move vertices down to surface  Topic is solved
General discussion related to SketchUp Pro and Make
Postby pbacot » Mon May 13, 2019 10:00 am
I want to move the edge vertices down to the surface below (in z direction). So it would be nice if I can select along an edge and have all the vertices of selected edges move to the nearest face below. Is there a plugin that does this? The two surfaces are in different contexts.
I can do this pretty well one by one manually, but I have a number of them to do. Just wondering.
MacOSX Mojave ShetchUp Pro v19 Twilight Pro v2 M2 Kerkythea PowerCADD
User avatar
Top SketchUcator
Re: move vertices down to surface
Postby ecati » Mon May 13, 2019 12:52 pm
If I understand correctly. If the bottom surface is flat, the Projection plugin. If not, you can use the Sandbox Drape.
Projection plugin: https://extensions.sketchup.com/en/cont ... uide-tools
User avatar
ecati
Re: move vertices down to surface  Topic is solved
Postby sdmitch » Mon May 13, 2019 3:59 pm
Code: Select all
mod = Sketchup.active_model
ent = mod.entities
sel = mod.selection
SKETCHUP_CONSOLE.clear
edgs = sel.grep(Sketchup::Edge)
if edgs[0]
  vers = edgs.map{|e|e.vertices}.flatten.uniq;
  vecs = []; vrts = []; axis = [0,0,-1]
  for v in vers
    p=v.position;
    h=mod.raytest([p,axis]);
    if h
      vrts << v;
      vecs << p.vector_to(h[0])
  ent.transform_by_vectors(vrts,vecs)
else
  puts "select edge(s)"
http://sdmitch.blogspot.com/
User avatar
sdmitch
PluginStore Author
PluginStore Author
Postby pbacot » Mon May 13, 2019 6:30 pm
when I saw sdmitch on the link I got excited! Let me check it out. Thanks!
ecati. Thanks! I don't want to copy but just move the vertices, modifying the upper surface edge. No, the lower surface is not flat at all.
User avatar
Top SketchUcator
Postby pbacot » Mon May 13, 2019 8:00 pm
sdmitch: It worked awesomely. Thank you! What can I do in return?
User avatar
Top SketchUcator
Postby sdmitch » Mon May 13, 2019 8:55 pm
pbacot wrote:sdmitch: It worked awesomely. Thank you! What can I do in return?
You're welcome. Nothing.
3
User avatar
sdmitch
PluginStore Author
PluginStore Author
Postby pbacot » Mon May 13, 2019 9:10 pm
Great skilz! Thanks!
User avatar
Top SketchUcator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: George3mesa8, Google Bot and 4 guests
Visit our sponsors:
