Additional geometry.
General discussion related to SketchUp Pro and Make
Postby Mike Amos » Fri Aug 23, 2019 1:49 pm
OK, I have just been attempting to use the cleanup plugin with a model and slow is not the word, HOW much additional geometry?
In the end I have forced a close on sketchup via the task manager, problem I cannot understand is how three instances of sketchup (2017 Make) can be running and need to be closed. Is this a new bug or has it been reported before?
If I had opened three instances of sketchup that would be understandable but I have only been opening the one.
Premium Member
Premium Member
Re: Additional geometry.
Postby Box » Fri Aug 23, 2019 1:58 pm
Two posts perhaps about the same thing, neither of which make any sense.
Try explaining your issue and your feature request with words and pictures and models if available that add up to something someone who can't read your mind can make some sense from.
User avatar
Postby Mike Amos » Fri Aug 23, 2019 2:11 pm
Thanks for that.
extra geometry in model.
3 copies of sketchup running when I force shutdown of sketchup via the task manager.
Has there been any development within sketchup to deal with the additional unwanted geometry?
New bug? Old bug? Design feature?
Premium Member
Premium Member
Postby Box » Fri Aug 23, 2019 4:00 pm
I'm afraid your response has left me less than informed and as such I will bow out of further discussion in case my ignorance of your subject causes embarrassment to someone.
User avatar
Postby Mike Amos » Fri Aug 23, 2019 5:07 pm
Have a nice day, crossed purposes obviously and missed communication. I wish it were my subject I might get further.
Premium Member
Premium Member
Postby Box » Fri Aug 23, 2019 7:06 pm
It is your subject! You created it. Show us something that we can possibly give you an answer to.
A real question, some evidence of an anomaly, randomly saying you have had to close things due to some sort of clean up is utter nonsense.
What on earth does, HOW much additional geometry? mean?
Explain your problems, don't blame your problems.
You suggest Bugs several times, whereas I would point out that user settings needing adjustment have been the most common solution to similar issues.
User avatar
Postby Mike Amos » Sat Aug 24, 2019 10:46 am
1. It is my model, the subject is the additional geometry sketchup is known to produce.
2. Saying I had to close sketchup due to the program failing to run while attempting to cleanup the additional geometry is not nonsense or random.
3. How much additional means just that, the amount of additional geometry in the model is staggering to the point that cleanup states 36 hours or more to delete additional faces and then freezes (Hence having to force close the application)
4. SHowing the model will not demonstrate the problem, how can it when additional geometry cannot be SEEN as additional geometry?
5. Explain your problems, don't blame your problems. I thought I had and I did not blame the problems. I suggest bugs because all programs have them and was wondering if newer versions of sketchup may have addressed the additional geometry problem.
I get that you are not having a great time at the moment, me either. I think now I shall close further involvement in my own thread and attempt to find a way round this myself. Sotto voce when reading posts please.
Premium Member
Premium Member
Postby slbaumgartner » Sat Aug 24, 2019 1:47 pm
Mike Amos wrote:the subject is the additional geometry sketchup is known to produce.
Please describe under what circumstances SketchUp produces additional geometry. That hasn't happened to me, so I don't know what you are referring to.
slbaumgartner
PluginStore Author
PluginStore Author
Postby Mike Amos » Sat Aug 24, 2019 3:38 pm
From a secondary component. ThomThom's cleanup plugin.
Premium Member
Premium Member
Postby shawb » Sat Aug 24, 2019 5:59 pm
Looking at the screenshot of the Cleanup report, in particular the number of edges that have been reduced, I would hazard a guess that what the OP is seeing is not additional geometry that SU has somehow created. Instead it is contiguous edges that have come about during the normal course of modelling. Raw geometry has been joined or overlaid with more geometry. As far as I know raw geometry is sticky and each edge remains a discrete entity and will not weld or join to form a single, longer edge. I haven't used Thom Thom's cleanup plugin but it looks like its purpose is to reduce geometry by joining contiguous edges and make for a smaller SU file size.
No idea what may be causing the other reported issues.
shawb
Postby pbacot » Sat Aug 24, 2019 7:55 pm
The additional geometry is really things like coplanar faces--removing the uneeded edge dividing them, and stray edges--depending on the settings you have made for Cleanup3. It's good to use the tool as you model before you create too many extra edges etc, and avoid modeling that does so. SketchUp doesn't make the extra edges, though plugins might (such as SandBox).
I would turn off the CleanUp purge functions and do the purges in the Model Info window. See if that helps.
I find CleanUp3 to be so slow as to be unusable in larger models in v2019, regardless of the cleanup job or selection. It is often faster to cleanup the model on my own. It seemed to work fine in 2016. I've never tried 2017.
Haven't heard of multiple instances of the application opening.
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
User avatar
Top SketchUcator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: Anitasketch and 12 guests
Visit our sponsors:
