How to turn off snap in arc tool
General discussion related to SketchUp Pro and Make
Postby dtrachtman » Fri Jun 14, 2019 4:32 pm
I am trying to draw very precise arcs but SU keeps snapping to arcs I don't want. Is there a way to turn that off? thanks
dtrachtman
Re: How to turn off snap in arc tool
Postby Box » Fri Jun 14, 2019 4:43 pm
You can't turn off the inference snap but if you show us what you are wanting to do we may be able to show you a better way t do it.
User avatar
Postby dtrachtman » Fri Jun 14, 2019 5:31 pm
I designed a curve in Illustrator, exported it as a dwg (also tried dxf) and imported it into SU. As you can see from the attached, it imports all jagged. Pretty amazing since it is such a simple curve, but anyway, I then tried to redraw it in SU w/the arc tool and it keeps snapping. I could lose a day just trying to get a simple curve into this program. Thanks for the help.
dtrachtman
Postby Dave R » Fri Jun 14, 2019 5:47 pm
I'm curious. Your original curve appears to be made with Bezier curves, not arcs. If that's the case, it would make more sense to trace the outline with Bezier curves in SketchUp.
I used the Classic Bezier tool in Fredo6's Bezier Spline extension.
User avatar
Global Moderator
Postby Box » Fri Jun 14, 2019 5:55 pm
dtrachtman wrote:I designed a curve in Illustrator,
How about learning how to draw the curve you want directly.
User avatar
Postby Dave R » Fri Jun 14, 2019 6:02 pm
Box makes a good point. I would have just drawn the curves I wanted in SketchUp to save time.
User avatar
Global Moderator
Postby dtrachtman » Fri Jun 14, 2019 6:08 pm
Dave R, that's perfect! Can you attach that file? I will get that extension and learn how to use it too. I draw things in Illustrator because it is software I am very comfortable with and didn't want to have to fight with SU.
dtrachtman
Postby Dave R » Fri Jun 14, 2019 6:10 pm
Here you go.
I would suggest if you are going to use SketchUp at all, it's worth taking the time to learn how to model things like this. It'll save you time and aggravation in the future.
User avatar
Global Moderator
Postby dtrachtman » Fri Jun 14, 2019 6:22 pm
Thanks for making that. I know your, right. I'm getting there.
Ok, just installed FredoScale Bezier. Very cool. I wish it worked just the same as Illustrator with handles I can click on, but I think this will still work fine. I love Fredo plugins, I am going to give him some money.
dtrachtman
Postby Dave R » Fri Jun 14, 2019 6:32 pm
There are handles to control the curves and you can edit the shape after you get it in place. My normal procedure for something like this is to rough the curve in quickly and then refine it afterward.
User avatar
Global Moderator
Postby dtrachtman » Fri Jun 14, 2019 6:34 pm
Ok, I must be missing something. I will watch a tutorial.
dtrachtman
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: ken and 9 guests
Visit our sponsors:
