[Plugin] !AdditionalPluginFolders - v5.0a - 13 Nov 15  Topic is solved
Re: [Plugin] !AdditionalPluginFolders - v5.0a - 13 Nov 15
Postby Bob James » Thu Oct 12, 2017 9:49 am
fredo6 wrote:NO. You put AdditionalPluginFolders plugin only in the native Sketchup Plugin directory. This will allow AdditionalPluginFolders to be loaded by Sketchup, and then to load plugins from your Box directory, where you have your shared plugins.
Apparently I was not clear in my question. My AdditionalPluginFolder plugin is only in the native folder as I mentioned earlier. I was asking about all the rest of the plugins. It was unclear which you were advocating: Other plugins just in the Dropbox folder or in both the Dropbox folder and the native folder.
fredo6 wrote:Do you still have it?
If by "it" you mean the folder setup putting most of my ~1GB of plugins in E:\Dropbox\plugins and identifying that path in AdditionalPluginFolders, then yes. These plugins are the plugins that were originally all in the native plugin folder.
Because of the strangeness of the "working and then not working" problem and the difficulty of troubleshooting it, I've decided to abandon trying to use AdditionalPluginFolders and go ahead and have each computer with its own native plugin folder and go back to trying to keep them both up to date (probably by synchronizing the folders after changes).
Thank you for taking the time to help.
User avatar
Bob James
Premium Member
Premium Member
Postby fredo6 » Thu Oct 12, 2017 5:44 pm
To summarize:
- AdditionalPluginFolders --> SU native Sketchup plugin directory
- plugins --> either in Box folder or in SU native Sketchup plugin directory but not both.
Note however that most plugins won't load twice, even if they are in the two directories.
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: arbaaz shaikh, Deissy, Eduardo Serpa, ggodby, hly74, juanilakd, maxresist, Oliv6000 and 12 guests
Visit our sponsors:
