Entering object dimensions--arg!
General discussion related to SketchUp Pro and Make
Postby CalypsoArt » Fri Aug 02, 2019 8:35 pm
What is the correct way to enter object creation dimensions so it to correct to the X/Y? Every time I do the axis is wrong. E.G. I enter 3',6' it never is on the axis I want. Reversing to 6',3' after the initial entry will give me the correct alignment. However, if I had entered it as 6',3' originally I would have still got the wrong thing. I expect that is another "Doh!" moment.
CalypsoArt
Premium Member
Premium Member
Re: Entering object dimensions--arg!
Postby shawb » Fri Aug 02, 2019 8:53 pm
I gave up trying to figure that one out a long time ago! What I have been doing is to click and drag out a rectangle that is long and thin so that a check of the Measurements box will show which way the Axis are showing up as either x/y or y/x for that particular operation.
shawb
Postby Dave R » Fri Aug 02, 2019 9:52 pm
Like shawb, I quit trying to figure it out over a decade ago and just start the rectangle very obviously longer in one dimension than the other and use the same order when I type. It depends on which way the rectangle is oriented in 3D space.
User avatar
Global Moderator
Postby agrazdi » Sun Aug 04, 2019 2:25 pm
I assigned a shortcut for " view/rendering/edge/by axis " as ALT + X so i can turn on or off the colors of the object's axis, so in this way, i know where to dimension any object. < X,Y >
agrazdi
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: No registered users and 8 guests
Visit our sponsors:
