[Plugin] Tools On Surface - v2.4a - 01 Nov 18
Re: [Plugin] Tools On Surface - v2.4a - 01 Nov 18
Postby reza1813 » Tue Feb 12, 2019 12:13 pm
Dear Fredo,
Thank you for your prompt reply to my question. Wow, I thought that adding curve line(Bezier) on Tool on surface plugin will be possible in SketchUp as MESH interface because this is just an example in order to show you what I mean and you obviously know that we usually need to add curve line on the curved surface(Like other Software: Rhino and...). Indeed, I ever use Drap(Feature in the SketchUp) or Flowify plugin(Anders L.) in order to put a pattern on my curved surface but most of the time it doesn't work properly or It does not look like what I am looking for.
All in all, I hope so in the near future, we have this feature on SketchUp. Thanks in advance.
Yours sincerely,
Hamidreza
reza1813
Postby Chumley » Sun Feb 17, 2019 2:16 pm
Hi there.
Do you have a link to download the Tools on Surface plugin? I tried on the main page but link doesn't work.
Thanks.
User avatar
Chumley
Postby TIG » Sun Feb 17, 2019 2:43 pm
You should always look in the Plugin Store for the latest versions of almost all toolsets...
See here...
https://sketchucation.com/pluginstore?p ... sOnSurface
Also remember to download and install the latest LibFredo...
https://sketchucation.com/pluginstore?pln=LibFredo6
After the installations, restart SketchUp to ensure everything gets synced...
User avatar
Global Moderator
Postby Caleb_Stanley » Fri Jun 28, 2019 3:48 pm
I am having issues upon the startup of SketchUp with ToolsOnSurface, I believe it may have something to do with the latest update but I am not sure. Below is the text of the error code upon starting.
ToolsOn Surface 2.4a: Error starting up plugin (creating menus and icons) invalid byte sequence in UTF-8 [in lib6config.rbe - #'===0: line 319]
c:/...'sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1058:in'rescue in block in effective_load_part2'
Please Help. Thank you.
Caleb_Stanley
Postby TIG » Sun Jun 30, 2019 6:52 pm
I'm sure that Fredo will respond with more details...
However, the error message you posted is incomplete - in fact it omits the vital parts.
Can you re-post the FULL message [including your ../users/user_name/ etc]...
Also please confirm that you have the latest LibFredo RBZ installed...
User avatar
Global Moderator
Postby fredo6 » Sun Jun 30, 2019 9:02 pm
Thanks, TIG, for your invaluable help.
I already answer in the other thread where the problem was also posted.
User avatar
PluginStore Author
PluginStore Author
Postby rv1974 » Tue Jul 02, 2019 11:35 am
Fredo could erroneous Arc behavior be fixed please?
rv1974
Postby jgb » Tue Jul 02, 2019 5:56 pm
I get that a lot too. Mentioned it numerous times in the past 8+ years and no improvement. Sometimes it works correctly, but I cannot define what works and what doesn't.
__________________
jgb
User avatar
jgb
Postby rv1974 » Tue Jul 02, 2019 8:34 pm
Yep it's present from day 1. The 'workaround' is not to start/end from the outer edges. Just a microscopic offset, then manually extend the arc Kinda helps in many (but not 100%) cases
rv1974
Postby fredo6 » Wed Jul 03, 2019 5:45 am
This is a fundamental flaw in the algorithm when you start from sharp borders.
So, not something simple to correct, versus revisiting seriously the algorithm itself.
User avatar
PluginStore Author
PluginStore Author
Postby jgb » Wed Jul 03, 2019 10:17 pm
What do you mean "sharp borders"?
__________________
jgb
User avatar
jgb
Postby fredo6 » Thu Jul 04, 2019 5:20 am
jgb wrote:What do you mean "sharp borders"?
Usual cases where you TOS algorithm has problem are those where the surface is a close shape and when you start from an edge which has a sharp angle.
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: planS and 15 guests
Visit our sponsors:
