[WIP] Woodworking Lathe -- Late 1800's
Postby Dave R » Sat Apr 20, 2019 5:22 pm
A little start on a model of a cast iron woodworking lathe from the 1800's. This one is designed to be driven by a wide belt from an overhead line shaft so head stock and the stepped pulleys will be next. The bed is intentionally short at this point to make modeling the rest of the parts that go on it easier.
FWIW, the components are all solid. I might make a scaled down version of it and 3D print it.
User avatar
Global Moderator
Re: [WIP] Woodworking Lathe -- Late 1800's
Postby tuna1957 » Sat Apr 20, 2019 6:27 pm
:thumb: :thumb: Very cool ! Curious where you found dimension drawings of the various parts. It's pretty hit and miss when I try and find dimension drawings for cool old stuff online ( usually miss ). Looking forward to seeing it printed. :thumb: :thumb:
tuna1957
Premium Member
Premium Member
Postby Dave R » Sat Apr 20, 2019 6:30 pm
Thank you. Old text books are good sources for this sort of stuff.
User avatar
Global Moderator
Postby Bryan K » Tue Apr 23, 2019 9:02 am
Cool project!
User avatar
Postby Dave R » Tue Apr 23, 2019 12:34 pm
Thank you Bryan.
A little more progress. Tailstock isn't finished yet and I need the hand wheel for the tool rest.
User avatar
Global Moderator
Postby L i am » Tue Apr 23, 2019 12:50 pm
I can feel the wieght of that piece it looks very authentic and believable :thumb: :thumb:
Premium Member
Premium Member
Postby Dave R » Tue Apr 23, 2019 2:07 pm
Thank you Liam.
A little more progress this morning. Not happy with the back part of the tail stock casting. It needs work but I decided to leave it for awhile and think about it. On to other parts.
User avatar
Global Moderator
Postby Dave R » Wed Apr 24, 2019 8:30 pm
Only a little more progress. Hand wheels, reworking the tail stock casting and a bunch of small parts left to do.
3
User avatar
Global Moderator
Postby Mike Amos » Wed Apr 24, 2019 11:05 pm
Very nice indeed.
Premium Member
Premium Member
Postby Bryan K » Tue Apr 30, 2019 5:22 am
Looking great!
User avatar
Postby Dave R » Tue Apr 30, 2019 7:16 pm
Thank you.
Lathe has turned to the back burner but I did get handwheels and a few other parts modeled.
User avatar
Global Moderator
Postby Bryan K » Tue May 07, 2019 7:12 am
Nice!
User avatar
Postby Dave R » Sun May 26, 2019 3:43 am
Thank you Bryan.
Thanks to Aaron and his live stream modeling, I found an engine to power it with. This one actually might be overkill for just a lathe, though.
User avatar
Global Moderator
Postby Bryan K » Mon May 27, 2019 3:43 am
That looks cool. :thumb:
User avatar
Postby Mike Amos » Mon May 27, 2019 10:37 am
Very impressive engine.
Premium Member
Premium Member
Postby railwaxking » Tue Sep 10, 2019 1:06 pm
Hello Dave,
i like your lathe and steam engine. The steam engine seams to be a little bit oversized for your lathe.
In former days they had spezial models to fit the needs of small workshops. Here an example hanging on a wall:
I found the drawing some time ago in the internet and started a sketchup drawing. As you can see still wisp (work in slow Progress).
To build a live steam model you find a similar engine here:
http://dampfmodellbauer.de/webshop/product_info.php?products_id=74
geatings
Martin
railwaxking
Postby railwaxking » Thu Sep 12, 2019 9:15 pm
Hello Dave,
today i founnd your steam engine at the 3d-warehouse. https://3dwarehouse.sketchup.com/model/fece5c92-7dd7-44fc-bd1e-7ae20f04a6b1/TWIN-CYLINDER-HORIZONTAL-STEAM-ENGINE
After some colour/material adjustments i made a quick twilight render.
I hope you like the result.
Greetings from Germany
Martin
railwaxking
Postby Dave R » Fri Sep 13, 2019 1:44 pm
Looks like a good rendering. It isn't my model of the engine, though.must be one made by someone else.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to WIP
Who is online
Visit our sponsors:
