TreeIt : Free tree generator
Useful freeware apps related to designing and productivity.
Postby pilou » Mon Jan 22, 2018 2:19 pm
Tree generator (only Windows) with settings!  :)
(There are some trees yet done! Export OBJ, dbo, x:)
No need to press the "Generate" button unless you put branches and leaves! :ugeek:
http://www.evolved-software.com/treeit/treeit
And you can of course load any PNG images with transparent background as "leaves"!
(even if not indicated in the drop-down menu files)
If you want to put native dds formats (Direct Draw Surface) you will have to use PaintNet to create some!
3
Speedy Galerie
User avatar
Top SketchUcator
Re: TreeIt : Free tree generator
Postby sofie9536 » Mon Jan 22, 2018 2:48 pm
very thanks, fine
sofie9536
Postby McGyver » Tue Jan 23, 2018 4:53 pm
Thank you Pilou!
User avatar
McGyver
Postby JQL » Tue Jan 23, 2018 5:34 pm
Looks good but doesn't work on my system unfortunatelly.
User avatar
JQL
Premium Member
Premium Member
Postby kaas » Tue Jan 23, 2018 6:04 pm
The size of leafs seems way off... Also, whats the triangle count of the trees? 1k 10k 100k?
kaas
Postby Stinkie » Wed Jan 24, 2018 3:05 pm
Cool! Thanks for the heads up, Pilou. :thumb:
User avatar
Stinkie
Postby pilou » Wed Jan 24, 2018 3:20 pm
1k 10k 100k?
Only depends of what you define as parameters! ;)
My red hypo-tree above OBJ + Texture mtl files = 585 kb
and compressed 143 Kb! ;)
Speedy Galerie
User avatar
Top SketchUcator
Postby Pixero » Wed Jan 24, 2018 4:19 pm
Has anyone found a way of having more than 250 leaves?
User avatar
Pixero
Postby Mike Amos » Thu Jan 25, 2018 2:48 pm
Would make fur by component do the trick?
Premium Member
Premium Member
Postby Mike Amos » Thu Jan 25, 2018 2:49 pm
pilou wrote:
1k 10k 100k?
Thanks very much.
Premium Member
Premium Member
Postby pilou » Thu Jan 25, 2018 3:48 pm
In Menu Leaves / Dupplicate layers any times you want! (9 Max) ;)
So 250 * 9 = 2 250 leaves! :ugeek:
Speedy Galerie
User avatar
Top SketchUcator
Postby Pixero » Thu Jan 25, 2018 6:31 pm
Yeah, but even 2250 leaves are not much if your going for something that look real. All examples have the twigs and leaves as an image plane. Seem to be more for real time games and such.
User avatar
Pixero
Postby pilou » Thu Jan 25, 2018 7:18 pm
Tree It is an easy to use and powerfull real time 3d tree generator for the simple creation of your very own 3d tree models for your dark basic pro and dark GDK apps and games. All Tree It model exports are 100% free to use with any engine and project, whether it's darkbasic or unreal 4.
Maybe you can take png "images" with many leaves ?
Speedy Galerie
User avatar
Top SketchUcator
Postby McGyver » Sun Jan 28, 2018 5:57 pm
Pixero wrote:Yeah, but even 2250 leaves are not much if your going for something that look real. All examples have the twigs and leaves as an image plane. Seem to be more for real time games and such.
You could do as I believe Pilou is suggesting, and perhaps instead of using images of single leaves, use images of smaller branched groups... This might not be too useful with trees like maples, where the spacing of the leaves is uniform and a bit distant, but for certain oaks where the leaves are closer together and more irregularly placed, it works well.
I made a PNG in Photoshop once using images of a bunch of diffent oak leaves I photographed and connected them using some thin branch images... It was a bit of work, but it allowed for a fuller looking tree that needed fewer leaves.
User avatar
McGyver
Postby pilou » Thu Nov 08, 2018 12:27 pm
Seeems there is a new version 7 11 2018
Treeit
:mrgreen:
Speedy Galerie
User avatar
Top SketchUcator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Freeware
cron
Who is online
Users browsing this forum: No registered users and 0 guests
Visit our sponsors:
