[Plugin] Roof.rb
Re: [Plugin] Roof.rb
Postby TIG » Thu Jan 26, 2017 1:50 pm
The change was to make it compatible with v2017.
Its usage is unchanged...
User avatar
Global Moderator
Postby tspco » Fri Jan 27, 2017 4:26 am
Tonight I saw an update for Tig's Roof plugin, I installed it, and it worked a couple of times. then I get this, Maybe I did something wrong, I don't know for sure.
SU make 2017, /Twilight Render Hobby
Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
tspco
Postby TIG » Fri Jan 27, 2017 2:27 pm
This is a known limitation.
Please read the recent posts...
The seed-face used for a hipped roof must NOT be at z=0 [when do you see a roof on the ground ?], and it should also be oriented to face upwards.
Your test examples seem to involve a rectangle drawn directly onto the ground and it is facing downwards too !
Extrude that face upwards into a 'box', select its top face, and now a hipped roof should form OK...
User avatar
Global Moderator
Postby tspco » Sat Jan 28, 2017 3:41 am
That makes sense, when I mentioned it worked, I was in another project and drew the roof on the floor (above 0Z) of that model, just experimenting with the update.
tspco
Postby tylovset » Sat Jan 28, 2017 12:53 pm
TIG,
I made a shape where I can create a Mansard roof, but it says it cannot make a Hipped roof.
I mention this because the algorithms seems similar. In fact, I can set "Height of Lower Roof" to only 1cm and it looks like a regular Hipped Roof. However, setting the height to 0 fails like Hipped roof.
Could it be a bug? Here's the file: https://1drv.ms/u/s!AnwI6G-MJcza1X_aCfVxdSqVB69t
tylovset
Postby TIG » Sat Jan 28, 2017 2:31 pm
The code for both roof-types is very similar, so I can't see why the hipped one fails.
However, it was easily fixed: I deleted the top face and drew over a single edge, so that SketchUp added back the face - as explained in the error-message sometimes a face's edge-order/loop-direction becomes confused in the SKP's data-base.
That replacement face then made a hipped roof without any difficulty...
User avatar
Global Moderator
Postby mariocha » Tue Dec 19, 2017 2:15 am
Anyone else having this bug with Gable Roof when using ^Height ?
Error: #<NoMethodError: undefined method `length' for nil:NilClass>
C:/Users/---------/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Roof.rb:1725:in `dialog_gable'
C:/Users---------/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Roof.rb:2376:in `gable'
C:/Users/--------/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Roof.rb:3919:in `onLButtonDown'
Mario C.
Certified SketchUp Trainer, QC CA.
Every rule has exceptions, but some.
User avatar
mariocha
Premium Member
Premium Member
Postby TIG » Tue Dec 19, 2017 1:47 pm
Have you tried ^55" ?
EDIT: Forget that.
It's nothing to do with it per se, although it only manifests itself using ^Height...
There's a weird typo in the gable making code which I need to resolve...
Watch this space...
User avatar
Global Moderator
Postby TIG » Tue Dec 19, 2017 2:13 pm
Here's v5.0
Download
It fixes a typo in the Gable by ^Height code which caused a failure.
this was a long standing typo, which has taken several years to find and be reported on !
The code is also re-signed for v2018 compatibility...
User avatar
Global Moderator
Postby Ahmed0007 » Tue Dec 19, 2017 6:17 pm
Please Update Follow me & Rotate
Ahmed0007
Postby TIG » Tue Dec 19, 2017 7:52 pm
Ahmed0007 wrote:Please Update Follow me & Rotate
This is not the correct thread to post this request.
This FaR tool has its own thread[s].
Although I have helped resolve some issues with FaR ver the years, it is NOT my code and is copyrighted and encrypted by its author.
So nag him - not me !
3
User avatar
Global Moderator
Postby mariocha » Wed Dec 27, 2017 4:08 pm
A localizable version named Roof-LH.rbz is now available. (LanguageHandler)
French strings included.
Please note that this is not a full version since 'Layers & materials' options have been removed from it.
Available on http://www.formation-sketchup.quebec
if requested I can also load it in the PluginStore.
Happy new year all.
Mario C.
User avatar
mariocha
Premium Member
Premium Member
Postby archarles » Wed May 23, 2018 12:46 am
Hi dear author, I tried the 'pick-three-point' to create a gable roof, but after the last click there is no menu come out. Do you have any suggestion. BTW, only 'select from face' options are still workable.
Cheers.
Charles.
archarles
Postby TIG » Wed May 23, 2018 10:40 am
The 3 points must all be in a horizontal plane [say the top of walls?]
1 & 2 defining the width of the gable triangle and then 3 sets the length of the eaves...
If you run it with the Ruby Console do you see any error messages ?
User avatar
Global Moderator
Postby bisnisbali » Sat Mar 23, 2019 12:47 pm
please update for sketcup 2018, thanks
bisnisbali
Postby TIG » Sun Mar 24, 2019 7:29 pm
It works fine in v2018 and in v2019.
It's already fully signed and compatible with all current SketchUp versions.
A few posts back [at the end of 2017] I posted to say v5.0 was now compatible with v2018 !
I just hadn't updated details on its main page...
Now done.
User avatar
Global Moderator
Postby kubra26 » Thu Apr 11, 2019 2:56 pm
hello 2018 sketchup plug-in downloaded but says invalid signature can you help me
kubra26
Postby TIG » Fri Apr 12, 2019 12:47 pm
If you get the latest version of 'Roof' from the PluginStore, then it should be fully signed and compatible for all current SketchUp versions...
Where did your problem version come from ?
Notwithstanding that - in reality the 'validity' of the extension's signature [or it even being 'unsigned'] doesn't matter very much.
If you have download an extension's RBZ from a trusted source [like EWH, SketchUcation, or a well known developer's web-site], then that RBZ might be somewhat old and therefore it's not been re-signed for some newer versions of SketchUp, BUT it is very probable that it will still work in those newer versions.
It's a PITA to get everything recompiled into an RBZ, and submit it to SketchUp's portal to get the latest signature added, then republish it: older extensions that haven't needed updating to suit changes in the newer SketchUp's Ruby API, will often have out of date signatures, or might even be 'unsigned'.
With 'free' extensions it's unreasonable to expect authors to re-sign everything, at every update...
The global fix is easy - to allow you to load and use these older plugins and extensions... simply set your SketchUp > Window > Extension Manager > Loading Policy to be 'Unrestricted'.
After you restart SketchUp and previously 'blocked' extensions will be loaded and be available for use...
User avatar
Global Moderator
Postby JakubPelka » Tue Apr 23, 2019 1:58 pm
It's great plugin. Thanks!
But... is there a chance for a Gambrel option?
Will be glad for any info!
JakubPelka
Postby TIG » Wed Apr 24, 2019 1:41 pm
It's an old Plugin, unlikely to have any major changes...
There's already a 'Mansard' option - this allows you two roof pitches per slope - to make a Mansard or Sprocketed roof form.
If you want your own kind of 'Gambrel' roof [which I think is called a 'Mansard' roof in many other locales], then you can edit a simpler roof form - and manually add/erase the necessary changes ?
User avatar
Global Moderator
Postby Ray Brown » Sat Oct 26, 2019 9:35 pm
TIG:
What am I missing?? I've installed V5.0 and still can't get hipped roof to work in either 2018 or 2019 on my MacBook Pro. I've followed your Help instructions, but nothing seems to work. I can generate gable end and pyramids, but no hips or mansards. HELP!!
Ray Brown
Ray Brown Urban Design
Ray Brown
Postby TIG » Sun Oct 27, 2019 1:56 pm
Have you run it with the Ruby Console open to see if there are any error messages ?
The face you use to make the outline of the hipped roof cannot be at z=0...
Draw a shape on the ground [z=0], then extrude it upwards using PushPull.
Now select just the top face of the geometry and run the Hipped Roof tool...
Any luck ?
User avatar
Global Moderator
Postby Ray Brown » Sun Oct 27, 2019 5:18 pm
When I ran it with the Ruby Console open, there were no error messages and the Plugin worked just fine in both 2018 and 2019. Some kind of long-distance sorcery from you, no doubt. Thanks.
Ray Brown
Ray Brown
Postby Juanjoxxx » Tue Dec 10, 2019 1:24 am
For me, it doesnt work.
When I run the program, it exits or closes.
Juanjoxxx
Postby TIG » Tue Dec 10, 2019 1:10 pm
Juanjoxxx wrote:For me, it doesnt work.
Please explain more details.
Is this problem in v2017 ?
If you run it with the Ruby Console open are there any error messages ?
There are several tools with the 'Roof' set: which one is causing the problem ?
When you say 'it exits' do you mean it just doesn't do any thing, or that SketchUp itself closes ?
No error messages at all ??
Are you using the tool as the usage notes explain ?
e.g. the flat face forming the outline for the hipped roof tool cannot be at z=0, and it is possible to devise a face that cannot accept a hipped roof - but then an error message should tell you that...
User avatar
Global Moderator
Postby kaciecomeaux » Mon Feb 17, 2020 3:48 pm
I have downloaded this roof tool but I am having a hard time using it. I watched videos. I use sketchup with dynascape. I import 2D drawings into skethchup and replace with components. When I use the select face roof tools, like hipped or gabled roofs, nothing happens. Only the color of the face changes but stays flat. I'm not sure what I am doing wrong. Is there somewhere that I can obtain more info on how to use this tool? I thought maybe these roofs are too complex for the tool, so I created a box and tried to put a roof on it and the same thing happens. Please Help! It looks like it can be an amazing tool if I could just get it to work.
kaciecomeaux
Postby TIG » Mon Feb 17, 2020 8:03 pm
It is an old toolset... but it should work.
Use it with the Ruby Console open...
A few pointers...
The face for a hipped roof must be flat and NOT at z=0.
There should be prompts on the status-bar and dialogs that ask for inputs...
Report any errors from the Ruby Console...
User avatar
Global Moderator
Postby kaciecomeaux » Mon Feb 17, 2020 9:30 pm
TIG wrote:It is an old toolset... but it should work.
A few pointers...
The face for a hipped roof must be falt and NOT at z=0.
Please forgive me, I am fairly new to sketchup. I know that is a ruby file but what does " use it with ruby console open" mean?
kaciecomeaux
Postby pilou » Mon Feb 17, 2020 11:29 pm
It's a little box screen that display in text mode in real time all that is working on the screen of Sketchup!
If there is an error that is displayed and like this that help a lot for debbugging! :)
Speedy Galerie
User avatar
Top SketchUcator
Postby TIG » Mon Feb 17, 2020 11:37 pm
Menu - Window > Ruby Console...
Opens a window that lists errors/outputs and also lets you type in simple Ruby commands...
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Extensions & Applications Discussions
Who is online
Users browsing this forum: No registered users and 7 guests
Visit our sponsors:
