MagicaVoxel as render for SU!
• Page 3 of 3 • 1, 2, 3
Re: MagicaVoxel as render for SU!Maybe a little speedy
![]() Last edited by pilou on Fri Feb 08, 2019 9:29 pm, edited 1 time in total.
Re: MagicaVoxel as render for SU!With an image by Aryaneire
![]() Last edited by pilou on Fri Feb 08, 2019 9:27 pm, edited 4 times in total.
Re: MagicaVoxel as render for SU!With a little piece of the above image and a triple loops of Processing
![]() I believe that you can change anything you want aespecially t between 1 - 50, the coef of k 1 - 5 etc... Tell me if that work for you in direct on the fly ! Press the black triangle inside the yellow disc! Then change the code... A cool thing that this Web Editor!
Re: MagicaVoxel as render for SU!A meta thing because it's the 72 images of an animation posted last week!
![]() A possible fixed image A close-up somewhere...walking is infinited! ![]() its brother! ![]() Last edited by pilou on Fri Feb 15, 2019 2:01 am, edited 1 time in total.
