by hdpv » Sat Apr 25, 2015 4:55 pm
hdpv
- PluginStore Author
- Name: Huynh Duong Phuong Vi
- Operating system: Windows
- SketchUp version: 2018
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by bsfranza » Sun Apr 26, 2015 9:53 am
awesome plugin!!!!
keep up the great work!
bsfranza
- Name: bsfranza
- SketchUp version: 2019
- License type: Pro
by Esense3d » Mon Apr 27, 2015 8:31 pm
Hello Can not try (expired) but Translate to German
Esense3d
- Name: Roland F.
- SketchUp version: 2014
- License type: Free/Make
- SketchUp use: hobby
by cotty » Sat Jun 13, 2015 8:38 am
Very nice plugin! One suggestion: a one-click-undo for the slicing would be nice.
cotty
- Top SketchUcator
- Name: Carsten
- SketchUp version: 2020
- License type: Pro
by hdpv » Sat Jun 13, 2015 9:26 am
Thanks! I use Ctrl_Z for undo.
hdpv
- License type: Pro
by pilou » Sat Jun 13, 2015 1:37 pm
French version!
- Top SketchUcator
- Name: Pilou
- SketchUp version: 2017
by pilou » Tue Jun 30, 2015 8:17 am
- Top SketchUcator
- Name: Pilou
by hdpv » Mon Jul 06, 2015 2:18 am
my slice is very sharp,it can detach a face to 2 faces.  This is special case.I will try fix it.
hdpv
- License type: Pro
by Bob James » Fri Sep 09, 2016 12:45 pm
S4USlice is enabled and activated but when I try to use it I get the License Expired error. Extension Warehouse lists it in my extensions as enabled. This is the second time I've gone through this rain dance What's wrong this time????? --------------------------------------------------------------------- Purchased From: Trimble Navigation Ltd. TIN# 94-2802192 Netherlands VAT # NL003257447B01 Billed to: ________________________________________ Robert James 4159 Constellation Road Lompoc CA, 93436 United States Order Details: ________________________________________ Order Confirmation Number: 636688 Transaction Date: July 2, 2015 3:08:30 AM EDT Vendor Web Store: HUYNH DUONG PHUONG VI Your order includes the following items: Qty Item No. Description Unit Price 1 x ea643527-4b89-45da-a8f6-c79994cd15e3 s4u Slice 3.3.1 $9.00 US
Bob James
- Premium Member
- Name: Robert James
- License type: Pro
- SketchUp use: engineering and mechanical design
- Level of SketchUp: Intermediate
by hdpv » Sat Sep 17, 2016 4:00 pm
Sorry! Sketchup checks the license. I don't know this error.
hdpv
- License type: Pro
by Bob James » Sun Sep 18, 2016 11:38 am
hdpv wrote:Sorry! Sketchup checks the license. I don't know this error.
Are you going to attempt to find out? It would be nice if an extension I paid for would not be identified as expired.
Bob James
- Premium Member
- License type: Pro
by hdpv » Mon Sep 19, 2016 2:59 pm
You try uninstall then reinstall. http://help.sketchup.com/en/article/3000264Your licenses is not expired. or If you want install and active by manual(not on Extension WareHouse) i will send the file *.rbz to you.
hdpv
- License type: Pro
by Bob James » Tue Sep 20, 2016 4:02 pm
Extension Warehouse identifies Slice as enabled, but when used Slice is shown as expired. slice.PNG expire.PNG If you want install and active by manual(not on Extension WareHouse) i will send the file *.rbz to you.
Seems like the only thing left to do
Bob James
- Premium Member
- License type: Pro
by rv1974 » Thu Feb 02, 2017 1:27 pm
Hdpv, would it be possible to add a 'multi-point' (not just by 2\3 points we have now) cutting mode?
rv1974
- Name: rv1974
- License type: Pro
by ithil » Wed Jun 07, 2017 9:52 am
Hello! Many thanks for your plugin. I'm just happy with him =)
My work accelerated even more.
ithil
- Name: Ithil
- SketchUp version: 2015
- License type: Pro
by srx » Sat Sep 02, 2017 8:21 am
Hi. Congratulation on making one of the most useful Sketchup plugins. I have an idea to make it twice time useful  ...simply by adding inverse function. So it could not only trim SU geometry, but also extend it using the same logic in picking 2 point lines, faces or 3 point faces... Even more useful would be possibility to select a few faces, or curved surface as an "edge" for trimming, or extending. It would be powerful feature.
www.saurus.rs
srx
- Name: srx
- SketchUp version: 7
by makro88 » Thu Aug 29, 2019 6:16 pm
Hi, I've just purchased this extansions but after 3-4 inputs where it works correctly, it says "S4u_slice is not yet Activated. Do you have the Activaiton file?"
Any solution?
edit: I'm in touch with the developer, he's being super helpful. Apparently it's an issue linked to the extension warehouse, as I cannot use it within sketchup (it appears to be offline)
makro88
- Name: luca
- License type: Pro
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Plugins
