[Plugin Beta] Curviloft 1.8a - 31 Oct 18 (Loft & Skinning)
Re: [Plugin Beta] Curviloft 1.7d - 31 May 18 (Loft & Skinnin
Postby fredo6 » Thu May 31, 2018 10:21 pm
NEW RELEASE: Curviloft v1.7d - 31 May 18
Curviloft 1.7d is a maintenance release fixing a bug in the automatic ordering of contours for the Spline tool.
See Plugin Page of Curviloft for Download (or use the Sketchup PluginStore plugin for auto-installation.
Main post of this thread
User avatar
PluginStore Author
PluginStore Author
Postby rv1974 » Fri Jun 01, 2018 8:45 am
Unprecedented responsiveness Fredo, many thanks!
I'll test the update later today.
Another imperfection (?, - maybe I just can't find right buttons) I encountered with Loft by spline is that
the inter-medial segments can't keep exact dimensions of initial profiles (lowest and highest ones in attached example 12X81m*, storey height is 3.5m). Another issue is that segments are slightly OFF XY Plane.
Is it possible to develop some special mode that'd keep segments exactly parallel to the input profiles, and if initial profiles are equal it'd keep their dimensions?
* P.S. In this particular case of 50+ storey towers PlayitItAgain script helped a lot.
rv1974
Postby fredo6 » Fri Jun 01, 2018 9:20 am
This seems to be a problem of geometry which you can simulate manually.
If you wish to keep the junction straight, then the intermediate profiles do not keep the same dimensions.
Also, the intermediate sections are parallel to the initial profiles. Do you have something different?
User avatar
PluginStore Author
PluginStore Author
Postby rv1974 » Fri Jun 01, 2018 10:54 am
With prussian pedantry I took all horizontal segments, run make faces and...
it did it all (: which proves you are right- they are horizontal. What misleads is "~" sign in measurements, must be some SU glitch.
rv1974
Postby rv1974 » Fri Jun 01, 2018 12:27 pm
Code: Select all
No, what is needed is intermediate segments to preserve initial dimentions of the profile.
In attached file the red body is OK (all horizontal segments keep right sizing),
and the blue one (lofting with 51 intermediate segments) misbehaves.
rv1974
Postby fredo6 » Fri Jun 01, 2018 1:08 pm
rv1974 wrote:No, what is needed is intermediate segments to preserve initial dimensions of the profile.
Then, Curviloft is not adapted, and you should use FollowMe Rotate or TIG Grow extensions.
With rotated profile, line joining the begin and end profile corner does not meet the corner of the intermediate profiles.
In your red shape, you can see that the short segments joining stores are not aligned and do not form a big straight line.
User avatar
PluginStore Author
PluginStore Author
Postby rv1974 » Fri Jun 01, 2018 4:02 pm
Thanks for mentioning those alternatives- I'll check them. I'm so glued to your tools that completely forgot others :)
BTW the straight line on a blue tower shows the horizontal segments don't sit perfectly on it. The gap is ridiculously small in real life scale (~0.3cm in the middle floors, but big enough to spoil the model
rv1974
Postby rv1974 » Wed Jul 18, 2018 6:22 am
Fredo could you take a look please
rv1974
Postby fredo6 » Wed Jul 18, 2018 2:46 pm
rv1974 wrote:Fredo could you take a look please
I need to consider this case of indetical profiles more seriously, which Curviloft did not really do.
So I'll come with something more robust.
User avatar
PluginStore Author
PluginStore Author
Postby Architure » Tue Sep 25, 2018 1:43 pm
Hi there,
When selecting more than 3 edge curves, and choosing for junction by orthogonal bezier curves, the surfaces do not get the reach the right spline method result.
Here is what the ruby console shows
Error: #<ArgumentError: Cannot create unit vector from zero length vector>
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:119:in `axes'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:119:in `compute_by_offset'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:58:in `compute_by_vectors2'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:86:in `compute_by_normals'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:357:in `block in spline_profiling_construct'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in `each'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in `each_with_index'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in `spline_profiling_construct'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:249:in `spline_junction_construct'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:497:in `generic_junction_construct'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1418:in `junction_construct'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in `block in link_construct_all'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in `each'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in `link_construct_all'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:396:in `link_calculate_all'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:530:in `option_set_prop'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:206:in `option_set_prop'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:773:in `call'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:773:in `block in pal_family_spline_method'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3963:in `call'
Just ask me for the file if needed!
Cheers
Manuel
Architure
Postby fredo6 » Wed Sep 26, 2018 1:14 pm
Architure wrote:Just ask me for the file if needed!
Yes the file would be useful, as this seems to be a special case.
User avatar
PluginStore Author
PluginStore Author
Postby Architure » Thu Oct 04, 2018 4:26 pm
Hi there,
Sorry for my late reply. Here is the attached 2018 skp file . You can see that the selected mode is only applied between the first 3 curves.
Let me know if I can provide more information.
Cheers
Architure
Re: [Plugin Beta] Curviloft 1.8a - 31 Oct 18 (Loft & Skinnin
Postby fredo6 » Wed Oct 31, 2018 10:07 pm
NEW RELEASE: Curviloft v1.8a - 31 Oct 18
Curviloft 1.8a is a maintenance release for bug fixing.
User avatar
PluginStore Author
PluginStore Author
Postby pilou » Tue Nov 13, 2018 1:28 pm
Loft along the path: can we modify the path after launch the plugin?
I don't see it! (the path)
Speedy Galerie
User avatar
Top SketchUcator
Postby zswseu » Wed Dec 05, 2018 4:43 am
Looking forward to another excellent work.
zswseu
Postby rv1974 » Mon Dec 10, 2018 1:03 pm
In 99% of of lofting uses I have to straighten borders connnecting ends of segments afterwards (thanks Thom there're Edge tools so it's not manual). Could there be an option to keep them straight when creating?
rv1974
Postby fredo6 » Mon Dec 10, 2018 2:42 pm
rv1974 wrote:In 99% of of lofting uses I have to straighten borders connnecting ends of segments afterwards (thanks Thom there're Edge tools so it's not manual). Could there be an option to keep them straight when creating?
Not too sure what you mean by 'straighten'.
Maybe an example would be helpful.
User avatar
PluginStore Author
PluginStore Author
Postby rv1974 » Mon Dec 10, 2018 8:07 pm
Edit: Only after posting I figured out 'junction by connected lines' in 'spline method' fixes this problem' :)
rv1974
Postby fredo6 » Mon Dec 10, 2018 9:58 pm
rv1974 wrote:Edit: Only after posting I figured out 'junction by connected lines' in 'spline method' fixes this problem' :)
I really need to refresh the plugin with more explicit control of the different options (and maybe selecting a few ones which make sense). Currently, Curviloft rather exposes the options that come from the algorithm, up to the user to find out what is appropriate. That's why I still leave it in Beta after all these years!
User avatar
PluginStore Author
PluginStore Author
Postby jgb » Mon Dec 10, 2018 11:05 pm
I wholeheartedly agree, but please also update your last 32 bit version as well.
I cannot run 64 bit apps on my old PC. I'm still running Make V.13.
__________________
jgb
User avatar
jgb
Postby fredo6 » Tue Dec 11, 2018 12:41 am
jgb wrote:I wholeheartedly agree, but please also update your last 32 bit version as well.
What do you mean?
Do you have issues with Curviloft on Sketchup 2013?
User avatar
PluginStore Author
PluginStore Author
Postby rv1974 » Tue Dec 11, 2018 7:54 am
I searched hard to find how to save this method as default but no luck. Is it possible at least make this tool to remember last used settings at least? If it could remember them permanently it'd be even better. Thank you.
rv1974
Postby fredo6 » Tue Dec 11, 2018 8:29 am
rv1974 wrote:I searched hard to find how to save this method as default but no luck. Is it possible at least make this tool to remember last used settings at least? If it could remember them permanently it'd be even better. Thank you.
Do you use the latest version (1.8a)? It keeps the latest settings across Sketchup sessions and I checked it works with SU2013.
User avatar
PluginStore Author
PluginStore Author
Postby rv1974 » Tue Dec 11, 2018 10:42 am
Great news! :enlight: Gone refreshing ALL of yours
rv1974
Postby rv1974 » Tue Dec 11, 2018 11:18 am
I checked, v1.8.a doesn't keep my last used settings (at least junktion by connected lines method)
rv1974
Postby fredo6 » Tue Dec 11, 2018 11:35 am
rv1974 wrote:I checked, v1.8.a doesn't keep my last used settings (at least junktion by connected lines method)
I forgot to say that you need to enable the option in Default Parameters....
User avatar
PluginStore Author
PluginStore Author
Postby jgb » Tue Dec 11, 2018 5:02 pm
What do you mean?
It's not that I have issues with CL in SU-2013, just I thought the latest CL update versions were 64 bit only. I will D/L the latest later this week.
__________________
jgb
User avatar
jgb
Postby fredo6 » Tue Dec 11, 2018 5:32 pm
jgb wrote:It's not that I have issues with CL in SU-2013, just I thought the latest CL update versions were 64 bit only. I will D/L the latest later this week.
In principle, Ruby script are independent from the OS details (hopefully), but sometimes dependent on the SketchUp version.
The trend is effectively that I will progressively transition my scripts toward SU2016 and above, but I'll keep usually the existing version, at least in maintenance mode, and the new version would probably include more functionality. This is what happens with RoundCorner and FredoCorner. So when you see FredoLoft published for SU2016+, you would still have access to Curviloft, even if it would likely be in maintenance mode.
User avatar
PluginStore Author
PluginStore Author
Postby jgb » Tue Dec 11, 2018 7:33 pm
Thanks again. :D I'll now upgrade SU to 2016 (32bit) and all my plugins/extensions as well.
__________________
jgb
User avatar
jgb
Postby Einstein » Fri Jan 11, 2019 1:26 pm
I made a loft and added a forced pair for each vertex of profile. Now there are some unnecessary pairs (yellow ones) between vertices and I was thinking if it's possible to remove them before applying the loft.
In this case both profiles - upper and lower - are hexagons. So intuitively, pairs should be created between vertices only. Instead, Curviloft connected each vertex of lower profile to edge midpoint of upper profile, which created a lot of unnecessary edges. So I'm thinking if I could force the tool to always match vertex-to-vertex when profiles have the same number of verts.
Einstein
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: ansdud, caramelsnow, dhoanglonghai250791, dtrarch, sheilly and 10 guests
Visit our sponsors:
