rescaling
The ideal place for beginners to get help using SketchUp
rescaling
Postby erzane » Wed May 08, 2019 10:32 pm
I did a sketch but I mistaked and did all in meters, but I wanted to have centimeters.
Is it possible to rescale it?
I usually use the rescale tool tu change the size but there I don't know exactly how to rescale it because for example there is 4,96 meter lenght, but I need only 49,6 centimeters.
Since I would like to send this sketch to the laser metal manufacture, I've to rescale it to avoid misunderstandings and getting a too big final work
erzane
Re: rescaling
Postby pcmoor » Thu May 09, 2019 3:29 am
use the tape measure, measure a part and instead of the shown measure, say if 1.2m, type .12m, enter then except the re-scale dialog
pcmoor
Re: rescaling
Postby Box » Thu May 09, 2019 3:56 am
You can also select the whole model and use the scale tool, grab the corner and move in then type .1 and hit enter.
User avatar
Re: rescaling
Postby erzane » Thu May 09, 2019 11:17 am
thanks for your replies.
selecting the whole model should be good
but you said ''tape .1'', does it mean 0.1?
should I press ''shift'' when moving? or another button?
p.s. the scale tool is this one right?
erzane
Re: rescaling
Postby pcmoor » Thu May 09, 2019 11:27 am
using the scale tool, as per your .jpg, select a corner then move towards the opposite then type 0.1 as per Box.
Otherwise use the measure tool and measure a part and type the correct measure including units you want and except the new scale as per dialogue activated by this action
pcmoor
Re: rescaling
Postby erzane » Sun May 12, 2019 10:02 pm
Hi guys,
I tryed to rescale by selecting a corner then moving towards then type 0.1 as per Box. This worked but as the figure was 4.89m, once rescaled to 0.1 it measures now 0.49m, so it seems to be bigger of 1mm. Is it an aproximation? Did the rescaling tool a perfect rescale even if he didn't write the correct value?
I also tryed the 2nd way, using the tape measure: I measured a 4.89m part and instead of the shown measure, I typed 0.489 in the box and hitted ''enter'', but nothing changed. I verified the new measure, it said 0.49m, so it seems he also added this 1mm extra.
Usualy, if the distance is approximative, the box says an approximative sign like ''~'', but in this case it's not like that, so I'm worrying if sketchup did really add this 1mm extra or if it's just a way that the box is using because sketchup cannot be more precise when downscaling with that scale...
p.s. what does ''except the re-scale dialog'' means?
erzane
Re: rescaling
Postby Dave R » Sun May 12, 2019 10:09 pm
erzane wrote:Hi guys,
Increase the Precision of the dimensions display in Model Info>Units.
User avatar
Global Moderator
Re: rescaling
Postby gilles » Sun May 12, 2019 10:25 pm
If your model is set in meters draw a line one meter long, go to window/info on the model/units/ chose millimeters/close.
Use the tape toll on the line, it tells you 1000 mm/ type 1+ enter and agreed redimension. Done
User avatar
gilles
Top SketchUcator
Re: rescaling
Postby erzane » Mon May 27, 2019 11:45 am
Thanks!!
erzane
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Newbie Forum
Who is online
Users browsing this forum: guneygultekin and 4 guests
Visit our sponsors:
