Smit Panther ASD Tug
Completed the Bow Towing Winch, I really wanted to take my time on this ( it took 6 Hours to complete ) as its the main part on the tug, heres a look at the real one :
Will still be adding the tow rope itself as soon as I can find a acceptable method to make a low poly version of it.
Heres a Link to to the 3D:
https://skfb.ly/6HuRQ
Currently 73 Hours 27 Minutes in -
Just WOW again!
"WOW" is very appropriate mate When all that goes together how many poly's do you expect and what file size?
Awesome!
Amazing detail and dedication
Thanks Guys, wish I had more hours in a week to throw at this!
My Guess is with the full interior Complete she will be around a million Polys, with probably around 10 4096x4096 Textures ( Each with 6 Different layers, AO, Normals , Rougness etc. )
Completed the Fire Monitors,I was dreading thes,e but they weren't as bad as I thought, only took 4 hours.
Heres a Few Shots of the model where is is at the moment:
Currently 77 Hours 46 Minutes in
No doubt about it, you are simply put, very talented.
The level of detail is just mind altering !
Thanks guys, really enjoying this project!
Bridge frames, Starboard bridge entrance, maindeck windows, bell and bow hatches ad Stern deck port fittings arranged as they should be ( not mirrored ).
Railings, top deck fittings and mast coming soon!
Currently 89 Hours 04 Minutes in
speechless.....
Alot has been changed over the years ive noticed, many things were added everywhere it seems, keeps this project challenging! Bridge Deck Railings took much longer than I thought, sprinklers and lights are there as well, you will see pretty big differences between the 2 sides of the bridge and that aft platform also was added later. Nearing the 100 Hour Mark!
Exterior will be done soon then I can get cracking on the interior!
Currently 98 Hours 32 Minutes in
Insanely impressive!
I thought this roof would take a hour or two and I could move on, well well Surprise! How much equipment can you cram into that tiny space! look no further!
The Top Deck is pretty much done, moving on to the mast next.
Currently 106 Hours 32 Minutes in
Superb work.
Where do you get your references?
Also, how did you create the hull?
Thanks Bryan, its an interesting process that ive tried to explain as best I could here:
https://sketchfab.com/blogs/community/art-spotlight-trawler-sea-lady/
I can give you a specific rundown on this hull if needed?
"I can give you a specific rundown on this hull if needed"?
That would be really cool and helpful.
Step 1: Gathering info
So step 1 is to be sure you have decent drawings (Side View and Front view is a must, top view is a bonus), rib plans are always the best but in the case I had a fairly simple hull with enough information on the drawings to create it, of course go searching for the images of the real ship out the water if you can find any!
Step 2: Subdiv Mesh
Creating the subdiv mesh is always fun, in this case I hard a few hard chine lines to deal with so I was sure to mark them out, I should have added the keel in at this stage, it would have made for a better looking mesh but with higher poly count for no reason apart from a better looking mesh.
Step 3. Seperating mesh for smoothing
This step is really quite dependent on the type of hull you are creating, a wooden ship for instance will not need this, to preserve the hard chine when smoothing is applied, I separate the meshs in their smoothing groups so that when it goes to blender for mapping and smoothing, it wont smoothen out the areas near the bow and stern that have less than a 35° angle. the tradeoff with this method is you will have separated areas on the UV for something that is essentially joined.
Hope this helps!
The Exterior for the most part is complete, the text will probably be removed later and replaced with textures, the Poly count currently is at 438k
Currently 110 Hours 46 Minutes in
Thanks very much for the TUT, looking fantastic.
I'm blown away by your modeling. And inspired. Hardly touched SU in two years, but I'm starting to get the itch again.
