[Plugin Beta] Animator - v2.8a - 17 Sep 20
General discussion about Animator for SketchUp
Fog.. etc
Postby tomaszdrgas » Mon Aug 07, 2017 7:52 am
"Fog" doesn't change smoothly between cameras, like "shadows" and "field of view" does. It just jumps to next style's value.
"date" for shadows. If I have to cameras based on sceens with two different dates (june and october), it causes jumping creasy shadows. not often people would use that but that little thing to fix.
As well when adding camera based on sceen, using styles, layers visibility and shadows connected to camera could be by default turned on (seems good to me).
When using camera captured from current view, options for using shadows, layers and styles attached to camera are not greyed out.. Is it becuse you can attach them? When I clicked shadows on, than it stopped the animation at the end of duration of previous camera.. so seems like it lucked of informations.. OOKK that was becouse I didn't turn on shadows on when capturing the camera.. When I chose the camera and recaptured with new shadows it worked.. though would be good it there was something in memory even if I don't turned it on..
There is nice smoothing of the path between the possitions of ongoing cameras. So the path of camera is a nice curve. (with bezzier) But speed is stil interpolated only between two consecutive cameras so there is no smooth change of sppeed in the point of camera's placement.. this one could be "eased" too... I was hoping for that ..
Tomasz
tomaszdrgas
Re: [Plugin Beta] Animator - v1.7a - 09 Jul 17
Postby tomaszdrgas » Mon Aug 07, 2017 8:26 am
To Fredo6 - Just very curious.. Are you a man or an institution.. Somehow can not fit it in my small head that someone having regular job, does all that work with plugins for free as a hobby in free time.. It seems not an easy thing to write it and you do a LOT..
Big thanks... for all..
tomaszdrgas
Re: Fog.. etc
Postby fredo6 » Mon Aug 07, 2017 1:33 pm
tomaszdrgas wrote:"Fog" doesn't change smoothly between cameras, like "shadows" and "field of view" does. It just jumps to next style's value.
Fog is not supported (yet) in Animator. So it does not do any interpolation
tomaszdrgas wrote: "date" for shadows. If I have to cameras based on sceens with two different dates (june and october), it causes jumping creasy shadows. not often people would use that but that little thing to fix.
Animator interpolates between the two dates. So, between June and October, you'll get many nights and days! What I think should be a nice add-on is to keep the day-time of the first day specified, and shows how the shadow becomes on the other days. I'll introduce this in a next version.
tomaszdrgas wrote: As well when adding camera based on sceen, using styles, layers visibility and shadows connected to camera could be by default turned on (seems good to me).
Views (and Scene) sequences are always captured with all style elements. However, the style can be enabled or disabled for the elements in the timeline. I could not make my mind about the default (currrently style is Off). I guess some users would use views just for the camera positioning and treat styles independently, via visual effects.
tomaszdrgas wrote: There is nice smoothing of the path between the possitions of ongoing cameras. So the path of camera is a nice curve. (with bezzier) But speed is stil interpolated only between two consecutive cameras so there is no smooth change of sppeed in the point of camera's placement.. this one could be "eased" too... I was hoping for that ..
I plan to introduce a Travelling camera, where there is a control over the speed of camera (constant or eased or dependent on curvature of the path).
User avatar
PluginStore Author
PluginStore Author
Postby fredo6 » Mon Aug 07, 2017 1:35 pm
tomaszdrgas wrote:To Fredo6 - Just very curious.. Are you a man or an institution.. Somehow can not fit it in my small head that someone having regular job, does all that work with plugins for free as a hobby in free time.. It seems not an easy thing to write it and you do a LOT..
I am alone, and does not even have lot of free time. So progress is slow!..., considering I wrote my plugins over 10 years now.
5
User avatar
PluginStore Author
PluginStore Author
*.skp dissapeared
Postby tomaszdrgas » Tue Aug 08, 2017 4:07 am
So I opened the same file today and animation again stopped on the end of duration of sceen camera before the "capture view" camera with attached shadow.. I thought maybe I haven't saved something yesterday. So I recaptured the view with changed shadow, saved inside animator and after going out of it.. Don't remember on which save I had notification " C file 5 exception ...bla bla bla" These are only worlds I remember. I didn't knew whats that about.. sKetchup was still working all looked fine..
I opened new file to again reopen my test animation and then I found test.skp is gone.. I saved twice so I could just use skb without problems but that was strange.. And happened second time this week just before I didn't connect it with another test file missing.. I'll show you the message if it happens again..
test2 MP4.skp
tomaszdrgas
Postby fredo6 » Tue Aug 08, 2017 8:03 am
Tomasz,
There is a small bug in the interpolation of shadows. Something weird, since apparently a shadow may not have a time defined (shadow["ShadowTime_time_t"] is nil).
I fixed it and will republished.
I doubt however that this can provoke a "C File5 exception", but it creates a problem in the animation of view.
Also, Animator just saves the animation data in the model, but cannot erase the skp file itself.
PS: I noticed that you also lost the spinning of the wheels. I re-established it in the attached skp.
User avatar
PluginStore Author
PluginStore Author
Spinning wheels
Postby tomaszdrgas » Wed Aug 09, 2017 1:48 am
I was looking for a way to remove some objects from the movement and adding others without deleting and creating another movement.. though I was uneable to do so.. probably some luck of click somewhere.. I haven't noticed it in tutorial..
I could go into edition of movement and select some but green arrow with dot for saving changes would stay greyed out.. When I deselected all (using arrow with x sign provided in animator) and selected what I wanted then green was green but all stopped spinning. I was going to look for that myself not to bother pros with such a littlies.. but I tried and no more ideas..
And the wheels spin opposite way than the arrow shows even though angle is possitive. When I change to negative (-795) they spin opposite direction but arrow aswell changed to opposite so it is always pointing wrong..
I'm actually childish proud of myself that I have actually foud a bag.. I mean you did, but... I helped..
I don't know who did it, but the file did dissapear. And in place of it was another file 1.skb . With same (about) time of creation like the time of dissapearing. And with date for a day ealier when simillar thing happend I have 0.skb file. So deffiniatelly something strange.
Tomasz
For a guy with no much time you answer with a light speed.. hollidays?
tomaszdrgas
Postby fredo6 » Wed Aug 09, 2017 9:01 am
Tomasz
Here is the model with all wheels spinning correctly.
I also enclosed the movement (Transalation and spinnings) into a clip, so you can reuse it in the animation, changing the distance and direction (via dimming factor).
tomasz - test2 MP4.skp
Film 1.mov
In a next version, I'll do something to make the cloning of elements and sequences easier to manage.
For the question of 1.skp, I guess this is not related directly to Animator. If you look at Forum, you'll see that this happens in various situations.
User avatar
PluginStore Author
PluginStore Author
Postby tomaszdrgas » Wed Aug 09, 2017 9:19 am
Sorry for trouble but I know how to meke the spin.. in corect speed.. What I ment was..
I have made rotate movement for 4 wheels. So 2 of them were moving opposite direction cos they were scaled *-1. I wanted without deliting movement itself remove two wheels from it.. Couldn't do it so..
Only way I know is deliting the movement for 4 wheels and meke new one for 2 wheels on one side and another for other side.
Editing values - Works. Editing selection - Don't know if possible.
Thanks again..
tomaszdrgas
Postby jgb » Fri Aug 11, 2017 5:05 pm
Fredo6, a favor please.
I just discovered your animation plugin, and went through this thread (quickly). It's installed but I have not yet played with it.
In the lead thread there is your usual documentation section and I well understand you have not (yet?) produced a .PDF guide. Instead you have references to 3 tutorials.
Could you please convert those references into clickable links?
jgb
__________________
jgb
User avatar
jgb
Postby fredo6 » Fri Aug 11, 2017 9:35 pm
jgb wrote:Could you please convert those references into clickable links?
Just fixed the link (polluted by an old bug in the forum, adding http: in URL).
Note that many videos are based on an older version of the GUI, but I guess you'll find your way with the updated GUI.
User avatar
PluginStore Author
PluginStore Author
Postby jgb » Fri Aug 11, 2017 10:07 pm
Thank you.
This old dog has difficulty learning new tricks.
I've tried many SU based animators over the years starting with SketchyPhysics (almost got the hang of it). Others left me wanting, others way too complex or plain unusable. I need a simple animator without the physics complications, so I hope, based on the quality and functions of your stuff, most of which I use daily (Curviloft in particular), this rendition of an SU animator will do the trick.
__________________
jgb
User avatar
jgb
Re: [Plugin Beta] Animator - v1.7c - 16 Aug 17
Postby fredo6 » Wed Aug 16, 2017 6:49 pm
New Release: Animator - v1.7c - 16 Aug 17
Requirement: LibFredo6 v7.7c
Minor release
- bug fixing
- First support of VRay (v3.40.04) for rendering of animations
See main post for RBZ files
User avatar
PluginStore Author
PluginStore Author
Shadows and date..
Postby tomaszdrgas » Mon Aug 21, 2017 6:30 am
I guess easiest would be interpolating date and hour seperately.
tomaszdrgas
Re: Shadows and date..
Postby fredo6 » Mon Aug 21, 2017 10:36 am
tomaszdrgas wrote:I guess easiest would be interpolating date and hour seperately.
Definitely.
If the two dates are separated by less than 24 hours, then interpolate the dates
Otherwise, interpolate the days, but keeping the same hour.
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin Beta] Animator - v1.7d - 23 Sep 17
Postby vailly » Sun Oct 15, 2017 7:12 pm
Nice job again Fredo6.
Is it possible to animate the "sun" to see the shadow of a building moving from early in the morning through the night?
Thanks,
François
vailly
Postby fredo6 » Wed Oct 18, 2017 8:09 am
vailly wrote:Is it possible to animate the "sun" to see the shadow of a building moving from early in the morning through the night?
This is possible with the Visual Effect "Shadow"
In the timeline,
- put a first one with the date/time of early morning
- put a second one with the date/time of late evening at the end (based on your video duration)
Shadow is a visual effect. So it can be combined with object and camera movements and with other visual effects (zoom, etc...).
Note that if the two date/time are separated with more than 24h, then you'll get a Season shadow animation. This is how you can simulate the shadow across several days, months or years.
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin Beta] Animator - v1.8a - 02 Nov 17
Postby fredo6 » Thu Nov 02, 2017 11:46 am
New Release: Animator - v1.8a - 02 Nov 17
Requirement: LibFredo6 v7.9a
Minor release
- bug fixing
- First batch of Performance improvement for large models
User avatar
PluginStore Author
PluginStore Author
Postby Mike598601 » Sun Nov 05, 2017 6:04 pm
Hey Fredo, you are genius :) I love animator
I tried rendering a clip in Twilight V2 pro, only 2 second duration (51 frames) - 30 hours in it had rendered 14 clips, so I decided to purchase V-Ray and upgraded LibFredo6 to 7.9 and animator to 1.8 as it says Vray is supported. Tried to render the same animation and it only took 1.5 hours - an amazing improvement!! I saw every frame rendering, However, the resulting movie, both MP4 and MOV were both only 1 frame long :( - Have I missed something? Can you advise me please?
Keep up the brilliant work!!!
Mike598601
Postby fredo6 » Sun Nov 05, 2017 9:41 pm
Mike598601 wrote:I tried rendering a clip in Twilight V2 pro, only 2 second duration (51 frames) - 30 hours in it had rendered 14 clips, so I decided to purchase V-Ray and upgraded LibFredo6 to 7.9 and animator to 1.8 as it says Vray is supported. Tried to render the same animation and it only took 1.5 hours - an amazing improvement!! I saw every frame rendering, However, the resulting movie, both MP4 and MOV were both only 1 frame long :( - Have I missed something? Can you advise me please?
For animation, I don't think you need super-rendering. If you have only 51 frames, with a rendering of 10 s, you should keep it under 10 minutes, whether Twilight or VRay.
Could you post or PM your model, so that I see how it renders with Vray and Twilight.
User avatar
PluginStore Author
PluginStore Author
Postby mast1987 » Sat Nov 11, 2017 7:30 pm
First: Big Thanks to FREDO for this Genius plugin.
Theres just 1 Thing I got a Problem with: Camera Fade out.
If I use more than 2 views/cameras the Animation stops at the second view/camera and doesnt fade to the third one.
what did I wrong?
mast1987
Postby fredo6 » Sun Nov 12, 2017 12:33 am
mast1987 wrote:If I use more than 2 views/cameras the Animation stops at the second view/camera and doesnt fade to the third one.
what did I wrong?
Could you please post or PM your model so that I have a look.
Maybe you simply disable fadeout for the second camera.
User avatar
PluginStore Author
PluginStore Author
Postby mast1987 » Sun Nov 12, 2017 6:46 pm
ok I got a solution:
when i set the camera Position with the eye tool it doesnt works.
when I set it with the Orbit and Hand tool it works fine.....
thanks for the quick answer btw
mast1987
Postby fredo6 » Mon Nov 13, 2017 11:24 am
Glad to see it works.
Still, I don't see why you have a difference, since Animator does not really care HOW you set a view: it just capture the camera when it is set.
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin Beta] Animator - v1.8b - 19 Nov 17
Postby fredo6 » Sun Nov 19, 2017 12:49 pm
New Release: Animator - v1.8b - 19 Nov 17
Requirement: LibFredo6 v8.0b
Maintenance release
- bug fixing
- Handling of cases where scenes which are part of an animation are deleted in Sketchup.
- improvement in circular camera interpolation (fadeout) if you also install LibFredo6 8.0b
_____________________________________________________________________________
User avatar
PluginStore Author
PluginStore Author
Postby Mike598601 » Wed Nov 29, 2017 3:45 pm
Just upgraded VRay to 3.6 but it no longer appears in the 'Render with' options in animator - is this version of Vray supported by animator in SU 2018?
Mike598601
Postby fredo6 » Thu Nov 30, 2017 4:33 am
Is Vray 3.6 installed in SU2018?
I will investigate on my side
User avatar
PluginStore Author
PluginStore Author
Postby solo » Mon Dec 04, 2017 5:39 pm
Go home Thea, you're drunk!
Why is Thea acting like a drunk uncle? see the animation in SU, this is what I want to render in Thea:
However, when I choose to render the animation I get this:
Is there a way to fix this? reset Thea in some way?
User avatar
Global Moderator
Postby ntxdave » Mon Dec 04, 2017 6:04 pm
I am assuming that when you went to create the animation using the Animator plugin you clicked the Thea button. I have not seen anything like that happen but I have not used Animator for a while
User avatar
ntxdave
Postby solo » Mon Dec 04, 2017 6:20 pm
ntxdave wrote:I am assuming that when you went to create the animation using the Animator plugin you clicked the Thea button. I have not seen anything like that happen but I have not used Animator for a while
If I did not press the Thea button then it would not have rendered with Thea, I did what I always do, use Thea animation with the Animator plugin selected.
Besides Thea, does Animator support other renderers? may be time to move on.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Animator Beta
cron
Who is online
Users browsing this forum: No registered users and 0 guests
Visit our sponsors:
