UV mapping of reflection map in Sketchup?
General discussion on V-Ray for SketchUp
Postby gnome_mo » Tue Jul 04, 2017 8:48 am
Is it possible to custom position reflection and glossiness maps in vray for sketchup?
I'm trying to add some surface imperfections like puddles on the road, fingerprints, but not as edited diffuse texture.
Thanks in advance
gnome_mo
Re: UV mapping of reflection map in Sketchup?
Postby andybot » Wed Jul 05, 2017 1:36 pm
Unfortunately, you're limited to the one channel that SU uses, so additional maps can only be mapped relative that that channel (you can use the UVW transforms like scale and rotation.) There's no way to add additional mapping per material.
However, if you export the mesh and edit the UV mapping in another 3D software (such as Blender) you can bring in those additional channels by making that mesh into a proxy outside of SU. (There's a mesh to proxy converter included with vfs3: "ply2vrmesh" in "tools" in the vfs3 program folder) Then in SU, you can select the additional channels in the Vray material editor as required.
my blog featuring recent projects
User avatar
andybot
Premium Member
Premium Member
Postby omiKron » Wed Jul 05, 2017 1:49 pm
It could be a trick faking the order of layers. You have your main diffuse, you add a reflection layer with a texture linked to it, then swap order of layers. Or, if this doesn't do it, make 2 Diffuse layers : one with color, one with a texture [like puddles, imprints]. swap it the way you like. Then drag-n-drop the bitmap slot of Diffuse in Reflection.
If that doesn't do it, you need to separately scale the puddle-imprint texture to your diffuse texture.
User avatar
omiKron
Postby anamichelena » Sat Feb 10, 2018 10:20 am
andybot wrote:Unfortunately, you're limited to the one channel that SU uses, so additional maps can only be mapped relative that that channel (you can use the UVW transforms like scale and rotation.) There's no way to add additional mapping per material.
So, if I get this right: in the 'texture placement' menu, you can choose a UV channel/set (by default set to 1), but there is no way to assign and use these different channels?
Does this make sense to anyone else? :?
Ana
hardware:
MSI Apache Pro
Intel Core i7-6700HQ
16GB ram
GeForce GTX 1060
anamichelena
Postby filibis » Sat May 05, 2018 12:14 am
Check this fresh plugin: Physically-Based Rendering
User avatar
filibis
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to V-Ray
Who is online
Visit our sponsors:
