[Plugin Library] LibFredo6 - v14.3d - 21 Apr 24
@caleb_stanley said:
I keep getting an error message with the plugin ToolsOnSurface upon starting up SketchUp, I think it may have something to do with the new update but I am not sure.
The message reads:
"ToolsOnSurface 2.4a: Error starting up plugin (creating menus and icons)
invalid byte sequence in UTF-8 [in lib6config.rbe - #'===0: line 319]For whatever reason, the default parameters file for ToolOnSurface is corrupted or had its encoding changed.
This file should be in
C:/Users/<username>/AppData/Local/LIBFREDO6_DATA_Dir/DefaultParameters/ToolsOnSurface.defThe best is to delete this file. You will just reset the default parameters to their default values. LibFredo6 will recreate it if you change the Default parameters of ToolsOnSurface.
Do you have a similar problem with my other plugins, if you have any installed?
Firstly... the plug in is truly amazing, and on viewing the support videos we had a really workable poperty fly through in record short development time. Thank you very much.
Question : is there anyway you can render to chaos groups new cloud render service from animator ?
The ' render to cloud button' in vray next for SU is situated in the asset panel. We usually use their service for larger longer renders.Thanks again
The ' render to cloud button' in vray next for SU is situated in the asset panel. We usually use their service for larger longer renders.Rendering animations created by Animator from the Rendering Software is really something that is left to the developers of the rendering software. I have published an API for these rendering software to interact with Animator and render the frames in batch. So far, only Thea Render has implemented it.
I am not sure however there is enough traction for them to engage into these (small) developments.
Thank you, I will raise it with Chaos Group to see their thoughts. It would be an additional route to their new cloud render service. Animator seems to level the playing field in the 3DS Max versus Sketch up choice especially in the property development market, so the need for them to accomodate will hopefully increase.
Something seems to be wrong with the link on the SketchUCation extension store. When I tried to download LibFredo6 I get a file ending in .php, not rbz. This problem doesn't occur for any other extension I've tried to download. The problem exists in both Firefox and Chrome browsers.
Hmmm... I just download it from the PluginStore and it downloaded with the .rbz extension.
What do you get when you use the Sketchucation Extension Store to download and install it?
Apparently it's some strange interaction with the Free Download Manager plug-in in Firefox (and Chrome). But what has me baffled is that it only affected LibFredo, but not any other extension I downloaded. But at least it's solved (for now).
Really got burned by g28 once - have avoided it ever since.
I'm using Chrome with no problems.
What is g28 and what does it have to do with this?
NEW RELEASE: LibFredo6 v9.1a - 20 Jul 19
LibFredo6 9.1a fixes various bugs and is required for FredoPortrait 1.2a
NEW RELEASE: LibFredo6 v9.1b - 28 Jul 19
LibFredo6 9.1b is a minor release for
- Souvenir 1.8d, with the possibilité to specify the directory where SU tasks are saved
- Animator video generation, with a timeout extended to 60 minutes for VRay.
Hi, thank you for plugin. I have a problem with icon on the deskop. i cant opredo. Jpg is en fin annexe. Thank you for answer
The empty toolbar should have a tooltip when you hover over it.
What does it say ?
If you drag it onto the main work area can you see anything more ?A little more detail would help us help you...
Glad to hear its working
Spanish Language file updated:
[attachment=0:a941s360]<!-- ia0 -->LibFredo6_ES.zip<!-- ia0 -->[/attachment:a941s360]
Thank you very much. This will go in the next version.
Hey is anyone else having issues with Fredotools on 2019? I get this error -
I've tried installing libfredo6 before, or after, uninstalling reinstalling, doing it via download vs sketchucation store. alll out of ideas
Can you clean and reinstall FredoTools instead.
I know that these kinds of errors have been seen before... and easily fixed by Fredo.
I think it involves temporarily deleting some preference file/folder, or removing an old/unneeded 'traductor' file...But I'm sure Fredo will be along to advise you later, with the definitive answer...
Instalei o LIBfredo6 que funcionava bem. mas por último quando inicio o SketchUP aparece este erro descrito abaixo.
ERRO SKETCHUP 2016Erro ao carregar o arquivo Fredo6_Curviloft.rb
Error: #<ArgumentError: wrong number of arguments (2 for 1)>
C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:308:intop_load' C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_Curviloft.rb:50:in
module:Fredo6'
C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_Curviloft.rb:26:in<top (required)>' Erro ao carregar o arquivo Fredo6_FredoTools.rb Error: #<ArgumentError: wrong number of arguments (2 for 1)> C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:308:in
top_load'
C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_FredoTools.rb:50:in<module:Fredo6>' C:/Users/Lourival/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in
<top (required)>'
""meu sistema é Win7 de 64 bits
isto tambem passou a aparecer após instalar outro plug-in que tambem teria como base o LIBFREDO6
Help!
I tried several times and this window still comes out. (>.<)'
Does anyone know what can I do?
