Power Toolbar (2.5) - fix for 2019
Thank you! Also, sometimes it does not redraw the curve, but it just disappears.
Then I get this error in the Ruby Console:
Error: #<ArgumentError: Not enough points - at least 2 required> C:/Users/.../AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar.rb:3841:in `add_curve' C:/Users/.../AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar.rb:3841:in `main' C:/Users/.../AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:578:in `block in <module:Max_Coppoletta>' SketchUp:1:in `call'
JHS powerbar 2.4 + su17! What was the problem?
thanks for the wonderful plugin! very useful. I have a problem with the "extrude lines" tool. it does not work correctly. when I specify the height to which you want to squeeze a curved line, it does not squeeze it out, but simply moves it with copying. Do you know why this is so?
Silly question: Does it work with the latest SU?
Hi…
I have a question about extrude line in JHS Power Bar plugin. I have tried to create a line and select the line, then click on extrude line in that plugin, but it didn’t extruded as seen in youtube tutorial, it was only an offset from first to second point with the same line, there is no any extrusion at all. Please advise me how to correct my steps thanks.please refers to my link : https://ufile.io/fk7et
Will we get support for 2019? It doesnt seem to be installing correctly.
Only for Info, I used your bar a lot
Do you have the intension to update it for SU2019?Thanks
SZ -
Yes, hope to work on an update sometime soon, time is a bit short but I will.
also if problems, please try to be as specific as possible.
ok, try this - a quick fix so it loads. first test seems fine. so let me know if you encounter issues..
later i'll have a proper look at the script and update it properly - thanks
Hello,
I hope this chat also relates to jhs powerbar.
After intalling SU 2019 I get the following errorcode :Fehler beim Laden der Datei C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb
Error: #<SyntaxError: C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar.rb:7367: Invalid return in class/module body
return nil
C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:10:inload' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:10:in
<module:JHS_powerbar>'
C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:7:in<module:Max_Coppoletta>' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/jhs/_jhs_powerbar/jhs_powerbar_menux.rb:6:in
<top (required)>'
C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:inrequire' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in
load'
C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:16:inregister_extension' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:16:in
C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:8:in<module:Max_Coppoletta>' C:/Users/Architekt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/_jhs01_powerbar.rb:7:in
<top (required)>'unfortuantely I have no clou how to fix this.
Any suggestions ?
thanks
Uli -
@atelierpaar said:
Hello,
return nil
<top (required)>'
load'
Any suggestions ?
thanks
UliUli, is this with the file provided in the post directly above yours? (see below for quote).
[attachment=0:26dzmfax]<!-- ia0 -->Powerbar Fix for 2019.rbz<!-- ia0 -->[/attachment:26dzmfax]
yes Uli, as Juju said - make sure you have the latest update - i have no errors on my machine
Thanks, the bar is going to work in 2019
Not sure what it could be. I have uninstalled all previous versions, reinstalled the update, it shows up in the Extension Manager as enabled, but no toolbar and the CADFATHER PACK doesn't show up in the Help menu either.
that's weird - at least if you got an error message - and i take it the location allows full access (not sure on mac)
thanks to you all
after a fresh download everything is nice an shiny again
Uli -
I went through all my 2019 plugins folders and made sure to delete everything, re downloaded the fix, and then reinstalled and I do have it working now. Thanks for your help and patience with this. I couldn't live without Powerbar!!!
thanks
working also for me
regars -
Hi Max,
Can you put the latest version in the PluginStore? The one linked to there is out of date.
Thanks.
hi Dave, sure
