Layout renders hidden layers (2018)  Topic is solved
General discussion related to LayOut
Postby Aris » Wed Oct 03, 2018 11:34 am
Hi all,
I found out that SU 2018 rocks!
a small problem with layout though (and it might be just me not understanding something):
I created two layers, one with content and one 'beneath' it with guides (lines and rectangles)
When I exported the pdf, I 'blinded' the guide layer but it still kept being exported to the pdf.
It was only gone when I deleted the layer with its contents.
Is this how it is supposed to work? because it is a problem if you want to update the model and export again at another date.
Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
User avatar
Aris
Premium Member
Premium Member
Re: Layout renders hidden layers (2018)
Postby Dave R » Wed Oct 03, 2018 1:30 pm
Normally layers that are not set to be shown should not show in the PDF export. Could you share the LO file that exhibits this problem so I can try an export to compare? That would help us sort out where things are going pear-shaped.
User avatar
Global Moderator
Re: Layout renders hidden layers (2018)  Topic is solved
Postby Aris » Wed Oct 03, 2018 1:48 pm
Hi Dave,
thanks for replying so soon but it was a false alarm.
I opened the pdf in the browser and for some reason it had cached the original file. I reopened the new version of the file with the guides hidden and it kept showing me the initial pdf.
It was a browser problem, not a layout problem. once I ctrl+F5'd it it showed the new version.
User avatar
Aris
Premium Member
Premium Member
Postby Dave R » Wed Oct 03, 2018 1:50 pm
Good enough.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to LayOut Discussions
Who is online
Visit our sponsors:
