Groups into components
General discussion related to SketchUp Pro and Make
Postby jofa » Thu May 23, 2019 11:38 pm
Hello Everyone,
I'm currently working on a model exported from archicad to sketchup. I have around 30 windows that are identical but each one is a group with its own name. My question is: Is there any plugin that can make those groups into components but with one name?
Thank you
jofa
Re: Groups into components
Postby Dave R » Thu May 23, 2019 11:48 pm
Thom Thom's Groups to Components will be a start.
User avatar
Global Moderator
Postby jofa » Fri May 24, 2019 3:55 pm
Thank You Dave R
jofa
Postby GD3Design » Tue May 28, 2019 11:54 am
I'm afraid TT's 'Groups to Components' plugin wont work for this application due to transformations made to the groups - windows rotated to each side of the house. You may have better luck with S4u's s4u_toComponents http://sketchucation.com/forums/viewtop ... 08#p484308 It is $20, but worth it if you're doing professional work...(if your working with archicad then you're doing professional work). I even use it in place of SU's native create component command...it's much faster, if you don't need the dialog...which you only generally need if you're making a cutting or follow me component. (I work with Archicad exports...so I feel your pain...)
User avatar
GD3Design
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: sanya_pp and 3 guests
Visit our sponsors:
