[Plugin] QuadFaceTools
Re: [Plugin] QuadFaceTools
Postby zooen » Sat Dec 08, 2018 7:18 pm
Thank you Oxer for your answer. I edited the file "core.rb" and translated with Notepade ++ for windows. I used google translation to translate so I will have to rework the texts in French.
User avatar
zooen
Postby AlegoZ » Wed Dec 12, 2018 10:42 am
Hey there genious, im just wondering if u know why i cant get a "floating" menu i tried all i know and i can only use quad Tools from the main menu "Tools"
AlegoZ
Postby Einstein » Sat Jan 05, 2019 3:34 pm
Hi!
Recently I discovered Connect tool to be very useful. However, if I set number of Segments to 1 and "Pinch" to any value, position of connecting segment doesn't change - it sticks to the middle, regardless. I thought about a little improvement for this plugin so that Pinch would also apply to single connecting segment, altering its position along edges. This would help a looot! And push SketchUp more towards poly-modelling which I personally miss soo much.
An illustration of the case:
Einstein
Postby Einstein » Sat Jan 12, 2019 2:25 pm
What about kind of "collapse edge" feature? There's a nice sub-tool "remove loops" but as stated, is removes entire loop (screenshot on the left, original quad-mesh on the right). The mesh in the middle shows how I imagine "collapse edge" would work. Only the selected edges are removed and ends are connected to surrouding quad corners.
Einstein
[Plugin] QuadFaceTools - Remove Triangulation removes faces
Postby uwesketch » Tue Feb 19, 2019 12:32 am
When using "Remove Triangulation" on the below selected quads, then the triangulating edges are removed not only from planar quads, but also from non-planar quads.
Selected Quads:
After executing the "Remove Triangulation" command - it looks like a Swiss cheese ;-)
Is there are way to avoid this?
User avatar
uwesketch
Re: [Plugin] QuadFaceTools - Remove Triangulation removes fa
Postby optimaforever » Wed Feb 20, 2019 3:51 pm
uwesketch wrote:When using "Remove Triangulation" on the below selected quads, then the triangulating edges are removed not only from planar quads, but also from non-planar quads.
Selected Quads:
You just want to remove triangulations on planar quads? use Fixit101 script.
optimaforever
Premium Member
Premium Member
Postby optimaforever » Wed Feb 20, 2019 3:58 pm
Hello Thomthom!
Perhaps has it already been discussed, but I often misclick on the Live mesh analysis button instead of connect edges tool button. Not a big deal, you'll say, but as Livemesh doesn't work with Undo, I usually need several clicks to undo it manually.
I quasi never use Live mesh analysis because I model cleanly most of the time. But I guess some people use it.
Now my question is; is it possible to remove it from the toolbar? or make it unclickable or invisible? Alla Fredo6, make a customizable QFT toolbar? Some functions would still be accessible from the menus... I realize I never use the UV mapping tools, nor build corners/ends. and they eat some real estate on my screen.
optimaforever
Premium Member
Premium Member
Postby uwesketch » Wed Feb 20, 2019 7:23 pm
Also the "Merge Faces" from "TT cleanup3" does the trick. - which seems the same in FixIt101.
But it would be nice if the function in QFT would work as well.
User avatar
uwesketch
Postby optimaforever » Thu Feb 21, 2019 8:40 am
I guess QFT remove triangulation’s use is different... If you want to regenerate the missing planes, you could use « make surfaces » script.
optimaforever
Premium Member
Premium Member
Postby uwesketch » Sat Feb 23, 2019 8:28 pm
I am not looking for a work around. The intent of the post is to report a misbehaviour of the QFT function "Remove Triangulation".
To reproduce the issue I have attached a sketchup file.
The below animated gif shows how to reproduce it.
User avatar
uwesketch
Postby tecnomijas » Mon Sep 09, 2019 10:33 pm
Aprende a pronunciar
I would appreciate your help since when I install the quadface tools plugin the plugin toolbar does not appear. I have installed it in sketchup 2018 and 2019
tecnomijas
Postby optimaforever » Wed Sep 18, 2019 1:48 pm
tecnomijas wrote:Aprende a pronunciar
Right-click an icon on the toolbar zone and check if the QuadFace Tools is checked on.
optimaforever
Premium Member
Premium Member
Postby optimaforever » Sun Jan 26, 2020 3:12 pm
Thomas, is there a "drape" a quad mesh on a "target" triangulated mesh (in another group, serving as a reference) along Z axis?
I'm fond of your "Flatten selection" command in Architect Tools, but I'm looking for a tool that basically "drops" all the vertices of a quad group on a target triangulated mesh group, while keeping the first group as quads.
optimaforever
Premium Member
Premium Member
Postby panixia » Sun Jan 26, 2020 7:51 pm
optimaforever wrote:"drape" a quad mesh on a "target" triangulated mesh (in another group, serving as a reference) along Z axis?
Is something like this what you are after?
User avatar
panixia
Postby optimaforever » Sun Jan 26, 2020 8:17 pm
Impressive modeling video! :D
Not exactly what I'm looking for but impressive nonetheless!
Let's say I have a simplified 3d mesh from a topographic survey (drawn from isohypse lines and meshed with toposhaper for instance). Very complex and heavy, and full tris so impossible to edit quickly.
Then I have a site in quad topology modeled in 2D from CAD plans with correct projections of roads, buildings rivers, and so on.
Right now, I move manually each vertice of my quad site to fit the correct height of the topographic mesh, beginning by the roads, then outlines of buildings, etc.
Of course, I use separated groups to keep the quads from merging with the tris, and I regularly test if SubD works without generating errors) and save a lot.
For complex sites, it takes hours. I enjoy the zen attitude when modeling sites but sometimes I realize that it's very repetitive and boring.
So, what I'd like is a script that 'drapes' the vertices of my quad mesh on the topographic mesh with one click, just like the sandbox's drape tool but that keeps the quads, so I can keep subDing afterwards, and of course further editing because the project always evolves...
optimaforever
Premium Member
Premium Member
Postby panixia » Sun Jan 26, 2020 10:08 pm
Oh I see. +1 one for this tool request! Sort of "conform quad mesh to target mesh" that would be really useful.
maybe there is some workaround using tons of plugins..
User avatar
panixia
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: abistyl, arvin_rezaie, bbelussi, mewi1902 and 8 guests
Visit our sponsors:
