[Plugin] Multiple Component Edit Warning
Thanks TIG - changes made
any recommendations on the plugin? Do you use it yourself?
Thanks for this Ash - A neat plugin - instant satisfaction ! no loading, or switching on toolbars, it simply works .
I wouldn't mind paying something for this plugin - it sure will save some time (and time really is money) - with an (overly complex) file, I recently changed all my broadleaf to fluoro green, when I thought I made the one I was working on unique .
@Ash, thanks for renaming the topic thread.
It should make more sense to persons browsing the Plugins Forum list.
I check the forum most days but somehow I missed this fantaboulous helper, I love it!!!
My worst disaster was when a client wanted small changes amounting to 8 versions, then decided to go back to the original which was, you guessed it, totally screwed. Had to redraw from scratch almost.
I would happily pay for this.
Thanks Ash and Dan.
Thanks Baz, we think its handy.
Seems every time I bump into a sketchup user they lament about this issue but haven't heard of the plugin and are quite excited when I show it to them.
I should try promote it harder I guess...
I found it purely by chance under 'Text/Labeling' in the Plugin Store widget inside SU. Not very intuitive because I didn't know I needed it til then, as I knew the problem was my error, Duh!
I think you should sell it to Trimble, it should be part of the GUI just like the popups which warn of 'changing styles'/'you are about to intersect with hidden geometry'/'your model is crap, start again' etc..
Actually, I made the last one up... but what an idea for a plugin!
Rgds from the home of the Wallabies
Convince Trimble to buy it and I'll send you a pet kiwi
P'haps Chris Fulmer or TomTom will see this. Tho I have no idea whether Trim ever 'buy' plugins. I s'pect not.
Its pissing down here in the shed, I can hardly hear myself think. -
@ashscott said:
..Bug fixed so that multiple edit warnings do not appear on top of each other..
There are 2 overlapping warning windows in SU 2018. Anyone to confirm?
Worked with SU 2020. Seems not to work with SU 2021. Can anyone confirm?
@creativegood said:
Can anyone confirm?
Yup, busted for me as well. Bummer this is a regular use one I loved.
I'm not sure if the author Ash is still about...
However, it's easy to fix the error - the newer Ruby version is stricter than it was years ago !Find the relevant file:
C:\Users\YOURUSERNAME\AppData\Roaming\SketchUp\SketchUp NNNN\SketchUp\Plugins\CoastalConcepts_EditFlas\EditFlag.rb\
You'll need to edit the text to include your Windows user-name and change the NNNN as the relevant SketchUp version - e.g. 2021Select that RB file and edit it using a plain-text editor - like Notepad++...
Find the lines #17 to #21 which read...unless defined?(OPT_KEY) VERSION = '2.4.0' LOAD_TAG = Module.nesting[0].name<< ':' << File.basename(__FILE__) OPT_KEY = 'Plugin_' << Module.nesting[0].name.gsub('::','_') end
so that they read as follows.
unless defined?(OPT_KEY) VERSION = '2.4.0' LOAD_TAG = Module.nesting[0].name.dup << ':' << File.basename(__FILE__) OPT_KEY = 'Plugin_' << Module.nesting[0].name.dup.gsub('::','_') end
Note the two additions of
.dup
code, which copy the 'frozen-string' in the module's name and use that instead, as a frozen-string cannot now be directly changed in code, without this sidestepping... -
However, it's easy to fix the error - the newer Ruby version is stricter than it was years ago !You are, as ever, awesome. Thank you for this! I'll have to edit the plugin code this weekend when I get the chance.
I keep meaning to make the time to start writing scripts for SketchUp. Are there any ruby courses or books you'd recommend? I have Automatic SketchUp by Matthew Scarpino but I expect the version of ruby has changed a lot in the years since that's come out.
@tig said:
I'm not sure if the author Ash is still about... However, it's easy to fix the error - ...
.dup
code, which copy the 'frozen-string' in the module's name and use that instead, as a frozen-string cannot now be directly changed in code, without this sidestepping...I just noticed this as I'm not over here at SCF much these days.
It was I who wrote this extension for Ash, long before the frozen string madness.
I did not realize that
Module::nesting[i].name
, ... actuallyMoudle#name
returned a frozen string. Even the Ruby v2.7.2 documentation does not indicate this. (Doesn't indicate much of anything really.)But it does make sense that all the class and module identifier strings would be frozen (likely linked to symbols.) I went back to v2.2.4 in SU2017 and repeatedly called
#name
on a module object and got a different string object and id each time called. (Not very efficient.)
The same test in latest version returns the same object, with the same id, each time called.I've not been running into it as I suppose I've not been using
String
append (<<
) much because of the gotchas like this.I'm more inclined these days to use interpolation like:
LOAD_TAG = "#{Module.nesting[0].name}:#{File.basename(__FILE__)}"
... which itself creates a new string.BTW ... the second assignment to
OPT_KEY
does not need the.dup
as.gsub
makes the copy. (Verified in Ruby 2.7.7 with SketchUp 2023.) -
Hello! First I would like to apologize if there is any grammatical error. Because I'm using Google Translate to translate from Brazilian Portuguese to English.
When I install the Edit Flag v2.4.0 plugin in SketchUp in Brazilian Portuguese, the tool name does not appear.
How could I fix this bug?
