Wrap-R for SketchUp
Re: Wrap-R for SketchUp
Postby juju » Thu Feb 14, 2019 8:42 am
tengel07 wrote:Payed nd got nothing! Cheater!
This won't help resolve any problems you may be experiencing.
More details would help though, like when the transaction happened, etc.
Be sure to check you spam filters / folders as well, sometimes there are false positives.
User avatar
juju
Premium Member
Premium Member
Postby tengel07 » Thu Feb 14, 2019 8:45 am
i did check my spam folder and my folder with mails from unkown too.
Its now 24h after i did the payment and i got nothing - only the payment response mail.
They do not respond on mails to support too.
CHEATER!
tengel07
Postby Gábor » Thu Feb 14, 2019 10:59 am
Hi tengel07,
Thank you for your interest in Wrap-R.
I'm now investigating what happened. Will answer your support ticket soon.
Gábor
Gábor
Postby Gábor » Thu Feb 14, 2019 11:27 am
Hi tengel07,
I checked and our system sent out the licence by email at the time of the purchase. Sometimes it happens that some over sensitive spam filter puts it into the spam folder or erases it.
Anyhow now I've re-sent the licence both from the system and from my gmail mailbox. Hope you've received it this time.
Best regards,
Gábor
Gábor
Postby pilou » Thu Feb 14, 2019 8:10 pm
+ QFT + SubD
What is QFT ? :oops:
Speedy Galerie
User avatar
Top SketchUcator
Postby juju » Thu Feb 14, 2019 9:17 pm
pilou wrote:
+ QFT + SubD
Quad Face Tools :thumb:
User avatar
juju
Premium Member
Premium Member
Postby pilou » Thu Feb 14, 2019 10:56 pm
Aaaah! Thx! :enlight:
I believe that Optimaforever is an old famous member of PPB*! ;)
And Master of Su of course! :fro:
* PushPullBar
A very cool SketchUp forum who has alas hacked! :(
Speedy Galerie
User avatar
Top SketchUcator
Postby suSteve » Sun Mar 10, 2019 9:38 am
Could you please confirm that it is compatible with make 2017 and pro 2019?
thank you (the wrap-r website says pro 2018).
Also the website has a cyber monday 2018 code is that still valid?
thank you
suSteve
Premium Member
Premium Member
Postby TIG » Sun Mar 10, 2019 6:34 pm
Get the latest version to ensure v2019 compatibility...
You can but try the code ;)
User avatar
Global Moderator
Postby Gábor » Mon Mar 11, 2019 11:45 am
suSteve wrote:Could you please confirm that it is compatible with make 2017 and pro 2019?
Yes, it is compatible with these versions. But to be sure it fits your needs I suggest to obtain and try the 7 days free trial at https://wrap-r.com/trial-access.html .
If you already have purchased a license you can download the latest version of the program from here: https://s3.amazonaws.com/wrapr-download/WrapR-installer_2018_4.exe
Gábor
Postby optimaforever » Mon Mar 11, 2019 12:19 pm
pilou wrote:Aaaah! Thx! :enlight:
* PushPullBar
Ah! salut Pilou! yes, I'm ryo from PPB ;)
optimaforever
Premium Member
Premium Member
Postby suSteve » Fri Mar 15, 2019 12:09 pm
Thanks for the replies - just purchased. No need to do the free trial as the reviews are good enough for me.
suSteve
Premium Member
Premium Member
Postby Gábor » Sat Mar 16, 2019 8:58 pm
Thank you for purchasing Wrap-R. I wish you loads of happy unwrapping! :)
Gábor
Postby suSteve » Tue Mar 19, 2019 4:10 pm
One of the bug bears and hopefully I have this wrong is:
I choose ctrl to create the start of my cut and I can't see the end of my cut so I hold down the middle mouse and shift key to pan and by doing that I switch over to loop mode and lose my start cut.
Is there a way around this?
thank you
Also, is there a way to pan the 3D object in wrap-r. I tried right click (which I think I saw somewhere) but that just gives me a context menu. Hand tool, middle mouse + shift does not work
thanks again
suSteve
Premium Member
Premium Member
Postby Gábor » Wed Mar 20, 2019 8:40 pm
suSteve wrote:I choose ctrl to create the start of my cut and I can't see the end of my cut so I hold down the middle mouse and shift key to pan and by doing that I switch over to loop mode and lose my start cut.
Do I understand well that you are trying to select an edge loop in the 2D window? In edge select mode pressing holding down T and left clicking an edge should mark the beginning of the edge loop. Then you can release T and pan with middle mouse button (Shift is not necessary) and then by again holding T and left clicking the end of the loop should create the loop. Is it not working so for you? Would it help if in loop select mode the middle mouse button would still do the panning?
suSteve wrote:Also, is there a way to pan the 3D object in wrap-r. I tried right click (which I think I saw somewhere) but that just gives me a context menu. Hand tool, middle mouse + shift does not work
Panning in the 3D window should work with Shift + Right mouse button
Gábor
Postby suSteve » Sat Mar 23, 2019 1:02 pm
Thanks for the reply
I am in edge select mode in Su. So I ctrl-click to start the loop and then have to pan so use shift-middle mouse and that changes the edge select mode to loop and I lose my start point
thanks
suSteve
Premium Member
Premium Member
Postby suSteve » Sat Mar 23, 2019 3:43 pm
Not sure if its mentioned here but if you want to see your texture in wrap-r then it has to be square (512 x 512 etc.). Took me a while to work that one out
suSteve
Premium Member
Premium Member
Postby Gábor » Sun Mar 24, 2019 5:05 pm
suSteve wrote:Thanks for the reply
thanks
Did the 'T' button + click the start of the loop then pan than hold 'T' and click the loop closing edge advice helped to solve the problem?
Gábor
Postby Gábor » Sun Mar 24, 2019 5:06 pm
suSteve wrote:Not sure if its mentioned here but if you want to see your texture in wrap-r then it has to be square (512 x 512 etc.). Took me a while to work that one out
Yes, it is true. At the moment Wrap-R can handle only square texture images. Thank you for mentioning it.
Gábor
Postby suSteve » Mon Mar 25, 2019 12:00 pm
Sorry I am not making myself clear
I am in Su not Wrap-r and I am marking the seams. If I use ctrl to mark the start and then shift+middle mouse to pan the act of using the shift clears the ctrl.
In wrap-r yes the T works fine.
If I use T in Su I would get the tape measure
This means I cannot set the start of the seam (ctrl) and then shift+middle mouse to pan otherwise the seam start is lost. Unless I can see the whole of the seam to be marked I cannot use ctrl
hope that helps
suSteve
Premium Member
Premium Member
Postby TIG » Tue Mar 26, 2019 12:44 am
In SketchUp there are 3 modes for 'marking'.
The starting default is to highlight and pick an individual 'Seam' edge.
Pressing Shift changes to 'Loop', where a connected loop of edges is highlighted en mass, based on angular divergence rules which determine the most likely loop of edges connected to that hovered-edge.
Pressing Ctrl changes to 'Path', where you pick a number of connected edges, one after the other to be marked by confirming at the end.
You can circle through these 3 modes using those modifier-key presses.
Pressing TAB toggles between marking and deleting Seams in any of the modes***.
The Status Bar at the bottom shows the current mode, and what key presses will change what...
In each mode the hovered-over edge's color and then its subsequently marked color changes, as does the cursor itself.
Seam == Light green on-hover
=> green marked edge, on click to confirm
Loop == Purple loop on-hover
=> green marked all loop's edges, on click to confirm
Path == Orange edge on-hover, and when picked all path's orange edges also have a temporary 'selected' [blue?] edge inside them
=> green marked all path's edges, when you press Enter/double-click to confirm
***Delete = Red on-hover - in Seam mode it deletes single edges, in other modes it can highlight and delete any found and highlighted loops, but only where appropriate...
red => unmarked edges on a confirming click.
Obviously if you press Shift for any other purposes while using the toolset then that is taken as a modifier press by the toolset, possibly changing from the current mode to 'Loop'.
So if you want to safely 'Pan' during your marking, I suggest that you use a shortcut - e.g. I have one set up for Camera/Pan so that I press H to activate the 'Pan' tool.
You can of course set up your own shortcut key-press alternative...
Then Pan run in this way will NOT affect the current toolset's mode setting.
But if you don't want to use a shortcut, then you'll need to commit the Ctrl generated Path marked thus far, by pressing Enter or double-clicking, then do the Pan with Shift+middle-button, and afterwards you need to press Ctrl again to recommence the toolset's Path marking mode from where you left off - the Path marked thus far is now shown in green, and any new addition to that Path are indicated as usual in orange/blue etc, until confirmed.
User avatar
Global Moderator
Postby Gábor » Tue Mar 26, 2019 12:03 pm
suSteve wrote:Sorry I am not making myself clear
Yeah, I thought it was about the standalone Wrap-R :shock: Sorry
I hope TIG's comprehensive guide above helps. Thanks to him for the detailed explanation.
Gábor
Postby suSteve » Fri Mar 29, 2019 5:19 pm
Thank you very much for the reply - yes it answers the question
suSteve
Premium Member
Premium Member
Postby iichiversii » Fri Apr 12, 2019 9:30 pm
Quick Question is Wrap-r compatible with sketchup 2019?
Bring on the Rain...
User avatar
iichiversii
Premium Member
Premium Member
Postby TIG » Sat Apr 13, 2019 3:06 pm
Gábor posted 'Yes' - a month ago in this very thread: viewtopic.php?p=646896#p646896
User avatar
Global Moderator
Postby pipinek » Mon Apr 29, 2019 3:56 pm
Rich O Brien wrote:Working hard to make docs for next week. But I cover most things in those videos above.
Two years later still no written docs, no clear guidance manual, shortcuts key list etc.
pipinek
Premium Member
Premium Member
Postby summerson1990 » Sat Jun 22, 2019 12:55 pm
Wrap-r plugin error SU_ERROR_SERIALIZATION. When I click “Send to Wrap-R” I get such errors.
User avatar
summerson1990
Postby rexhunter2030 » Tue Sep 03, 2019 6:21 pm
Hi there, I purchased Wrap r about four days ago and still don't have my Activation key.
i sent you a email through your website, I have checked everything in my email account and the only thing I have is the purchase confirm reciept, Please can you forward this on to me please.
rexhunter2030
Postby alsomar » Wed Sep 04, 2019 4:15 pm
What about the possibility of setting a minimum margin between islands.
Sometimes the resultant ones are too close one to another. If that happens, I usually have to face some color contamination when I'm painting the model
User avatar
alsomar
Premium Member
Premium Member
Postby jonorman » Mon Sep 23, 2019 6:49 am
Hi, I tried to contact the WrapR support 2 times, but there is no reply.. Did i miss somthing or are the Site/company down ???
jonorman
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Extensions & Applications Discussions
Who is online
Users browsing this forum: silverghost2u and 1 guest
Visit our sponsors:
