[Plugin] TopoShaper - v2.5b - 11 Apr 19 - IsoContour & Cloud
Re: [Plugin] TopoShaper - v2.3b - 06 Dec 17 - IsoContour & C
Postby alpro » Tue Nov 13, 2018 2:35 am
fredo6 wrote:In general, it is better to conceive the terrain before adding decoration, houses, fences, etc...
But I'll think about what can be done, especially for roads.
So what I'm doing is recreating our existing conditions surveys so that design can be brought in in 3D for some presentations and renders. When creating surfaces in Civil 3D our spot shots are used for the surface but so is our line work as breaklines for things such as roads, sidewalks, retaining walls. When I bring the contours into SU and create a surface using topo shaper sometimes the differences are pretty significant and just like KrisM I have to manually make adjustments to the surface which is tedious. Toposhaper already is a great plugin but I think having this feature will make it even better.
alpro
Premium Member
Premium Member
Re: [Plugin] TopoShaper - v2.4a - 19 Dec 18 - IsoContour & C
Postby fredo6 » Wed Dec 19, 2018 10:08 pm
NEW RELEASE: TopoShaper v2.4a - 19 Dec 18
Requirement: LibFredo6 8.7a
TopoShaper 2.4a is a maintenance release with small adjustments.
Home Page of TopoShaper for information and Download.
Main post of this TopoShaper thread.
User avatar
PluginStore Author
PluginStore Author
Postby MelResDes » Sat Feb 16, 2019 6:31 pm
Hello,
I have never used Toposhaper before. I am trying to create a surface from the contour lines and I keep getting an error and the script aborts the operation. Attached is the Error:
Date: 16-Feb-19 12:25:07
An error occurred in CLEANSING
The operation is fully aborted
undefined local variable or method `colors_init' for #<F6_TopoShaper::TopoShaperCleanser:0x0000017fe1ef9f68>
toposhapercleanser.rbe: 84 -- initialize
toposhapertool.rbe: 541 -- new
toposhapertool.rbe: 541 -- cleansing_processing
toposhapertool.rbe: 523 -- after_selection
toposhapertool.rbe: 493 -- notify_edge_picked
body_lib6edgepicker.rbe: 445 -- call
body_lib6edgepicker.rbe: 445 -- notify_action
body_lib6edgepicker.rbe: 496 -- terminate_current_selection
toposhapertool.rbe: 658 -- execute_validate
toposhapertool.rbe: 387 -- handle_initial_selection
toposhapertool.rbe: 319 -- activate
toposhapertool.rbe: 133 -- select_tool
toposhapertool.rbe: 133 -- action__mapping
lib6plugin.rbe: 126 -- call
lib6plugin.rbe: 126 -- launch_action
lib6plugin.rbe: 224 -- launch_action
bootstrap_toposhaper.rbe: 83 -- launch_action
bootstrap_toposhaper.rbe: 136 -- block in startup
lib6plugin.rbe: 1271 -- command_invoke
lib6plugin.rbe: 1253 -- block (2 levels) in build_config_commands
lib6traductor.rbe: 1361 -- block in add_command
Please let me know if you need more info from me or if you need the file I am working on.
MelResDes
Postby fredo6 » Sat Feb 16, 2019 7:45 pm
Can you advise if you use Linux under the cover?
User avatar
PluginStore Author
PluginStore Author
Postby MelResDes » Sat Feb 16, 2019 8:16 pm
I am not really familiar with Linux other than it is an OS that I don't think I use. I'm using a standard Windows 10 OS and Sketchup Pro 2019.
MelResDes
Postby fredo6 » Sat Feb 16, 2019 9:03 pm
I found the problem, which seems specific to SU2019.
I will publish a fix.
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] TopoShaper - v2.5a - 16 Feb 19 - IsoContour & C
Postby fredo6 » Sat Feb 16, 2019 9:15 pm
NEW RELEASE: TopoShaper v2.5a - 16 Feb 19
TopoShaper 2.5a includes a major fix for SU2019, preventing it to launch correctly .
User avatar
PluginStore Author
PluginStore Author
Postby MelResDes » Sat Feb 16, 2019 9:38 pm
The update worked! Thank you so much!
MelResDes
Postby fredo6 » Sat Feb 16, 2019 10:07 pm
MelResDes wrote:The update worked! Thank you so much!
Thanks for signaling the problem.
User avatar
PluginStore Author
PluginStore Author
Postby MelResDes » Thu Feb 21, 2019 9:32 pm
Hello Fredo,
Is there a tool I can use to manipulate a mesh created by Toposhaper? I am looking for a way to push or pull the grade around the house model I have placed on the mesh. I tried to use the native smoove tool in Sketchup but it did not want to cooperate with the Toposhaper mesh and it locked up.
MelResDes
Postby fredo6 » Thu Feb 21, 2019 9:42 pm
MelResDes wrote:Hello Fredo,
You can use the native Sketchup Sandbox, or Artisan by Whaat (pay plugin).
User avatar
PluginStore Author
PluginStore Author
Postby MelResDes » Thu Feb 21, 2019 9:57 pm
Thank you. I tried to use the native sandbox tools but it locked up SketchUp. I will look into the Artisan plugin.
MelResDes
Postby fredo6 » Thu Feb 21, 2019 11:15 pm
MelResDes wrote:Thank you. I tried to use the native sandbox tools but it locked up SketchUp. I will look into the Artisan plugin.
Did you build the terrain from iso-contours (so you get a quadmesh) or from a cloud of points (so you get a triangulated mesh)?
User avatar
PluginStore Author
PluginStore Author
Postby pbacot » Thu Feb 21, 2019 11:16 pm
A problem with the native sandbox tool--don't pre-select the mesh. Vertex Tools ($) also helps for some work.
MacOSX Mojave ShetchUp Pro v19 Twilight Pro v2 M2 Kerkythea PowerCADD
User avatar
Top SketchUcator
Postby MelResDes » Thu Feb 21, 2019 11:27 pm
pbacot wrote:A problem with the native sandbox tool--don't pre-select the mesh. Vertex Tools ($) also helps for some work.
Thanks! That is what I was doing wrong. I appreciate the help.
MelResDes
Postby Rom1br » Tue Mar 05, 2019 10:01 am
Hi , I try to figure out how I can create a terrain from a 3D dwg file I'm given.
When you import this in SU and you keep the points and explode the components you see that Entity info confirms that they are Guide Points.
I select them all and try to use the Points cloud fonction of the plugin but it fails or crash my SU ( pro 2018 on Mac btw ).
I upload the dwg file if someone is kind enough to tell me what I'm doing wrong .
Thanks for the good job though , big fan of your work .
Thanks everybody
Rom1br
Postby fredo6 » Tue Mar 05, 2019 11:52 am
Did you enclose all guide points within a group and then launch TopoShaper on this group?
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] TopoShaper - v2.5b - 11 Apr 19 - IsoContour & C
Postby fredo6 » Thu Apr 11, 2019 3:04 pm
NEW RELEASE: TopoShaper v2.5b - 11 Apr 19
TopoShaper 2.5b includes another major fix for SU2019, preventing it to launch correctly .
User avatar
PluginStore Author
PluginStore Author
Postby pbacot » Sat Apr 27, 2019 3:14 am
Working on a issue here. The main hill in my terrain is coming out deflated. In the screen shot, have selected "Show contours used by each node of the mesh". It looks like a lower contour is coming into play. (is this query relevant?) I have the hilltops set to "rounded". There is no straight line like is highlighted here connecting that contour below. No hidden lines. Maybe the contour file is too rough there are some gaps and big hole as you can see. At least I am reading the manual now.
I can see there is a point where I can see these erroneous closing of contours (the straight lines). At this point in cleansing I can ignore the contour or simplify it. I wonder what steps I should take a that point to correct the straight line connections.
User avatar
Top SketchUcator
Postby pbacot » Sat Apr 27, 2019 4:57 am
I think I am really pushing it here. Two large a sample. Everything with this file is super slow. But it appears that I can find these troublesome contours and have TopoShaper ignore them--it doesn't hurt the outcome.I just seem to have quite a few of these contours trying to close from far away.
The bad contour did not show until after "Calculating Contours" I selected it and noted the elevation. Went back to "Cleansing"and right-click: exclude the contour from calculation of mesh(sorry I can't remember exactly what the contextual menu called it). I also just have to run smaller chunks of contours at a time.
User avatar
Top SketchUcator
Postby fredo6 » Sat Apr 27, 2019 4:25 pm
@pbacot,
Would you have the model so that I have a close look at the issue.
User avatar
PluginStore Author
PluginStore Author
Postby pbacot » Sat Apr 27, 2019 7:12 pm
I'll pm you, Fredo. Thanks!
User avatar
Top SketchUcator
TopoShaper not working
Postby clairem » Thu Jun 06, 2019 5:02 pm
Hi everyone. I'm came to this community to use the seemingly wonderful TopoShaper but nothing happens on my end... I followed the simple instructions and i get this lines in Ruby :
Error: #<Errno::ENOENT: No such file or directory @ rb_file_s_mtime - /Users/claire/Library/Application Support/.LIBFREDO6_DATA_Dir/LibFredo6_all_defaults.dat>
/users/claire/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:113:in `mtime'
/users/claire/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:113:in `need_reload?'
/users/claire/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:118:in `init'
/users/claire/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:141:in `store'
/users/claire/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1281:in `usage_use'
/users/claire/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1269:in `command_invoke'
/users/claire/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1252:in `block (2 levels) in build_config_commands'
/users/claire/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1361:in `block in add_command'
I'm not code savvy and im new to Point clouds too.
Can anyone offer assistance here?
I'm using Sketchup Pro 2019 on a MacBook Pro...
clairem
Postby fredo6 » Thu Jun 06, 2019 6:04 pm
@clairem
Could you try with this version LibFredo6 8.9b.
It might come from your installation, but I made theis portion of the code more resilient.
User avatar
PluginStore Author
PluginStore Author
Postby clairem » Thu Jun 06, 2019 6:13 pm
Thanks a lot!! Un gros merci @fredo6, ça marche :)
clairem
Postby fredo6 » Thu Jun 06, 2019 6:18 pm
clairem wrote:Thanks a lot!! Un gros merci @fredo6, ça marche :)
Merci a toi.
Peux tu confirmer que tu n'avais jamais installé LibFredo6 auparavant
User avatar
PluginStore Author
PluginStore Author
Postby clairem » Thu Jun 06, 2019 6:23 pm
Non, c'était bien la première fois. J'ai supprimé les plugins installés dans l'Extension manager et j'ai installé le nouveau lien que tu as posté, fermé SU, réouvert, puis ensuite ré-installé TopoShaper. J'ai réussi à faire un mesh avec les points que j'avais!
clairem
Postby TIG » Thu Jun 06, 2019 6:44 pm
So we have a solution ?
Nous avons donc une solution?
User avatar
Global Moderator
Postby mozzie » Sat Jun 22, 2019 2:28 pm
Thanks for Toposhaper - it is wonderful!!!
I'm using it on the last Google version of Sketchup (8), and have had no problems over a long period. I recently updated to v2.5b (and LibFredo v8.9b) and have not been able to complete the final build.
I would appreciate your suggestions - I know that SU 8 Pro is now very outdated, but it is a all I need!
NOTE: The latest versions work fine on Sketchup Make 2015, but fail on the final stage with SU 8.
CLEANSING - no problems
PREVIEW - no problems
Choosing flat or rounded - no problems
Generate Terrain - Ruby error here is the log file.
Code: Select all
Date: 22-Jun-19 21:30:15
An error occurred in GENERATION OF TERRAIN
undefined method `hovering_notification' for #&lt;Traductor::Palette:0x1bd6e938&gt;
(eval): 102 -- onMouseMove
(eval): 870 -- onMouseMove
(eval): 865 -- onMouseMove_zero
(eval): 1309 -- geometry_terminate
(eval): 449 -- call
(eval): 449 -- terminate_execution
(eval): 332 -- next_step
(eval): 2548 -- geometry_step_exec
(eval): 2493 -- geometry_execute
(eval): 370 -- call
(eval): 370 -- step_geometry
(eval): 419 -- start_execution
(eval): 1280 -- geometry_execute
(eval): 668 -- execute_validate
(eval): 130 -- execute_from_palette
(eval): 76 -- notify_from_palette
(eval): 431 -- getMenu
body_Lib6Tool.rb: 1478 -- call
body_Lib6Tool.rb: 1478 -- show
(eval): 102 -- call
mozzie
Postby fredo6 » Sat Jun 22, 2019 3:27 pm
@mozzie
There must be something wrong in your installation of LibFredo6 and the problem you have is very strange, including the bug report.
Can you clean up LibFredo6 and reinstall.
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
cron
Who is online
Users browsing this forum: No registered users and 15 guests
Visit our sponsors:
