messagebox within a callback fails
Postby Didier Bur » Sun Mar 31, 2019 11:28 am
Hi all,
I'm encountering this problem:
When writing a callback function, everything goes well until a messagebox call: the SU window suddenly minimizes to the taskbar :? , the message box doesn't pops-up and the callback stops :shock:
Something like this:
Code: Select all
@web_dialog.add_action_callback("wcCreatePlace") { |d, p|
         # Possible opening ?
         pushPullDoable=validateFace4Pushpull(face)
         if pushPullDoable
            dist=findWallFaceDistance(face)
            if dist
# EVERYTHING OK UNTIL HERE
               rep=UI.messagebox("Open the wall ?",MB_YESNO)
               face.pushpull(-dist) if rep == IDYES
Anyone encountered this before ?
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
User avatar
Didier Bur
Re: messagebox within a callback fails
Postby fredo6 » Mon Apr 01, 2019 7:49 pm
Didier Bur wrote:Hi all,
I don't have the problem, but I use a generic block for the call back and then dispatch the action.
Anyway, very strange!
In your code, I see a variable <face> that is not initialized in the block. Is this the real code?
User avatar
PluginStore Author
PluginStore Author
Postby Didier Bur » Tue Apr 02, 2019 2:17 pm
Thanks Fredo,
No, that's not the real code, simplified for readability.
En fait, "face" est une variable d'instance @face dans mon vrai code, j'ai simplifié pour poster ici.
Je n'ai toujours pas solutionné le pb, j'ai mis des mouchards partout pour tracer ce que fait le callback, et dès que la messagebox est appelée, plus rien...
Je vais calquer ma manière de faire sur la tienne ;-)
Didier Bur
User avatar
Didier Bur
Postby TIG » Tue Apr 02, 2019 2:50 pm
Change this one line to output 'face' & 'dist' to the Ruby Console just before the failure.
p face; p dist=findWallFaceDistance(face)
User avatar
Global Moderator
Postby Didier Bur » Wed Apr 03, 2019 8:34 am
@TIG
Thanks for the hint, unfortunately it doesn't help, I'm getting the correct values for face and dist outputs. BUT, I tried to call message box in others callbacks, it worked in every case.
So what was wrong with this particular callback ? Guess what, one CANNOT call a UI.messagebox after a webdialog (or html dialog) closes, modal or non-modal.
There's some kind of logic here...
This doesn't work:
Code: Select all
# callback cancel
@web_dialog.add_action_callback("dlg_cancel_settings") { |d, p|
   @web_dialog.close()
   r=UI.messagebox("Are you sure ?",MB_YESNO)
This works:
Code: Select all
# callback cancel
   @web_dialog.close()
Didier Bur
User avatar
Didier Bur
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Developers' Forum
Who is online
Users browsing this forum: sketchos and 7 guests
Visit our sponsors:
