Aug 24, 2019 12:50 am
Just came across this Fredo. Amazing stuff!
I'm on vacations so will be difficult for me to try it, but one question came to mind: what happens if I convert a component to a ghost and then purge the model. will the original component be purged?
User avatar
JQL
Premium Member
Premium Member
Postby fredo6 » Sat Aug 24, 2019 9:07 am
JQL wrote:what happens if I convert a component to a ghost and then purge the model. will the original component be purged?
FredoGhost keeps a copy of the original definition, for Components and Groups, in a safe, hidden place, called the Capsule. So the component definitions will not be purged (and as a result, your components would still be visible in the Component browser).
User avatar
PluginStore Author
PluginStore Author
Postby JQL » Thu Aug 29, 2019 12:24 am
That capsule is a great concept. You always have things covered! I will try this one, as well as portrait, in September, both hold much promise if used right.
User avatar
JQL
Premium Member
Premium Member
Postby ttz4 » Wed Sep 04, 2019 2:09 pm
Hello Fredo. Is it possible to make "Bounding Box" witch is copying the structure of the original 3D model? I want to see the contours of the model with all the bends and not just the box at the highest points. I attached some metal structure as an example.
ttz4
Postby fredo6 » Wed Sep 04, 2019 10:21 pm
ttz4 wrote:Hello Fredo. Is it possible to make "Bounding Box" witch is copying the structure of the original 3D model? I want to see the contours of the model with all the bends and not just the box at the highest points. I attached some metal structure as an example.
Does the method "Bounding box by sub-object" work for you?
User avatar
PluginStore Author
PluginStore Author
Postby ttz4 » Thu Sep 05, 2019 1:42 pm
Not realy. "Bounding box by sub-object" makes objects like in picture №1. But I am wondering, if it possible to make proxy object like in picture №2?
ttz4
Postby fredo6 » Thu Sep 05, 2019 11:55 pm
ttz4 wrote:But I am wondering, if it possible to make proxy object like in picture №2?
Not really, as this is an interpretation of the geometry, not a combination of bounding boxes. You would have to construct it yourself and make it a proxy.
Anyway, if you can post the model, it would help.
User avatar
PluginStore Author
PluginStore Author
Postby ttz4 » Fri Sep 06, 2019 5:59 am
Here is the model. I exported it from .nwd–>.fbx–>.skp. I have a lot of steel frames that need to be proxied. Now I'm finding the way, how I can do it faster than to rebuild all the frames myself.
ttz4
Re: [Plugin] FredoGhost - v1.3a - 19 Oct 19
Postby fredo6 » Sun Oct 20, 2019 12:10 am
NEW RELEASE: FredoGhost v1.3a - 19 Oct 19
FredoGhost 1.3a extends validity.
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] FredoGhost - v1.3b - 22 Jan 20
Postby fredo6 » Wed Jan 22, 2020 8:22 am
NEW RELEASE: FredoGhost v1.3b - 22 Jan 20
FredoGhost 1.3b extends validity.
User avatar
PluginStore Author
PluginStore Author
Postby Oxer » Sun Jan 26, 2020 2:50 pm
Spanish Language File
FredoGhost_ES.lang.zip
User avatar
Oxer
Postby fredo6 » Sun Jan 26, 2020 4:42 pm
Oxer wrote:Spanish Language File
Thank you very much.
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] FredoGhost - v1.4a - 21 May 20
Postby fredo6 » Thu May 21, 2020 8:43 pm
NEW RELEASE: FredoGhost v1.4a - 21 May 20
Requirement: LibFredo6 10.4
FredoGhost 1.4a fixes bugs and extends validity.
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] FredoGhost - v1.5a - 19 Aug 20
Postby fredo6 » Wed Aug 19, 2020 9:36 pm
NEW RELEASE: FredoGhost v1.5a - 19 Aug 20
Requirement: LibFredo6 11.0
FredoGhost 1.5a fixes bugs and extends validity.
User avatar
PluginStore Author
PluginStore Author
Postby rezvan23 » Fri Oct 09, 2020 9:39 pm
Hi Fredo.
Could you add a feature that is like 3ds max's "Display as Box" option, which shows the object as a box in viewport, and shows the actual geometry in render?
I don't mean vrayproxy, that's not editable.
I don't know if that's possible.
Thanks for your great sketchup extensions.
rezvan23
Postby fredo6 » Sun Oct 11, 2020 10:37 am
rezvan23 wrote:Could you add a feature that is like 3ds max's "Display as Box" option, which shows the object as a box in viewport, and shows the actual geometry in render?
FredoGhost is not aware of the rendering. So, just before rendering, you need to swap the objects from box to their 'real' version.
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] FredoGhost - v1.6a - 20 Nov 20
Postby fredo6 » Fri Nov 20, 2020 1:17 pm
NEW RELEASE: FredoGhost v1.6a - 20 Nov 20
FredoGhost 1.6a fixes bugs and extends validity.
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] FredoGhost - v1.7a - 06 Jan 21
Postby fredo6 » Wed Jan 06, 2021 8:00 am
NEW RELEASE: FredoGhost v1.7a - 06 Jan 21
FredoGhost 1.7a fixes bugs and extends validity.
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin][$] FredoGhost - v1.8a - 27 Jan 21
Postby fredo6 » Wed Jan 27, 2021 1:59 pm
NEW RELEASE: FredoGhost v1.8a - 27 Jan 21
Requirement: LibFredo6 11.6
FredoGhost 1.8a becomes a paid plugin.
There is a Free trial period of 15 days from activation, with full features. Then, you need to license the extension on Sketchucation:
  • Perpetual License: 17 €
  • Rush License (21 days from purchase date): 5 €
See this post for instructions to license an extension on Sketchucation.
Note: the previous version v1.7a will naturally expires on 31 Jan 21
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: Ellez, fnatic vector, Google Bot, Samara1207, tomywong, Ukacha21 and 11 guests
Visit our sponsors:
