[Plugin Beta] Animator - v3.3a - 22 Feb 21Re: [Plugin Beta] Animator - v2.2b - 14 Jul 18 (SU2016+)Is Animator and Thea 1.5 still working? I cannot get them to work together, I tried both from Animator dialog and from the Thea window to render an animation to no avail.
Good you signal it. Something has changed in Thea 1.5, and the method for rendering does not work as it used to (you can see it in the Ruby console). This simply prevents the rendering from Animator with Thea. is ennoying and there is little I can do on my side. Fredo
Re: [Plugin Beta] Animator - v2.2b - 14 Jul 18 (SU2016+)I have informed Tomasz about this issue, hopefully, he will fix it. I hear that Animator works with Vray now, I did not see Vray in the options, Is there a tutorial for Animator and Vray? I may need to use this if Thea is not working anymore.
I sent a message to Tomas too. VRay is supported, but same thing happens with the most recent version (v1.6), where the API is less stable and can hang. More generally, there is not a lot of attention from rendering software companies to provide a stable and flexible API to use rendering from an external program (like Animator). Fredo
That is too bad, so what do I do? Here are the options I have available, SU native or Thea, now that we know Thea no longer works (sad news) when I install Vray it will show up as an option? but the newest version does not work? so I have to somehow find an earlier version? Is there any other render engines that work with Animator?
Re: [Plugin Beta] Animator - v2.2b - 14 Jul 18 (SU2016+)Solo,
Twilight is also supported. By the way, you really need to install ffmpeg in order to get the video files (mp4, mov, ...). Otherwise, you'll only get a sequence of png image files). Fredo
Re: [Plugin Beta] Animator - v2.2b - 14 Jul 18 (SU2016+)EDIT: Version# corrected.........thanks Fredo
Solo Don’t know if this helps as I don’t know Thea’s last working version in Animator. (SU V1.5.09.547) https://www.thearender.com/site/index.php/downloads Last edited by Charlie__V on Wed Aug 15, 2018 1:51 am, edited 2 times in total.
Re: [Plugin Beta] Animator - v2.2b - 14 Jul 18 (SU2016+)Apparently, based on Tomasz advice, the problem disappears with the latest version 1.5.09.547.
I uninstalled Thea and then installed this latest version and it works again. Fredo
Re: [Plugin Beta] Animator - v2.2b - 14 Jul 18 (SU2016+)Hi Fredo
I have just downloaded your wonderful plugin and specially like the detailed control over keyframes management (easing etc) and the ability to render animations on vray. However, you have not built support into it so as to be able to render animations outside of the local environment (ie, vray cloud for instance) as 99% of professional animation renderings happen over render farms and not on local systems. Vray cloud https://www.chaosgroup.com/vray/cloud is the new rendering platform by chaosgroup like other 3rd party render farms out there and currently is in beta, free for testers. We are trying it out, and it indeed is good. Is it possible to export out Keyframes from Animator as Sketchup Scenes (complete with easing values etc), so that those may be given out to Vray Cloud? I am sure many architectural firms out there would want this feature. Thanks. Ar. Nitin Sharma 3DA Architects 3DADS
'Leadership, by Design' 3rd Dimension, Architecture Design Studio Re: [Plugin Beta] Animator - v2.2b - 14 Jul 18 (SU2016+)
Animator exposes an API for rendering software to batch the rendering from outside Animator. So far, only Thea has implemented it. Generating scenes is not a solution, because you can only handle the movement of cameras, not objects. Fredo
Re: [Plugin Beta] Animator - v2.2c - 26 Aug 18 (SU2016+)New Release: Animator - v2.2c - 26 Aug 18
Requirement: LibFredo6 v8.5a Minor release
_______________________________________________________________________________________ See plugin home page of Animator for Download of RBZ from the PluginStore. See Main Post of the Animator thread for more information.
Re: [Plugin Beta] Animator - v2.2c - 26 Aug 18 (SU2016+)Hi Fredo, I did some other tests with the plugin. But I was wondering, is it also possible to have a sun animation in these videos I made ( with thea render and animator ) ? So I want all the movement of the objects + sun animation ( from dusk till dawn for example), is this possible?
https://www.youtube.com/watch?v=9PKL0Gg3rfU https://www.youtube.com/watch?v=YWNq3IeCrPA other little thing: there is 'no clip defined in model' when I want to start animation render in thea render sketchup ( not animator). Even if I have the license done. Rendering from animator is no problem though. Re: [Plugin Beta] Animator - v2.2c - 26 Aug 18 (SU2016+)
Sun is supported (using Shadow Visual Effect). Just put two elements in the timeline with different dates and Animator will interpolate the shadows between the two. Fred
Re: [Plugin Beta] Animator - v2.2c - 26 Aug 18 (SU2016+)Hi, I have created a staging animation in SU for a construction of a metro station, an 8min video, approx. 160 scenes, showing how the station will be built from start to finish, with construction equipment, etc. I am looking for someone to turn this into a more photo realistic animation, add some movement to the construction equipment, etc. Animator seems like the right tool, though I have never used it myself. Is there someone that would be interested and had immediate availability to do this for me?
Regards, Michal Re: [Plugin Beta] Animator - v2.2c - 26 Aug 18 (SU2016+)Cannot find the explode function in the latest version.
Please advise. Thanks Re: [Plugin Beta] Animator - v2.2c - 26 Aug 18 (SU2016+)
It is in the Movement palette
Re: [Plugin Beta] Animator - v2.2c - 26 Aug 18 (SU2016+)It is chinese translation, 100%.
Thank you. Found it. Was a bit confused with the route. Re: [Plugin Beta] Animator - v2.2c - 26 Aug 18 (SU2016+)Hi Fredo. when I export animation or render plugin writes that it needs a Pro version where I can fix it or buy a Pro version ?
Re: [Plugin Beta] Animator - v2.3a - 14 Nov 18 (SU2016+)New Release: Animator - v2.3a - 14 Nov 18
Requirement: LibFredo6 v8.6k Minor release
Re: [Plugin Beta] Animator - v2.3a - 14 Nov 18 (SU2016+)Hi Fredo,
Is there an option for achieving transparent backgrounds when generating a video as an images sequence (PNGs)? Cheers, Chris Re: [Plugin Beta] Animator - v2.3a - 14 Nov 18 (SU2016+)
Good point. I have to test, but it should be possible. I'll have to add the option in the GUI too. Fredo
Thanks so much for the reply! Animator is such a fantastic plugin, but I was going insane trying to find that option since MSPhysics and ClothWorks have it. Adding it to Animator will truly complete the SketchUp animation trifecta as far as I'm concerned. Good luck and thanks again! ![]() ![]() Cheers, Chris* Re: [Plugin Beta] Animator - v2.3b - 16 Nov 18 (SU2016+)New Release: Animator - v2.3b - 16 Nov 18
Re: [Plugin Beta] Animator - v2.3c - 18 Nov 18 (SU2016+)New Release: Animator - v2.3c - 18 Nov 18
Requirement: LibFredo6 v8.6m Minor release
Thanks Fredo, Good news: I can now see the Transparent Background toggle button on the GUI. Bad news: I don't get transparent backgrounds in my PNGs when I export them with the option selected ![]() Re: [Plugin Beta] Animator - v2.3c - 18 Nov 18 (SU2016+)
Did you upgrade to LibFredo6 8.6m?
That did the trick! You're the man, Fredo! |
