[Plugin] ClothWorks v1.7.9 - 18 Apr 2024
@valerostudio said:
Is there a way to have pressure (or have a future feature) where you can have a pillow and drop it on to a sofa or bed? I have played with this in Max a little bit.
Nice video! Soft bodies are planned for V2.
Although we'll have to wait for future releases to do this properly, it's still possible with the current version.
I just need to pull out my finger and find a screen capture method for recording my workflow.
My first test with the plugin, it has a lot of possibilities.
Hieru and Oxer - your examples just above are so great !!
how do you manage to generate these voluminous cloth shapes - whether as a pillow or a sack full of potatoes? what I mean is, which kind of cloth surface collides here onto or around which collider to get such a complex kind of result? -
A picture is worth more than 1000 words.
New test, ClothWorks+MSPhysics, I modeled the potatoes and they placed with MSPhysics.
Hi Anton.
Bought and testing. Simply AWESOME. It's just what I needed. Anton, you're amazing.
still trying to make pillows.
but I'm not getting on...
Any ideas or tutorials?
@ Oxer: how did you fix the frame?
draping simple grids works fine. I've made a model of my curtain samples
please help me out of my hole - I try and try but don't get any idea what to do in which way to achieve such kind of shapes
The frame is a pin, select the frame > right click > Make Pin
oxer
Thank you for the pictures. Please forgive my dullness, but could you explain how to use each of the pictures? -
That's very smart...it will probably remove a step when I record my pillow workflow .
impressive work oxer!
Thank you, oxer
You're welcome!
Care Frederik!! "The curiosity killed the cat"
The possibilities are endless, you can use ClothWorks to create a lot of different organic objects, more examples at the end of the day or tomorrow.
